Kraeuterbutter -> RE: A123Racing Battery Questions (2/24/2007 1:38:45 PM)
sorry for asking about a post so long ago: @batfish wrote: quote:
Nightshift, I'd recommend two of the 2s1p 2300 packs. They will give you the same performance - no more worrying about which pack is the "best" pack. As with other Lithium technologies, these batteries have an extremely low self-discharge rate so you don't have to worry about peaking them right before racing. You can even charge them a couple days before the race and not notice any decrease in the battery's performance. The A123Racing packs also shouldn't heat up during a 5-minute race, and can be put directly onto the Hypersonic charger to be freshly charged again in about 10-15 minutes. If they happen to get a little warm, you may want to let them cool for a few minutes before charging them. You can always have one pack charged while using the other, so you should never be out of business. hmm. iam wondering about: "charge them a couple days before the race and not notice any decrease in the battery´s performance" i have made other experiences! i use the FePo4 as 4s1p in my heli and 5s1p in another heli.. it makes a significant difference when the batts are charged and what temerature they have.. batts charged (8A current), flown after charge... medium Power batts charged again (8A current) without any "let the batts cool down" after they came warm out of the heli, charged within 15min and used emidiatly after charge (around 30°C) - better performance batts charged again (8A) and flown AT THE NEXT day (so 12 hours) resting --> worst power result: the voltage is at least 1volt lower (in the 4s pack) then when used imidiatly after charging and the batts are warm! i have now found this tests in a german forum: batts at 20°C [img]http://www.rc-network.de/forum/attachment.php?attachmentid=59139&d=1170621501[/img] and batts heated to 40°C [img]http://www.rc-network.de/forum/attachment.php?attachmentid=59142&d=1170621592[/img] thats a not too small difference !!! can be significant for racing !
