Cool Power bad rep?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Cool Power bad rep?
Page: [1] 2   next >   >>
Login
Cool Power bad rep? - 8/23/2006 11:11:29 PM
daveopam
Status: offline
I have never used Cool Power before. My LHS said I should try it for my Saitos. He sold me 15%
heli full synthetic. I don't want to start a caster vs synthetic debate. I have been running Rich's Brew. Supply is greater than demand and we can't get it here anymore. Who has some real world time with Cool Power. Can anybody tell me why some call it Cruel Power? I can't imagine the LHS running it if is that bad.
David
_____________________________
"Choose your shirt and shoes by the color. Choose your friends by their character." unknown
       Post #: 1
RE: Cool Power bad rep? - 8/24/2006 4:11:16 AM
CiprianGugu
Status: offline
I have been using Cool Power for years and I like it a lot. But since I use the cheapest fuel that I can find locally, lately I have been using Wild Cat. Use whatever you find locally, just make sure you tune the engine properly and you will not have any problems.
After running a few gallons of cool power through an engine, the insides will turn a nice green color. Very cool.
< Message edited by CiprianGugu -- 8/24/2006 4:17:05 AM >
(in reply to daveopam)
       Post #: 2
RE: Cool Power bad rep? - 8/24/2006 1:50:43 PM
Jezmo
Status: offline
Look at what the Major Competitors are using at the big events. You will see many using Cool Power or one of CP's "parent companies" other brands. (The parent company of Cool Power has several different brands) Anyway, I have used a number of different fuels and found that most are very good. More a matter of personal preference, price, and availability. Just my two cents.
Raptor 50 V2 OS 50 Hyper, T-Rex 450XL CDE, Spektrum DX7, SuperTigre OS FOX Saito Enya Jett TT
(in reply to CiprianGugu)
       Post #: 3
RE: Cool Power bad rep? - 8/24/2006 2:22:27 PM
daveopam
Status: offline
Thanks guys. I didn't think the LHS would ever steer me wrong but I wanted a little reassurance.
thanks again, david
(in reply to Jezmo)
       Post #: 4
RE: Cool Power bad rep? - 8/24/2006 9:38:02 PM
Sport_Pilot
Status: offline
Read your Saito manual. Cool power would void the warrenty! Don't use fuel without some castor! It is called cruel power because it is cruel to your engine. But really not that bad for ringed two strokes, if you keep it on the rich side. And it may not be that bad for the Saito, but it will void the warrenty. And they can tell if there has been no castor in the engine. With castor the inside of the case will have a nice rusty gold color.
“I Saw Elvis at 1000 Feet” John Force
       Post #: 5
RE: Cool Power bad rep? - 8/25/2006 12:27:26 AM
CiprianGugu
Status: offline
Sport Pilot,
The manual of my Saito 91 does not mention anything about castor oil. In the fuel section it says to use "a high quality 2-cycle fuel like, Omega, Cool Power, K&B, Power Master, etc." Omega has some castor oil in it, but Cool Power doesn't. So, I use whatever I find locally and make sure that it is not lean.
Happy flying.
(in reply to Sport_Pilot)
       Post #: 6
RE: Cool Power bad rep? - 8/29/2006 7:10:31 PM
RC-Bearings
Status: offline
In the heli world, I am getting some reports of bearing failures (OEM and mine) by people using Cool Power 30% heli mix. I attibute this to it haveing an extremely low viscosity oil (somewhere near 5W). Most other fuels use oils with viscosities in the 20-40W range.
< Message edited by RC-Bearings -- 8/29/2006 7:11:08 PM >
Steel and Ceramic bearings for model engines
http://www.rc-bearings.com
       Post #: 7
RE: Cool Power bad rep? - 8/29/2006 7:20:22 PM
Sport_Pilot
Status: offline
Castor is as thick as 50W motor oil when cold. I don't know how much it thins out hot, but have a hunch it does very well.
(in reply to RC-Bearings)
       Post #: 8
RE: Cool Power bad rep? - 8/30/2006 5:52:09 AM
downunder
Status: offline
Castor is the only oil allowed in both FAI Pylon and FAI CL speed where engines are turning upwards of 40K revs and fully peaked out. These are the most extreme conditions our engines can ever run in and no one complains about the oil.
In CL stunt where engines live a very easy life running in a 4 stroke all the time no one will even consider using Cruel Power (or one other brand known as the Red Death) because very long and consistent engine life is needed.
       Post #: 9
RE: Cool Power bad rep? - 9/7/2006 6:27:11 AM
AndyW
Status: online
I run and fly mostly small engines. The last few years mostly 1/2A and mostly Norvels. My experience with fuel in the smaller engines is that yes, castor is necessary in SOME engines, notably the Cox line and the VAs from Russia. The issue is the shrouded wrist pin with the VA and the ball socket rod with Cox. In both cases, there's much less fresh fuel/oil circulating in these areas because of the design. If you DON'T use lots of castor in these engines, you'll have premature wear.
