RE: A123Racing Battery Questions
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: A123Racing Battery Questions
Page: <<   < prev  3 4 5 6 7 8 9 [10] 11 12   next >   >>
Login
RE: A123Racing Battery Questions - 7/12/2007 6:01 AM
SS Pede
Score: 100
Last Login: 5/18/2009
Status: offline
*Ping* Still hoping to hear some word of new pack sizes/configurations. I could get a current pack but I would like a more standard-sized one.
Hide Signatures
(in reply to Tex Gehman)
       Post #: 226
RE: A123Racing Battery Questions - 7/14/2007 3:24 PM
DLS II
Score: 100
Last Login: 11/2/2009
Status: offline
I came across a statement on the net that the new smaller cells are AA size at 1200 mah- but I can't verify this. Don
Hide Signatures
(in reply to SS Pede)
       Post #: 227
RE: A123Racing Battery Questions - 7/14/2007 4:12 PM
Red Scholefield
Score: 179
Last Login: 9/27/2009
Status: offline
quote:
ORIGINAL: Tex Gehman
Great info, all. I've been using SPTs for years on NiCd and NiMH cells, and can't see just how one would attach balance leads to all cells, in say, a 6S pack like I will be using. Tex.
It is quite easy, just insert a small strip of brass shim stock between the cells before you add the end caps and long theaded rods. Let the shim stock stick out far enough to solder the balancing leads to.
_____________________________
Red S "AMA 951 since 1958
www.hangtimes.com/redsbatteryclinic.html
Hide Signatures
       Post #: 228
RE: A123Racing Battery Questions - 7/15/2007 1:21 AM
OCR99
Score: 100
Last Login: 11/3/2009
Status: offline
I have 123 cells 2300 ma i put them in 3&4 cell packs i have a 60 size eflight with 7 cells in searis and 16x10 prop i get 54 amps 1100 watts at prox 6400 rpm---with 17x10 i get 59 amps 1200 watts at 6500 rpm this all when plane in one place on ground.The plane flew great straight up harrires and so on aprox 8 min flying,i am goig to try same set up in parrallel dont know if exrta 1 lb will make much diferance im afraid it will take away 3d capability,amy body know how much amp differance in flight compared to ground?
Rick
Hide Signatures
       Post #: 229
RE: A123Racing Battery Questions - 7/15/2007 1:51 AM
Tex Gehman
Score: 100
Last Login: 8/25/2009
Status: offline
quote:
ORIGINAL: Red Scholefield
Red: I've also been told that I can just hammer the buggers with amps and they'll eventually sort themselves out. My brief experience with them leans towards this philosophy. Tex.
Hide Signatures
(in reply to Red Scholefield)
       Post #: 230
RE: A123Racing Battery Questions - 7/15/2007 2:31 AM
Richard D Bahmann aka/Wrongway
Score: 100
Last Login: 11/7/2009
Status: offline
Hammer them....do you mean like this?........
http://www.youtube.com/watch?v=GDHJNG2PngQ
Material, Craftsmanship, Design =Super Props www.WrongwayRC.com
Hide Signatures
       Post #: 231
RE: A123Racing Battery Questions - 7/15/2007 3:27 PM
Red Scholefield
Score: 179
Status: offline
Be my guest . . . . at US$10 per cell.
Hide Signatures
       Post #: 232
RE: A123Racing Battery Questions - 8/7/2007 6:39 PM
ronin149
Score: 100
Last Login: 2/26/2008
Status: offline
I work for a small R&D firm. One of our specialties is electric traction. Your batteries get all of us very excited! They are quite literally the batteries I have been waiting my whole career for. My question: Are there any Li-ion supervisor chips that are tailored for use with A123 battery systems? I've done hours of research, & the voltage thresholds are always wrong. I can get them in 0.05V increments from 4.1V up to 4.35V, all too high considering my 3.6V final voltage. Today I start designing a circuit from scratch, but I thought I'd ask just in case someone knew of something.
thanks,
Jeff
ICONIX R&D
Hide Signatures
       Post #: 233
RE: A123Racing Battery Questions - 11/3/2007 9:03 PM
skyrider2
Score: 100
Status: offline
I received an email today (11/3) from Hobby City
https://www.unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=5632
saying that the Yuntong 2700 mah LiFePo4 cells are now available @ $10.50 each.
skyrider2
Hide Signatures
(in reply to ronin149)
       Post #: 234
RE: A123Racing Battery Questions - 11/4/2007 10:30 PM
OCR99
Score: 100
Status: offline
DO THEY HAVE SOLDERING TAPS IT WAS HARD TO SEE?
RICK
Hide Signatures
(in reply to skyrider2)
       Post #: 235
RE: A123Racing Battery Questions - 11/5/2007 4:13 PM
bradman
Score: 100
Last Login: 11/5/2007
Status: offline
PLEASE NOTE!!!! that Hobby City LiFePO4 cells are not A123Racing cells. They do not utilize our patented Nanophosphate technology and therefore have very different performance characteristics.
Make sure you know what you are purchasing. People have purchased cells similar (if not the same) and found when they received them that they were rated for a 2C (not 20C) discharge.
