RE: A123Racing Charger Questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> RE: A123Racing Charger Questions
Page: <<   < prev  1 [2]
Login
RE: A123Racing Charger Questions - 9/16/2007 3:43:29 AM
lifewater
Status: offline
I apologize for going a bit offtopic here.. but how exactly do you charge these? I've only used AC chargers before... DC is a bit new to me. DO you just use Car batteries or is there something else you use?
(in reply to SS Pede)
       Post #: 26
RE: A123Racing Charger Questions - 9/16/2007 5:34:41 AM
snellemin
Status: offline
Well, you could use a cheap car battery charger from walmart. Or you can buy a 12 volt power supply that puts out more then 10 amps, or even better by converting a computer power supply for use as the power source.
_____________________________
check out www.Hamdrl.com
Snelle-RC, A123 Racer
(in reply to lifewater)
       Post #: 27
RE: A123Racing Charger Questions - 9/16/2007 6:09:22 PM
SS Pede
Status: offline
I use this power supply here: http://www.radioshack.com/product/index.jsp?productId=2103960&cp=2032056&f=Taxonomy%2FRSK%2F2032056&categoryId=2032056&kwCatId=2032056&kw=power+supply&parentPage=search
(in reply to snellemin)
       Post #: 28
RE: A123Racing Charger Questions - 9/26/2007 4:37:38 AM
CLofland
Status: offline
I'm really new to this. Looking for a DC supply for the Sonic charger. Plug and play.
Eventually I want to run TWO Sonic chargers, so I can recharge two packs at once.
Would this unit be able to supply 12V to two Sonic charger's at once without tripping a fuse all of the time?
http://www.competitionelectronics.com/pages/pwr_supply.html
Thank you for any input/help. Other ideas are welcome.
(in reply to A123 Racing)
       Post #: 29
RE: A123Racing Charger Questions - 9/26/2007 2:25:58 PM
snellemin
Status: offline
quote:
ORIGINAL: CLofland
It's cheaper to use a converted computer power supply. Good ones put out more amps then the link you provided. Anyways, I put 2 batteries in parallel and charge them from a single charger. Takes twice as long ofcourse, but I really don't mind.
(in reply to CLofland)
       Post #: 30
RE: A123Racing Charger Questions - 9/26/2007 4:16:05 PM
A123 Racing
Status: offline
Hey CLofland,
The power supply you have specified will work with two of the Sonic Chargers, no problem.
Also note that a cheap car battery charger from Walmart, or anywhere else for that matter will not work with the Sonic Charger. The car battery chargers are not a regulated 12V they are very dirty (electrically speaking) and can cause damage to the charger.
Let me know if you have any more questions.
Power . Safety . Life
Brian
       Post #: 31
RE: A123Racing Charger Questions - 9/26/2007 5:28:17 PM
CLofland
Status: offline
What about charging from a car? ie. directly off of the battery or via a cigarette lighter adapter?
       Post #: 32
RE: A123Racing Charger Questions - 9/26/2007 5:33:12 PM
CLofland
Status: offline
quote:
ORIGINAL: snellemin
Well, I do actually have PC power supplies laying around. They are mostly 200W, which I think is 15Amp? Since they are free to me, that would be an easy solution.
What does "converted" mean though? Can someone explain EXACTLY, as in in detail, what it takes to "convert" a PC power supply to do this?
Also, if you could explain what the purpose of each modification is, that would help a lot.
Thanks.
       Post #: 33
RE: A123Racing Charger Questions - 9/26/2007 5:36:16 PM
A123 Racing
Status: offline
Hey CLofland,
There is no problem charging off of a car battery. I would not recommend the cigarette lighter though as they sometimes have a 5A fuse built into them. If you search online you should be able to find clear directions on how to modify your PC power supply, typically it is as simple as jumping a couple of wires. If it is 200W it may just be enough to power two chargers (depending on the efficiency of the supply)
Brian
       Post #: 34
RE: A123Racing Charger Questions - 9/28/2007 6:08:59 AM
JettPilot
Status: offline
I have seen some tests to indicate that A123 packs balance themselves over time. I have also read that A123 cells were not damaged by small voltage differences charging non balanced packs. After all, we never balanced NICAD and NIMH packs. Is balancing of A123 packs really needed ??
One more question, 10 amps seems like a LOT of current. Any advantage, or disadvantage to charging A123 cells at 1 amp or even 250 mA ???
JettPilot
THE TRUTH ABOVE ALL ELSE...
       Post #: 35
RE: A123Racing Charger Questions - 9/28/2007 3:25:14 PM
A123 Racing
Status: offline
Hello JettPilot,
10A is a lot of current, that is one of the primary advantages to our cells technology. There is no advantage to charging with a lower amp rating, our packs are spec’d to cycle up to 1000 times with the 10A charge current. The only disadvantage to charging at 1A or even 250mA is that it will take two hours or more to charge the pack.
Brian
(in reply to JettPilot)
       Post #: 36
RE: A123Racing Charger Questions - 7/20/2008 4:05:36 AM
scoobi
Status: offline
hello. need help i bought 2 hypersonic chargers and 4 9.9 batterys and both chargers keep blowing fuse on the input 12 side 1 charger is brand new never got to use bought off ebay and they have not answer me yet is there something i can do to send both back to a123 factory. both doing the same thing 1 has charged about 4 batterys the other brand new. thanks
       Post #: 37
Jump to:
