SS Pede -> RE: A123Racing Hypersonic Turbo Questions (10/31/2006 4:26:15 PM)
I'm comparing raw off-the-line acceleration with the turbo box vs. without the turbo box. I hear the packs are punchier than NiMH without the turbo, but lack the top speed of a good NiMH pack. This makes sense since they're low-IR lithium cells, but they have a lower voltage. So, if adjusting gear ratios didn't satisfy me, I might want to use the turbo box to gain my top speed back by getting a full 7.2 volts out of the pack. BUT...when increasing voltage/top speed with the turbo box I would not want to hurt my wheelie-popping ability too much. Put another way: Whether I adjust top speed with the turbo module or with a gearing change, I do not want to hurt bottom-end grunt too much. If I can re-gear and get the performance I want without the turbo, that's awesome because it eliminates weight and improves run time. If I do have to resort to using the turbo box, I don't want starting torque to suffer. Thanks for the input, I hope this has cleared things up. [:)]