Power . Safety . Life
Brian
Hide Signatures
(in reply to OCR99)
       Post #: 236
RE: A123Racing Battery Questions - 11/5/2007 10:44 PM
OCR99
Score: 100
Status: offline
THANKS FOR HEADS UP
RICK
Hide Signatures
(in reply to bradman)
       Post #: 237
RE: A123Racing Battery Questions - 11/27/2007 4:53 AM
SS Pede
Score: 100
Status: offline
Is there a balancer that could potentially balance A123 and LiPo packs? I have not yet purchased a new generation of batteries for my truck, but if I ended up owning LiPo and A123 packs it would be nice to have a single device that would balance both. Say I got a balancer with just pins as a plug, without the plastic housing, so it would fit any balance tap with the right pin configuration. Would an Astroflight Blinky (regular, not A123 version) balance an A123 pack if it was fully charged? This would be to avoid tripping the Blinky's low voltage protection.
Hide Signatures
(in reply to OCR99)
       Post #: 238
RE: A123Racing Battery Questions - 11/27/2007 12:15 PM
OCR99
Score: 100
Status: offline
Yes the astro blinky makes them they are same except you need ywo because of differant voltages on batteries
Rick
Hide Signatures
       Post #: 239
RE: A123Racing Battery Questions - 11/27/2007 8:59 PM
SS Pede
Score: 100
Status: offline
Well, I would hope to not need two Blinky's. I'm wondering if the regular LiPo Blinky will balance A123 packs as long as they are fully charged so the voltage is not too low. Would the Blinky still think they were LiPo cells (just partially charged ones) and balance them normally?
Hide Signatures
(in reply to OCR99)
       Post #: 240
RE: A123Racing Battery Questions - 11/27/2007 11:50 PM
OCR99
Score: 100
Status: offline
You can check with them i have one off each and there set to turn off at differant voltages
Rick
Hide Signatures
       Post #: 241
RE: A123Racing Battery Questions - 11/28/2007 1:18 AM
everydayflyer
Score: 100
Last Login: 9/15/2009
Status: offline
The LiPo Blinkey will not balance A123 packs unless you overcharge them.
If the Lipo version ,which was developed / marketed first worked correctly with A123s then Asto Flight would not have made the A123 ones.
Hide Signatures
(in reply to OCR99)
       Post #: 242
RE: A123Racing Battery Questions - 11/28/2007 1:56 AM
SS Pede
Score: 100
Status: offline
Thanks. So is there any other balancer that might do the trick, or would I have to just bite the bullet and have a different balancer for each battery type?
Hide Signatures
(in reply to everydayflyer)
       Post #: 243
RE: A123Racing Battery Questions - 11/28/2007 2:53 AM
SinCityJets
Score: 105
Last Login: 11/8/2009
Status: offline
They need to incorporate a switch that will allow it to do both. But, why buy one, when you can get two for twice the price!
< Message edited by SinCityJets -- 11/28/2007 2:54 AM >
Third Annual Sin City Jets Rally 2009 November 5-8 http://www.sincityjets.com/events.htm
U.S. Importer for evoJet Booster Engines
U.S. Importer for Lambert Kolibri Nano-Turbines
Hide Signatures
       Post #: 244
RE: A123Racing Battery Questions - 11/28/2007 4:23 AM
everydayflyer
Score: 100
Status: offline
quote:
ORIGINAL: SS Pede
Thunder Power Smart Balancers work well for both LiPolys and A123. They balance LiPos to + /- 0.005 or 0.01 total extreme inbalance and balance A123 to within + /- 0.015 or 0.030 total inbalance.
Charles
Hide Signatures
       Post #: 245
RE: A123Racing Battery Questions - 11/28/2007 1:57 PM
dick Hanson
Score: 100
Status: offline
Shirley -you can get closer than that -----
I am watching you
Libby
Hide Signatures
       Post #: 246
RE: A123Racing Battery Questions - 11/28/2007 7:32 PM
everydayflyer
Score: 100
Status: offline
I am unaware of any LiPoly balance which is better than 0.01 for a 2S-5S or 2S-10S pack.
My TP Smart balancers are closer than my Blinky,Vampower and ,Hyperion LBA6 .
They also balance closer than my FMA CellPro 4 , Balance pro HDand my DN Power chargers.
TP Smart balancers only balance A123 to within 0.03 due to the simple fact that they are two stage balancers and the normal fully charged 3.6 volts per cell of the A123s is not high enough to get them into their high precesion range. I have always felt that 0.30 is more than good enough for A123 cells.
Charles
Hide Signatures
(in reply to dick Hanson)
       Post #: 247
RE: A123Racing Battery Questions - 11/28/2007 8:18 PM
SS Pede
Score: 100
Status: offline
Good info everydayflyer, thanks again. Do you have Thunder Power taps on your A123 packs, or do you use some sort of adapter?
By the way, it seems that the Hyperion LBA10 can do A123 as well.
Hide Signatures
       Post #: 248
RE: A123Racing Battery Questions - 11/28/2007 10:38 PM
dick Hanson
Score: 100
Status: offline
quote:
ORIGINAL: everydayflyer
Charles
I wuz pulling yer leg-- anything at.03 is plenty good enough for me-
I am watching you
Libby
Hide Signatures
       Post #: 249
RE: A123Racing Battery Questions - 11/29/2007 12:33 AM
everydayflyer
Score: 100
Status: offline
quote:
ORIGINAL: SS Pede
Most of my A123 packs have PQ/Hyperion balancing leads on them.
yes I have many adapters for the TP Balancers. I had a Beta ver. of the TP 205 balancer before Thunder Power even had LiPolys with balancing leads on them.
I have heard that about the LBA10 and I had some input into its' firmware but never seen one in person.
Charles
Hide Signatures
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.234RCU1
