Is this a good configration
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> Is this a good configration
Page: [1]
Login
Is this a good configration - 8/22/2006 11:14:40 PM
zsultan
Status: offline
T-Rex XL HDE V3 with Futaba GY 401 gyro, TP2100 3-Cell LiPo 15A,HITEC Electron-6 MICRO RECEIVER /#29 crystal. 2 HS-55 Servos, 1 HDS-877 digital servo on tail. 35A ESC and 430L motor. about 50 fligts on it . Is it a good buy for $400?
< Message edited by zsultan -- 8/23/2006 3:30:00 PM >
       Post #: 1
RE: Is this a good configration - 8/22/2006 11:37:12 PM
RcFlyer06
Status: offline
Zsultan,
On the battery is it 15A or 15C??? Big difference!!! 15C I'd say your good (measn your getting more then 30A continuous) but 15A won't cut your power needs and you'll probably damage the battery!!! And why do you only have two servos on swash? lol. I assume you ment three, hs-55s are a little weak but there's enough combos out there with them that I guess they'll get you in the air, I'd at least get hs-56s. Gy401, EXCELLENT!!! I don't know the servo your using but it's digital so it can't be horrible and will probably help realize the GY401's full potential.
_____________________________
If your nose starts bleeding it means your picking it too much...or not enough
(in reply to zsultan)
       Post #: 2
RE: Is this a good configration - 8/23/2006 1:29:39 AM
ptarp
Status: offline
I think the HDS is a modded Hitec servo to convert to digital...I've heard people having troubles with them. You might consider just getting HS-56 all around (or HS065-MG if money isn't a concern).
Philip Tarpley (PTarp)
(in reply to RcFlyer06)
       Post #: 3
RE: Is this a good configration - 8/23/2006 3:26:38 PM
zsultan
Status: offline
I am just a newbie i wont be doing any 3D very soon. I am planning on buying this configration from some one for $400. is it a good deal and can i use HS 55 and the HDS 877 for a while, till i get good at flying or do you guys think $400 is too much for this.
(in reply to ptarp)
       Post #: 4
RE: Is this a good configration - 8/23/2006 4:46:29 PM
ptarp
Status: offline
It looks like a decent deal...just price all the parts new and add 'em up. I wouldn't pay more than 70% for anything used personally.
       Post #: 5
RE: Is this a good configration - 8/23/2006 4:53:24 PM
zsultan
Status: offline
Thanks Ptrap,
All new will cost me close to $600. I am little concerned about HS 55's and HDS 877 on tail. do u think they ll be ok till i master forward flight and nose in.
< Message edited by zsultan -- 8/23/2006 5:21:30 PM >
(in reply to ptarp)
       Post #: 6
RE: Is this a good configration - 8/23/2006 5:25:28 PM
RcFlyer06
Status: offline
They will take you into forward flight just fine. It's when you start 3d maneuvors or even aerobatics that the servos could be become a problem.
       Post #: 7
RE: Is this a good configration - 8/23/2006 7:24:40 PM
bdavison
Status: offline
That's a steal at 400 bucks.
The gyro alone is 160-180 bucks.
Pretty good set-up.
teamflyingcircus.com
       Post #: 8
RE: Is this a good configration - 8/24/2006 2:05:26 PM
ptarp
Status: offline
Its much cheaper than that...you are maybe thinking about the gyro/9254 combo?
I agree with RcFlyer06. The servos should be fine for learning and gentle aerobatics.
< Message edited by ptarp -- 8/24/2006 2:06:28 PM >
(in reply to bdavison)
       Post #: 9
RE: Is this a good configration - 8/24/2006 3:18:13 PM
zsultan
Status: offline
ptarp,
do you think $400 is ok for this setup? this is used.
(in reply to ptarp)
       Post #: 10
RE: Is this a good configration - 8/24/2006 6:05:11 PM
ptarp
Status: offline
It looks like a fair deal to me. Not a steal or anything, but fair price for used gear.
       Post #: 11
RE: Is this a good configration - 8/24/2006 7:02:54 PM
zsultan
Status: offline
ptarp,
$400 includes shipping and lots of spare parts. like 2 sets of blades etc
< Message edited by zsultan -- 8/24/2006 7:03:52 PM >
(in reply to ptarp)
       Post #: 12
RE: Is this a good configration - 8/24/2006 7:48:29 PM
Nankin Hobby
Status: offline
That is not a bad deal. The gyro is great the heli is great and the Rx will be fine. As you have read the others have suggested getting rid of the servos. I would definatly do this. I run the HS-65HB servos by hitec and they are the best micros on the market hands down. The metal gears are not necissary one bit. Save the 40 dollrs on the karbonite ones and get urself a couple pairs of blades/other spare parts. As long as all the parts are functioning correctly (i.e. see it fly is possible) id get it.....you wont get that setup for less and if that is where u want to go with helis jump on it.
Mike Galunas
Tech/Sales
       Post #: 13
RE: Is this a good configration - 8/24/2006 7:51:16 PM
Nankin Hobby
Status: offline
Also as you progress in flight u can convert parts to SE specs and be set.
Mike Galunas
Tech/Sales
(in reply to Nankin Hobby)
       Post #: 14
RE: Is this a good configration - 8/26/2006 1:04:09 PM
shaitan
Status: offline
One thing to check on that XL is whether the 430L has gold (bad) or silver (good) endcaps. The gold motors had a problem (they come apart). Honestly, it's not a hot deal. It's an XL, and it's used. If you check around, you can snag a 450SE RTF package (with good stuf, HS65, GY401, 9650, 430L, battery, etc.) for less than $800. Twice the money, yes. But, it's new and more than twice the bird.
I bought an XL used, and wish I hadn't.
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
