RE: A123Racing Battery Questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> RE: A123Racing Battery Questions
Page: <<   < prev  2 3 4 5 6 7 [8] 9 10 11   next >   >>
Login
RE: A123Racing Battery Questions - 4/3/2007 1:16:21 AM
SS Pede
Status: offline
I see that A123 revealed new packs with a new form factor at RCX 2007!!! I'm eager to get more info...though they're probably very similar except for shape.
(in reply to dick Hanson)
       Post #: 176
RE: A123Racing Battery Questions - 4/4/2007 7:51:41 PM
SS Pede
Status: offline
Maybe Brian can shed a bit of light on the details of these new packs...like prices, when they'll be available, that sort of thing.
(in reply to SS Pede)
       Post #: 177
RE: A123Racing Battery Questions - 4/5/2007 12:59:10 AM
Red Scholefield
Status: offline
It will be interesting to see if they show up at Toledo. IT should tell us if they are serious about the electric flight market or not. Heard a rumor today that they had signed an exclusive with a major distributor. LIST PRICE OF SINGLE CELLS $19.95. WHICH TELLS ME THEY ARE NOT SERIOUS! But then they may know the market better than I do and realize that there are few in the hobby today that have the expertise to tear a DeWalt pack down and salvage the cells for $10-12 each. Maybe a new cottage industry opportunity here.
< Message edited by Red Scholefield -- 4/5/2007 1:01:14 AM >
_____________________________
Red S. AMA 951
R/C Battery Clinic
www.rcbatteryclinic.com
       Post #: 178
RE: A123Racing Battery Questions - 4/5/2007 1:09:38 AM
RC Accessory
Status: offline
Red, it is true. Go to www.horizonhobby.com and search for A123. $19.95 per cell.
Evan
(in reply to Red Scholefield)
       Post #: 179
RE: A123Racing Battery Questions - 4/5/2007 1:34:56 AM
dick Hanson
Status: offline
that list price is a bit of a surprise ---
I am now using the 2 cell packs, as rcvr packs (as well as using 4 cell packs in an electric model)
I make the rx pack by adding a std heavy duty JR pigtail- (all three wires ) and some heatshrink. I converted one pack from the two wire pack I got from RC Accessory. I just HAD to see if balancing was really req'd
I access em thru a JR charge plug/switch -- which accepts a JR female plug, adapted to a CellPro charger pigtail
It could not be easier or more simple - I recharge or check whilst refueling the gas tank on my 33% /42% or 27% gassers
the big gasser gets two packs simply because it has dual switches in place and 5 more ounces on 40 lbs means nada.
It is really handy to plug in and see "remaining is 80% charge " on the Cell Pro screen then the thing is charged up again shortly after refueling .
no friggen regulators either --
One other thing-- waiting for final balancing is really not worth the delay just as soon as you see 100% --
go fly but rebalance if you want to --
I also got one of the Dapter chargers for my ASTRO super 12
this is really slick - I use the "goose mode" and up comes the voltage --and STAYS up! big surprise. They should call it the Viagra mode.
My airyplanes is all changing to 123 cells.
< Message edited by dick Hanson -- 4/5/2007 1:45:02 AM >
I am watching you ----
Libby
(in reply to RC Accessory)
       Post #: 180
RE: A123Racing Battery Questions - 4/5/2007 2:36:00 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: RC Accessory
Evan
Amazing when there are a dozen DeWalt 36 volt packs on e-Bay right now at a max cell cost of $15 including shipping. Making your own packs from these is SO easy a cave man could do it. You can come up with a couple 4S packs without having to solder between the cells, just add the leads and balance connector of your choice. Make up packs using the MEC power tube concept with the other two cells - buy two DeWalt packs and end up with 5 4S packs for under $300. I've been flying the A123 packs since June - and they are fantastic in my 40 size electric conversions.
Red S. AMA 951
R/C Battery Clinic
       Post #: 181
RE: A123Racing Battery Questions - 4/5/2007 5:08:13 PM
BTerry
Status: offline
These cells are $15.50 each from MEC, but they don't have solder tabs (set up for the Power Tube). I think we will see a lower price from Horizon eventually, but they don't like to undercut their LHS customers.
       Post #: 182
RE: A123Racing Battery Questions - 4/10/2007 2:26:40 PM
carbonater55
Status: offline
II am confused. Hobbico said they thought that the 2- 2 cell 7.4 volt batteries would be needed to operate this plane. But that would be 1 volt short of the 8.4 volt pac's they reccomend.
Looking over these specs. what would you reccomend?
SPECIFICATIONS
Stock Number: HCAA12**
Wingspan: 63 in (1600 mm)
Wing Area: 709 sq in (45.7 dm2)
Weight: 6-6.5 lb (2720-2950 g)
Wing Loading: 19-21 oz/ft2 (59-64 g/dm2)
Length: 53 in (1345 mm)
Includes: Futaba® 4EXA 4-channel computer radio w/R168 receiver and 3 servos, 42 mm brushless out-runner motor, Great Planes® ElectriFly 45A brushless ESC
Requires: (2) 7-cell 8.4V 3000 mAh NiMH battery packs (GPMP0355) OR (2) 7.4V 3200mAh 20C discharge batteries with balance (GPMP0622), Dual Peak Charger (HCAP0255
(in reply to A123 Racing)
       Post #: 183
RE: A123Racing Battery Questions - 5/26/2007 7:00:36 PM
Bob93447
Status: offline
Brian,
Is it possible to use the entire Dewalt 36v power pack in a model application? I'm thinking of using the DeWalt power pack in my Seawind on the assumption that it might be a bit safer if dunked.
Bob
93447
       Post #: 184
RE: A123Racing Battery Questions - 5/31/2007 4:15:23 PM
DLS II
Status: offline
Batfish, I'm setting up a TC with a 10.5 and a MEC SPT A123 2S2P pack. Will the gearing up trick work here to? I hope so! One battery pack race all day! A123Racing, will the Turbo module work with 10.5 & 13.5 brushless? Thanks, Don
< Message edited by DLS II -- 6/2/2007 2:46:17 PM >
(in reply to Bob93447)
       Post #: 185
RE: A123Racing Battery Questions - 6/9/2007 5:13:02 PM
meatpuppet
Status: offline
Can someone post a pic of these batteries in comparison to a thunder power 3 cell lipo. I still am not sure about their actual size. How large is each cell?
thanks
       Post #: 186
RE: A123Racing Battery Questions - 6/9/2007 7:03:32 PM
guver
Status: online
They are a C size battery.
(in reply to meatpuppet)
       Post #: 187
RE: A123Racing Battery Questions - 6/9/2007 10:18:17 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: guver
Yes, same as C diameter 1.024 inches, but some what longer than a C cell. A123 is 2.62 inches, C is 1.97 inches
Red S. AMA 951
R/C Battery Clinic
(in reply to guver)
       Post #: 188
RE: A123Racing Battery Questions - 6/9/2007 11:03:53 PM
guver
Status: online
Wow, I didn't know that, Thanks for the correction.
That brings up another. Why is it that can only get 2300 capacity in this size? If it was a nimh battery it would have 6000 + at far less voltage though.
< Message edited by guver -- 6/9/2007 11:04:12 PM >
