Stickbuilder
FL, USA Status: offline
A note of update....I now have the short kit (provided by Joe) and have the tail group, the cabanes, and the wing cores. I am still waiting for the other formers, but have the wood to cut them myself. I have purchased the new balsa for the fuse sides (the fuse short kit is pure plywood and will prove to be very heavy). I will use the supplied sides as a pattern, and as a fuse doubler to just behind the wing saddle. I have also purchased the stringers, spar material and the leading and trailing edge material. I intend to set the servo tray up to utilize interior mounted servos since Jim's full scale did not have servos hanging out under the tail. I will set the rudder up for pull-pull, and the elevators up for twin servos. Gordon was nice enough to prevail on Mike Dunphy to provide the wing cores (thanks Mike) and is going to send me a cowl to finish. We are going to need a tail wheel set, a pair of 4" wheels and wheel pants. I am going to set the engine box to use a G-62, since there should be an opportunity to get one of these at a lower price than say a DA-100 or equivelant. A G-80 twin would really be nice here. The tank box will have adequate space for mounting the smoke tank. This is a fairly large box, but you can still run out of room quickly. Any help would be appreciated at this point (getting our hands on some parts) Bill, AMA 4720 WACO Brotherhood #1
_____________________________
It's easy, just glue all the pieces together, and sand off everything that doesn't look like an airplane.
