A123Racing Hypersonic Turbo Questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> A123Racing Hypersonic Turbo Questions
Page: [1] 2   next >   >>
Login
A123Racing Hypersonic Turbo Questions - 8/25/2006 3:42:51 PM
A123 Racing
Status: offline
Hello RC Universe, please use this forum for any questions regarding the Hypersonic Turbo system.
Brian
       Post #: 1
RE: A123Racing Hypersonic Turbo Questions - 8/30/2006 3:09:55 AM
guver
Status: offline
Hi, thanks for being here.
What is price for turbo booster?
Are they seperate units for differing voltage ?or
does one unit do all voltage ranges?
If not what is the range and price for each unit? thanks
_____________________________
This is an apostrophe ''
(in reply to A123 Racing)
       Post #: 2
RE: A123Racing Hypersonic Turbo Questions - 8/30/2006 5:06:25 PM
A123 Racing
Status: offline
Hello Udud,
To answer your question. The turbo box is a single module that works with all of our batteries. The module is sold with our batteries in the Hypersonic kits, go to www.a123racing.com for purchasing information. It is not currently sold individually mainly because it is not recommended for use with other batteries. The turbo module draws high amounts of current which our batteries are capable of delivering. Use with other packs may damage the Turbo module and/or your other battery.
Please let me know if you have any other questions.
Brian
(in reply to guver)
       Post #: 3
RE: A123Racing Hypersonic Turbo Questions - 8/30/2006 5:16:38 PM
guver
Status: offline
Ok, Thanks, what is the voltage range (input and output) for each unit?
I think if I understand correctly it is the same module for the 7.2-10.8 and if I got that particular unit it would also work for 3S batts and go up to 14.4?
< Message edited by U-dUd -- 8/30/2006 5:20:40 PM >
       Post #: 4
RE: A123Racing Hypersonic Turbo Questions - 8/30/2006 5:52:28 PM
Bob93447
Status: offline
Brian,
Your batteries seem to operate at a slightly lower voltage than conventional Lithium Poly batties? I assume that the mandatory cut-off voltage is also lower. What is it? If I am configuring a system for aircraft operation that would normally be 6S, do I need to add a cell to work with your system?
Bob
(in reply to guver)
       Post #: 5
RE: A123Racing Hypersonic Turbo Questions - 8/30/2006 6:52:29 PM
A123 Racing
Status: offline
Hello Udud,
You have the voltages figured out. The 2S packs can output 7.2V-10.8V when the turbo module is used. The 3S pack can output 10.8-14.4 when the boost module is used. It is the same boost module, when you plug in the battery it auto senses what type it is, all you have to do is choose the voltage setting.
Bob, I answered your question in the battery thread.
Brian
(in reply to Bob93447)
       Post #: 6
RE: A123Racing Hypersonic Turbo Questions - 8/30/2006 7:13:41 PM
guver
Status: offline
Thanks, man . Now I have to find a partner who needs the cells, lol. I want the booster only.
       Post #: 7
RE: A123Racing Hypersonic Turbo Questions - 8/31/2006 5:55:12 PM
gniessen
Status: offline
How is the cut-off handled? My concern is that if the Turbo module cuts off there will be no power to the ESC, which means no power to the receiver, which means crash. Even if I program a cut-off in the ESC it wouldn't cut in as long as the Turbo module is maintaining the programmed voltage. This seems problematic.
Gordon
Electric (Clean, Quiet, Smart)
(in reply to guver)
       Post #: 8
RE: A123Racing Hypersonic Turbo Questions - 8/31/2006 6:00:41 PM
guver
Status: offline
The turbo is a voltage booster, not a voltage cut-off. The voltage Brian is talking about is output voltage I think and is the same or higher than input voltage.
A related question, if 12 volts were supplied would the output still be 14.4 max? thanks.
(in reply to gniessen)
       Post #: 9
RE: A123Racing Hypersonic Turbo Questions - 8/31/2006 6:58:41 PM
gniessen
Status: offline
If the Turbo Booster doesn't have a voltage cut-off it will seriously damage the batteries when the battery drops below the threshold and the output is still maintained. You would need some other device in between the battery and Turbo to monitor it.
Gordon
(in reply to guver)
       Post #: 10
RE: A123Racing Hypersonic Turbo Questions - 8/31/2006 7:31:46 PM
guver
Status: offline
These cells are supposed to be able to take that ok. They also fall off voltage very fast and with the booster it will make this condition even worse (better). I would love to hav batts like that, just like running out of gas. I'm not sure that it is best for them to kep being discharged low, and a lcv may also be a great idea.
       Post #: 11
RE: A123Racing Hypersonic Turbo Questions - 9/2/2006 7:36:08 AM
clive45
Status: offline
It may seem a stupid question but how do you get 10.8v from a 2S(7.2v) battery at the current draws possible. How can the booster make something from nothing.
FLY SAFE AND ENJOY
(in reply to guver)
       Post #: 12
RE: A123Racing Hypersonic Turbo Questions - 9/2/2006 8:51:28 AM
guver
Status: offline
The voltage is stepped up and therefore the current must also be stepped up. The current capacity at the higher voltage is less than it is at lower voltage, but if you are not even close to limit then it works fine.
The total power shall remain the same (less a small loss)
< Message edited by U-dUd -- 9/2/2006 8:53:51 AM >
(in reply to clive45)
       Post #: 13
RE: A123Racing Hypersonic Turbo Questions - 9/8/2006 5:26:53 PM
newflyermx
Status: offline
Bryan:
I Have a Multiplex Easy Star powered with a Warp 4 4 turn, Castle Creations Phoenix 25 ESC, and APC´s 6*4e Prop.
Do you recomend the Turbo System for this configuration?
2S1P or 3S1P?
Does the Turbo System Includes the Charger? Can you charge this batteries with a Hobbico Accu Elite Pro Charger / Cycler?
Do you need a balancer for this packs?
Thank you
(in reply to guver)
       Post #: 14
RE: A123Racing Hypersonic Turbo Questions - 9/10/2006 9:47:36 PM
ShellDude
Status: offline
Hi Brian,
What is the voltage and amperage tolerance of the "Turbo" module? Specifically, what would happen if I ran two of your 2300 3S packs in series, in essence (6s1p) through the module?
< Message edited by ShellDude -- 9/10/2006 9:48:39 PM >
(in reply to newflyermx)
       Post #: 15
RE: A123Racing Hypersonic Turbo Questions - 9/11/2006 4:10:17 AM
Batfish
Status: offline
quote:
ORIGINAL: ShellDude
Hi Brian,
ShellDude,
I'm not an A123Racing representative, but I've learned quite a bit about them through working with Brian (for real-world results in cars/trucks) over the past couple months.
The turbo box is not designed to handle the kind of load you're asking about. The way to handle that would be with a turbo box on each battery pack, then wiring those two assembled units in series.
I haven't actually used a turbo box myself (I've been able to use the native voltage by just upping pinion teeth by a couple), but I should be testing one for them soon in the truck arena.
It sounds like you've had a similar success in your helis to that I've had in my cars/trucks. Great to hear!
______________
Joe
(in reply to ShellDude)
