Twanger -> RE: Cool Power bad rep? (3/11/2007 3:24:34 AM)
I like to switch back and forth from syn/cas to straight synthetic. I'll run syn/cas until I can feel the prop shudder as I SLOWLY turn it through a compression stroke by hand. This seems to happen more when the humidity is high. The first sign is when you can't seem to get the needle set right. You think it's lean, so you richen it. You search for the sweet spot. It's not there. You start having deadstick problems. GRAB THE GREEN! A couple of tanks, and she's tearin' up the sky. Slow compression stroke test, shudder greatly diminished or gone. Half a gallon or so later, go back to the syn/cas. Everybody's happy![:)] I might add that I run .40 size two stroke engines exclusively. YMMV[;)]
