A123 Racing
Joined: 8/25/2006 From: Hopkinton, MA, USA Status: offline
Hello People, I've got more answers to your questions. Thundermaxx, do these batteries not have an internal cutoff like others? Low voltage cutoff should not be of great concern to the average user. We recommend a cut-off voltage of 2V / cell but they are tolerant of over and under voltage. The working range for the cells is: Charge to 3.6V / cell and discharge to 2.0V/cell. The tolerable range is 4.2V to 1.0V / cell. These characteristics can be applied to the packs as long as the individual cells in the pack remain balanced. For example a 2S1P (6.6V) pack can be brought up to 8.4V provided that it is not kept at that voltage for a long duration of time, and that the pack is balanced properly. If the cells in the pack were not balanced you could seriously damage your pack at 8.4V. If one of the cells was measuring 3.6V the other would be at 4.8V. In this situation it is certain that you would shorten the life of the pack, and very possible that you would permanently damage it. Even though the batteries are tolerable of 4.2V / cell we do not recommend that they be charged on a 4.1/4.2V Lithium charger because the charger will maintain the pack voltage at 4.2V for several minutes, which will degrade the life of your pack. Also because those chargers do not monitor and balance the cells during charging it is very possible to permanently damage the pack. DougE, will your battery work with Novaks now. Also thinking about getting a Mamba Maxx. Hello DougE, we have people out there running our batteries in their 1/10 scale trucks and cars. I have not heard or seen any problems with them yet. I reviewed the Mamba Maxx manual (available at the manufacturers website) and that should work well also. Please note that the 2S2P battery is a bit larger than a typical NiMH pack that most people are used to. You may need to modify your chassis / battery strap down in order for it to fit. The 2S1P is narrower but still a bit taller than a typical pack, but most people do not have much difficulty in finding a way to keep it in the chassis. LeeJay, how will we address limitations of our batteries. Hello LeeJay, because of our single cell size (26mm diameter x 65mm) we limited in some aspects. The solution to this is research and development. We are always looking for the next best thing. Time will be the solution to the limitations you mention. In the mean time we believe that people can certainly make use of the: Power; 30C continuous 60C pulse. Safety; No thermal runaway / fire. Mechanical durability; impact resistant laser welded aluminum canister, and up to 1000 cycles. Electrical durability, voltage tolerant of 1V to 4.2V / cell. Quick Charge, As little as 15 minutes with the Sonic Charge system. The pack availability can be changed based on user feedback. I urge you to let us know if there is something else you are looking for. Nightshift: Interest in racing A123s Hello Nightshift, sounds like you have a nice setup there. I am running the sphere with a neo 3 star in my touring car. With a 2S1P battery, and it really moves. Batfish has some great input for your questions. He has been racing these batteries for a little while now. The 2S1P certainly would be the best fit for you. It is small (about 28mm Dia x 132mm) and lightweight (less than half the weight of a NiMH). They charge in about 15 minutes, and I expect you would see run times equivalent to Batfish’s. As long as you don’t require a battery swap sooner than 15 minutes a 2S1P starter kit (2 x 2S1P battery and a charger) should suit you well. Thanks again for all the questions, please keep them coming.
