RE: 1/8th scale B-1B
Tower Hobbies
Logged in as Guest
Users viewing this topic: fw190pilot
    Search This Thread
Printable Version
Digitech/Pro-Lynx landing gear for Falcon 120 - RTF
Seller:  digitech
Details:   $399.00   |  3/18/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: 1/8th scale B-1B
Page: <<   < prev  33 34 [35] 36 37 38 39 40 41 42   next >   >>
Login
RE: 1/8th scale B-1B - 8/28/2009 10:11 PM
Hustler58
Score: 100
Last Login: 3/21/2010
Status: online
quote:
ORIGINAL: DCM
quote:
ORIGINAL: Hustler58
OK ,just had a conversation and the event is a ''GO'' for October 22-25. AMA has been contacted, they are aware of the test flight and have given specific rules on how we can do it and not interfere with the AMA rules. The event will be shut down a certain times if the B-1B is ready to fly. Those times ''WILL NOT'' be covered under AMA ! Which is good because we have some other special things planed that won't happen at any other event. So everyone make your plans and come ready to have some FUN ! I will post Hotel and other info that is needed next week.
Tater peelin contest?
David
I will have taters there just for you! Don't cut yourself !
_____________________________
http://www.b1modelproject.com/
Hide Signatures
(in reply to DCM)
       Post #: 851
RE: 1/8th scale B-1B - 8/29/2009 1:58 AM
yeahbaby
Score: 100
Status: offline
I musta missed the tail section video. damn that thing is sweet!!!
evoJet Booster Factory Pilot
"Don''t let the beard fool you. He''s a child!"
Hide Signatures
(in reply to Hustler58)
       Post #: 852
RE: 1/8th scale B-1B - 8/30/2009 12:08 AM
ps2727
Score: 100
Last Login: 3/20/2010
Status: online
Butch,
This is the configuration for flying halffast right?
Paul
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to yeahbaby)
       Post #: 853
RE: 1/8th scale B-1B - 8/30/2009 12:27 AM
invertmast
Score: 100
Status: offline
quote:
ORIGINAL: ps2727
Butch,
Paul
half-fast.. lmao
Thomas W.
Euro-sport Evo. NextD Rave 450, Scratch built 1/7 F-14D Tomcat
Hide Signatures
(in reply to ps2727)
       Post #: 854
RE: 1/8th scale B-1B - 8/31/2009 8:59 PM
JKEpps
Score: 100
Status: online
My turn...
New video posted as of 48 minutes ago! http://www.youtube.com/watch?v=Bue-uD_NSUg
Hide Signatures
(in reply to Seraphim77)
       Post #: 855
RE: 1/8th scale B-1B - 9/1/2009 10:35 PM
Hustler58
Score: 100
Status: online
Recived the wing accuators today. They have 6" of travel and 150#'s of force. 15sec for full travel. we only need 4.625 of travel.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to JKEpps)
       Post #: 856
RE: 1/8th scale B-1B - 9/6/2009 6:34 AM
bambam102
Score: 100
Status: offline
Awesome project! Question.
Ive heard that long servo leads are really bad news for radio control. how do you avoid those problems on such a huge project?
Hide Signatures
       Post #: 857
RE: 1/8th scale B-1B - 9/6/2009 7:16 AM
invertmast
Score: 100
Status: offline
quote:
ORIGINAL: bambam102
what do you mean "really bad"? the electricity running thru the wires does pose as a source for electrical interference, but twisting/braiding the wires or running ferrite rings or a shielded cable eliminates more of the electrical interference issues.
Thomas W.
Hide Signatures
(in reply to bambam102)
       Post #: 858
RE: 1/8th scale B-1B - 9/6/2009 10:42 AM
bambam102
Score: 100
Status: offline
thats exactly what I meant. electrical interference. thanx.
Hide Signatures
(in reply to invertmast)
       Post #: 859
RE: 1/8th scale B-1B - 9/6/2009 7:07 PM
Molar mender
Score: 100
Status: online
That is the key term, electrical interference. Whether it be spurious emissions from inside sources, like the pump, ECU, etc. or electromagnetic emissions from outside sources like other transmitters. On my 1/12th scale B-1B project, my longest servo run is from the rudder which is 12' from the receiver. Bob's will be a third again longer in the 1/8th scale depending on where he mounts his receivers.
