mbiedul
Joined: 11/29/2002 From: Edmonton, AB, CANADA Status: offline
bkyser - Bob: On the Super Lazy Ace, 96" span, there are no bulkheads in the normal trace-from-pattern sense. Chuck has 1/4" x 1.5" (I'm guessing...maybe its thicker and wider pieces.... I'm not at home with the plans) pieces top and bottom, overlapped by the same material for the sides. Easier to do than describe but it makes a nice strong box. Think of 4 popsicle sticks glued to make a square frame. There is an alarmingly long expanse with no "bulkhead" at all in the wing area, but then the sides are very thick and heck it gives me a lot of room for equipment! It is all on the fuselage plan, at least on my 96" version, but there is no "template". I used spruce stringers on the cockpit to tail top and it didn't add much weight. The balsa stringers felt to me that anyone restraining the model would crush them..... I don't recall about dihedral angle. I think he just gives the inches to raise the tips when joining the halves, and you are on your own for a template again. Hope this helps. e-mail if you need a hand. -Mike