HOWEVER, in the Norvels, I've run Cool Power 25% for a few years now and have not had any problems. In fact, I've found superior power, idling and acceleration with Cool Power.
The worst fuel, at least for 1/2A, was Byrons 1/2A formula. Same day, same prop, same engine and the CP was far superior. In fact, the Byron was the worst fuel these engines had ever seen. On top of that, the Byron was specified for 1/2A and the CP is NOT. But Norvels are unique, won't say the same thing for any other brand of small engine.
On the same note, I had run, for years, Morgan's 25% Sidewinder fuel on small engines with no problems whatsoever. And many of these were Cox engines. Go figure, especially in that Sidewinder fuel is for CARS and has only 10% oil. And recent flying with Sidewinder on a Norvel .074 has shown good power and good throttling. ??? Beats me.
But I DO like Rich's Brew, especially in that he'll mix up any formula you want,, like 60% nitro with 25% castor. Just what I needed for TD .010s and TD .020s. Throttling is much improved with the increased nitro. Yes, expensive, but not on a per flight basis.
Here,
http://www.youtube.com/profile?user=hopeso
You can see a custom heli engine turning a 6 X 3 Grish prop at 19K plus on 25% Cool Power. Not bad. Same goes for a modified Brodak .049 in one of the other videos.
< Message edited by 1705493-AndyW -- 9/7/2006 6:30:27 AM >
Andy Woitowicz
(in reply to downunder)
       Post #: 10
RE: Cool Power bad rep? - 9/7/2006 11:19:19 PM
daveopam
Status: offline
Thanks Andy. I have not used up the old fuel to start on the Cool Power yet. Next month I should be onto it. You and others have reassured me.
Thanks Again,
David
(in reply to AndyW)
       Post #: 11
RE: Cool Power bad rep? - 9/8/2006 5:45:30 AM
AndyW
Status: online
That's COOL Dave,
Andy
< Message edited by 1705493-AndyW -- 9/8/2006 5:46:54 AM >
Andy Woitowicz
       Post #: 12
RE: Cool Power bad rep? - 9/8/2006 6:02:04 PM
bgruenba
Status: offline
quote:
ORIGINAL: daveopam
David
My son and I have used CoolPower in our 14 engines for the last 2 years. We have 4 Saitos (1x91, 2x100, 1x180), 6 OS 2 stroke airplane (4x46AX, 1x50SX, 1x61FX) and 4 OS 2 stroke helis (2x32SX-H, 1x50SX-H, 1x91SX-H).
We use CoolPower 15% 4-stroke in the Saitos and regular 15% in the OS 2 strokes. There is no difference between the 15% and 15% heli (see the FAQ on Morgan's web site).
I switched to CoolPower after the 50SX burned its rings twice running 15% S&H. We were not running it lean. Since then, we have run easily 7 gallons through the 50SX alone and had absolutely no problems and great performance. The helis and the 4 strokes work beautifully. Two of the 4 strokes are in Funtanas. The 91 is in my Funtana 40 and the 100 is in my Funtana 90. The 91 has burned several gallons of gas as my primary plane.
No question - CoolPower is the only fuel I would use. Small problem, though. I have just moved to California from New Hampshire (more flying days) and I can't find a dealer in the Pasadena area that carries CoolPower. Anyone?
regards,
Bruce
       Post #: 13
RE: Cool Power bad rep? - 9/8/2006 7:56:28 PM
hilleyja
Status: offline
OS 1.60 Ringed engine. 1 gallon of 15% Coolpower sloppy rich OK
2nd Gallon of Coolpower, maybe ONE lean run and damage to both ring and sleeve -- NO MORE COOLPOWER for me.
Since then I have been running Wild Cat Xtra Premium 15% in ALL of my engines except 2 of them -- no problems at all. (I don't mind the castor varnish on my heads and mufflers)
I use FAI Omega on my Moki 180 -- it is not running well right now so school is out on it.
I used 50% Methonal and 50% Wilcat 15% Xtra Premium on my Super Tiger 3000 -- ran great.
Jim Hilley
AMA #671825
RCCA# 758
Twist 150 Brotherhood #14
(in reply to bgruenba)
       Post #: 14
RE: Cool Power bad rep? - 9/8/2006 8:07:44 PM
daveopam
Status: offline
I think your going to find the Saito likes nitro.
David
(in reply to hilleyja)
       Post #: 15
RE: Cool Power bad rep? - 9/9/2006 5:14:43 AM
