RE: futaba 3pk or m11? please help!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Radio Equipment >> RE: futaba 3pk or m11? please help!!!!
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: futaba 3pk or m11? please help!!!! - 8/29/2006 2:44:39 PM
Rs43EVOman
Status: offline
Well im using the synthezized version, and until i get digital servos, i should use the PCM right?
(in reply to SAVAGEJIM)
       Post #: 26
RE: futaba 3pk or m11? please help!!!! - 8/29/2006 3:24:10 PM
Ryanrodfl6363lu
Status: offline
as long as you are not using HRS with no digital servos then you will be ok. if u are using HRS with no dogital servos you will know it very quikly because it will burn them up. also DSM, or spectrum works in these radios, however futaba does not reccomend it, and by using it voids all warranties.
(in reply to Rs43EVOman)
       Post #: 27
RE: futaba 3pk or m11? please help!!!! - 8/29/2006 4:08:50 PM
Rs43EVOman
Status: offline
Well im probably gonna go toay to get my radio hopefully the LHJS wont close early becuase of the Hurricane!!
(in reply to Ryanrodfl6363lu)
       Post #: 28
RE: futaba 3pk or m11? please help!!!! - 8/30/2006 1:34:28 AM
SAVAGEJIM
Status: offline
quote:
ORIGINAL: Ryanrodfl6363lu
... DSM, or spectrum works in these radios, however futaba does not reccomend it, and by using it voids all warranties.
If you ever have to waranty your 3PK and you have used the DSM module, do not ever tell Futaba that. Before you send it in, simply slap on the original Futaba TX module.
_____________________________
I hate stray Tomcats
       Post #: 29
RE: futaba 3pk or m11? please help!!!! - 8/30/2006 1:37:35 AM
SAVAGEJIM
Status: offline
I should also add, I made the mistake of telling Futaba that I have been using ths DSM module. I still sent it in and the replaced my LCD (the display was screwed up) and it only cost me about $37. They told me that so long as the DSM module was not the cause of the problem, then the warranty work would be done without any additional charges.
       Post #: 30
RE: futaba 3pk or m11? please help!!!! - 8/30/2006 1:45:09 AM
Rs43EVOman
Status: offline
This is ym first high-end radio, so i dont know what to expect. I was wondering, How confusing are the menus? Is it preatty easy to figure out and get the radio set-up? Also does the 3PKS Synth come with the Advanced wheel positioner thing? Every time i see pro races the guys with the thing have the wheel dropped straight down, and i was just wondering if it came with the radio, looks like a cool feature
< Message edited by Rs43EVOman -- 8/30/2006 1:46:07 AM >
       Post #: 31
RE: futaba 3pk or m11? please help!!!! - 8/30/2006 2:26:19 AM
Airbus 9e
Status: offline
Yup.....it comes with the wheel postioner......if you have big hands.....like me.....it's nearly useless though.....good luck....I love my 3PK....
Custom Works x3.....ADX, Custom T-Maxx,Losi Aftershock, NTC3, RC10T4 Oval, and a lot of other junk.....
       Post #: 32
RE: futaba 3pk or m11? please help!!!! - 8/31/2006 11:57:02 AM
Rs43EVOman
Status: offline
Guys got my 3PK Super PCm 75 MHZ, but i was wondering how do you change the crystal in the module, if you wanted to change channel?
       Post #: 33
RE: futaba 3pk or m11? please help!!!! - 8/31/2006 8:48:12 PM
Ryanrodfl6363lu
Status: offline
Rs43EVOman i dont know how the change the crystals out. i would imagine that the module would open up somehow, but i am not sure. why didnt you get the synthesized one? just curious. i am still researching radios, and i am pretty much decided on the 3pk, but i was just wondering if there was a benefit to getting the crystalized one over the synth.
       Post #: 34
RE: futaba 3pk or m11? please help!!!! - 8/31/2006 10:19:57 PM
SManMTB
Status: offline
quote:
ORIGINAL: Rs43EVOman
You can't! You need to get a new module for every frequency you are going to use.
Why didn't you buy the synthesized module?
       Post #: 35
RE: futaba 3pk or m11? please help!!!! - 8/31/2006 10:21:29 PM
SManMTB
Status: offline
Synth all the way. Crystals are old tech and there's no benefit at all.
(in reply to SManMTB)
       Post #: 36
RE: futaba 3pk or m11? please help!!!! - 9/1/2006 1:29:18 AM
Rs43EVOman
Status: offline
Didnt knwo that, what ever, ill eventually buy my self the synth, probably wouldnt have bought it if i knew that
       Post #: 37
RE: futaba 3pk or m11? please help!!!! - 9/1/2006 1:46:31 AM
Airbus 9e
Status: offline
The module is removable....You just slide the cover off towards the side where the charge jack is, then the whole module pops out. There's a metal piece that covers the crystal, just remove that carefully, then you can pull the crystal out....
       Post #: 38
RE: futaba 3pk or m11? please help!!!! - 9/1/2006 1:50:27 AM
SAVAGEJIM
Status: offline
On the upper left of the 3PK just under the lid that houses the TX module and in front of the big black circle (the round cover for the left-hand conversion), you will see a small recessed black square with XTAL written under it. This is the crystal access.
You can change the crystal by taking out the TX module and prying the little metal plate off. (it is only heln on by take adhesive or sticker adhesive; it's not hard to take off.) Under that, you will see the crystal with the little paper tab tucked neatly forward. Just take a sewing pin to reach in and pull out the paper tab. This tab will tell you what frequency your TX module is operating at. Pull the paper tab to yank out the crystal; and if you have another crystal, slap it in!
If you change your Tx frequency, BE SURE to also change your receiver the same frequency.
Let me warn you, acording to the laws governing the FCC, changing your own crystals in your radios and receivers is illegal (I don't know why this retarded law was even passed).
       Post #: 39
RE: futaba 3pk or m11? please help!!!! - 9/1/2006 2:01:34 AM
Ryanrodfl6363lu
Status: offline
it is illegal to change crystals? then why would they put them there? i havent heard of this law, but if it is true, then it truly is retarded....... could u imagine sitting in jail.....
"what are ya in for?"
"i switched my crystal in my transmitter"
lol. sorry guys. im probably just not understanding this all correctly.
       Post #: 40
RE: futaba 3pk or m11? please help!!!! - 9/1/2006 2:19:08 AM
Rs43EVOman
Status: offline
Yah i saw that sawuare on the module, how hard should i have to pry to get it off, i thought that might be it, but i didnt want to try too hard, and mess anthing up. What should i use to pery it out, i could do it with a small screw driver. Think it would be eaiser if i took off the cover of the module?
