RE: Cermark Pitts Build/Assembly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Cermark Pitts Build/Assembly
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: Cermark Pitts Build/Assembly - 1/27/2008 4:25:19 PM
Mutt
Status: offline
Saito 1.25 will fly it fine. I have had a Saito 1.80 in my first one then went to the zenoah g-23 was so much more fun and cheaper to fly with the zenoah. The evo 26 is awesome since its real light and more power then the zenoah. The Saito 1.25 will be a blast with it too have fun with it they are nice flying planes.
(in reply to fritzdecat)
       Post #: 76
RE: Cermark Pitts Build/Assembly - 1/28/2008 1:32:37 AM
brewski
Status: offline
The 120 ax is a really nice fit. Vertical is maybe not unlimited but sure is close. Today was my first flight and all was good until the motor died due to losing tank pressure. The muffler had been in a prior nose over and broke both stingers. They were JB welded back and that was where I made the mistake to use it. The stingers came loose in flight thus the tank pressure issue. I had no chance of getting in back to the runway so I landed in a field nearby. Fortunately the only damage was to the landing gear. The ply that the landing gear is mounted to is unbelievably light. It needs to be beefed up before anyone attempts to fly the Cermark.
_____________________________
A bad day flying is better than a good day at..........well........maybe not.
Revver Bro #177
(in reply to Mr67Stang)
       Post #: 77
RE: Cermark Pitts Build/Assembly - 1/28/2008 1:58:20 AM
Mutt
Status: offline
My old cerkmark pitts I have one from 2000 or 2001 never had a landing gear issue ever and ive landed short of the run way a few times.. I really like the old pitts from them. Hey by the way I cant find my book can you do me a favor what is the elevator and ailerons low and high rate settings I want to check them out its been a while since I flown Her. The settings are the same old and new pitts.
(in reply to brewski)
       Post #: 78
RE: Cermark Pitts Build/Assembly - 1/28/2008 2:09:08 AM
fritzdecat
Status: offline
on the new one
LOW ........................... HIGH
AIL 1/2 up 1/2 down ............................ 7/8 up 7/8 down
Elev 1 3/8 up/down .................... 2 1/4 up/down
Rudd 1 1/2 left/right ........................ 2 1/4 left/right
Twist Brotherhood #15 AMA # 871253
(in reply to Mutt)
       Post #: 79
RE: Cermark Pitts Build/Assembly - 1/28/2008 2:31:50 AM
Mutt
Status: offline
fritzdecat THank you very much Your a life saver. I dont know what happened to my books on the old and the newer one. Now that you gave me the specs I will find them lol thanks again. When I get a change I will and the weather lets up I will take a pic of them and put them up.
       Post #: 80
RE: Cermark Pitts Build/Assembly - 2/4/2008 1:05:58 AM
jsenicka
Status: offline
Howdy all.
I just picked up a perfect shape blue version at our club swap meet.
Can someone give me the forward and aft balance limits?
Thanks!
(in reply to Mutt)
       Post #: 81
RE: Cermark Pitts Build/Assembly - 2/4/2008 1:24:53 AM
Mr67Stang
Status: offline
Okay I lust looked at my instructions to see what it says. It says to balance it 1/4 inch in front of the rear cabane strut. There is a nice picture in the manual that shows this. I do not want to assume you don't know but because I would not know without the picture I will explain better. The Strut/frame work that bolts to the center of the upper wing is the cabane strut securing the wing with 2 bolts. The rear most bolt goes though this rear strut. At the leading edge of that rear strut measur 1/4 inch forward and balance there.
He who dies with the most toys wins!
(in reply to jsenicka)
       Post #: 82
RE: Cermark Pitts Build/Assembly - 2/4/2008 1:27:39 AM
Mr67Stang
Status: offline
Well in an effort to over do everything I picked up a new OS 1.60 fx with a Pitts muffler for my Cermark Pitts. Should be somewhere between balistic and rediculous
       Post #: 83
RE: Cermark Pitts Build/Assembly - 2/4/2008 7:28:30 PM
Propwash-don
Status: offline
How would a Zenoah 20 Ei do in this plane.
       Post #: 84
RE: Cermark Pitts Build/Assembly - 2/4/2008 7:36:33 PM
jsenicka
Status: offline
Mr67Stang,
thanks. I also saw on another post that 1/4 inch in front to the lower wing. I need to go look at hot the rear cabane lines up with leafing edge of lower wing at the fuse side.
As far as the OS160 and Pitts muffler, the guy I picked up my Pitts from started with one in his and needed 12 oz of lead in the tail to get it to balance.
(in reply to Propwash-don)
       Post #: 85
RE: Cermark Pitts Build/Assembly - 2/4/2008 7:38:03 PM
Mutt
Status: offline
It will fly it fine its lighter then the g-23 and almost the same hp. If you own the engine all ready I would say use it if considering and gonna buy a engine I would go with the evo 26 lot lighter and more power.
       Post #: 86
RE: Cermark Pitts Build/Assembly - 2/4/2008 8:24:18 PM
Mr67Stang
Status: offline
quote:
ORIGINAL: jsenicka
Mr67Stang,
I think You misunderstood me so I took a picture of the balance procedure.
Click to see fullsize image.
Click for fullsize
       Post #: 87
RE: Cermark Pitts Build/Assembly - 2/4/2008 9:11:53 PM
fritzdecat
Status: offline
I ended up going with an Evolution 26GT2 and it flew the plane perfectly heres a You Tube vid of the
Pitts Break in
       Post #: 88
RE: Cermark Pitts Build/Assembly - 2/4/2008 9:33:58 PM
Mr67Stang
Status: offline
What size prop do you use with the Evo 26 GT?
       Post #: 89
RE: Cermark Pitts Build/Assembly - 2/4/2008 9:49:17 PM
fritzdecat
Status: offline
18 X 8 APC but think I might switch to a 16 X 8
This was plenty of engine for a little Bipe . Def requires a new set of skills to fly but its a blast.
Keep an eye on those little 440 bolts that hold the metal wing connector brackets to the fuse. They loosened up from vibration when I was breaking in the engine. The are a royal pain in the a$$ to tighten.