I personally am using 18 ga shielded/grounded wire from the servos to the ElectroDynamics Pow'R Bus Pro which optically isolates the servos from the receivers. It allows a separate battery source to power the servos and allows a dual receiver set up without any electrical interference getting back to the receivers. This system is what I have used for a number of years and works for me. There are any number of ways to accomplish eliminating electrical interference. Smartfly Power Expander, Duralite PowerBox or the Weatronics system all accomplish the same thing and that is to keep out electrical interference and allows for system redundancy.
I am sure Bob has taken this all into consideration and we will hear shortly how he will accomplish this task and what he will be using.
Go Bob!
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Molar mender -- 9/7/2009 1:54 AM >
Eliminate skin cancer
Protect and Inspect
Hide Signatures
       Post #: 860
RE: 1/8th scale B-1B - 9/7/2009 1:35 AM
Hustler58
Score: 100
Status: online
Finishing up the spar and bulkheads. We Have KIDNEYS !
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Molar mender)
       Post #: 861
RE: 1/8th scale B-1B - 9/7/2009 1:46 AM
invertmast
Score: 100
Status: offline
haha.. looking goood... im gettin excited
Thomas W.
Hide Signatures
       Post #: 862
RE: 1/8th scale B-1B - 9/7/2009 3:23 AM
drdoom
Score: 115
Status: offline
One way they intend to avoid long servo leads, is multiple receivers. Somewhere I believe they may be thinking 4.
sounds like a good Idea to me. Less heat build up from current for each receiver.
AMA #70046 Jet Junkie!
Hide Signatures
       Post #: 863
RE: 1/8th scale B-1B - 9/10/2009 5:56 PM
Hustler58
Score: 100
Status: online
Ya'll are gettin slow ! It's been up for 2 hours and no one has posted it ! http://www.youtube.com/watch?v=CrS0W2uuP2o&feature=channel_page
Hide Signatures
(in reply to drdoom)
       Post #: 864
RE: 1/8th scale B-1B - 9/10/2009 6:40 PM
ianober
Score: 100
Status: offline
Well its been so long since the last post we were all sleeping!!!!
Hide Signatures
       Post #: 865
RE: 1/8th scale B-1B - 9/10/2009 7:24 PM
Hustler58
Score: 100
Status: online
quote:
ORIGINAL: ianober
LOL ! Your just spoiled !
Hide Signatures
(in reply to ianober)
       Post #: 866
RE: 1/8th scale B-1B - 9/10/2009 7:29 PM
ianober
Score: 100
Status: offline
I think thats the case for sure Butch. Bob is finally showing signs of being human! I hope he takes some good time off to recharge nicely and dive right back in!
Hide Signatures
       Post #: 867
RE: 1/8th scale B-1B - 9/11/2009 3:16 AM
izz4u2mm
Score: 100
Last Login: 3/15/2010
Status: offline
Hello yeah I would like to see some videos made of the jets you are going to fly in Texas. I wouldn't mind seeeing you fly that FW190 you showed us yeah that would be nice too...did I leave anything out hahahahaha.
Good flying and have a great time out there.
Manny
Manny Monroy
izz4u2mm@verizon.net
Hide Signatures
       Post #: 868
RE: 1/8th scale B-1B - 9/13/2009 7:44 PM
Hustler58
Score: 100
Status: online
New video! http://www.youtube.com/watch?v=2VT8ATMIoRs&feature=channel_page
Hide Signatures
(in reply to izz4u2mm)
       Post #: 869
RE: 1/8th scale B-1B - 9/13/2009 8:52 PM
yeahbaby
Score: 100
Status: offline
good to meet B1 Bob and Dad. got to see the fuse and gear in person before the rain really started coming down......stunning!!!
Hide Signatures
       Post #: 870
RE: 1/8th scale B-1B - 9/13/2009 10:10 PM
Jason233
Score: 100
Last Login: 2/2/2010
Status: offline
Hustler58,
Hey I just ran across this thread as I was searching for info to build my own b1, all I can say is this project is nothing short of incredible......im speechless your plane is the largest most accurate scale model I have ever come across in my life long love of modeling. Sorry to bother you, but in short I would assume that you used some sort of 2d/3d CAD model in your design's infancy and I was actually just surfing the net trying to find an existing CAD model that I could sort of scale to my liking and customize as opposed to starting from scratch. I'm not the best at drawing all those curves yet I am going to school for engineering and my real passion is CAD and aircraft of all types. I currently have AutoCAD and AutoDesk Inventor, wasn't sure what program you used and if it could be converted for either my 2d, or 3d format. I also realize that you must have put many thousands of hours, sweat and tears into your baby, I know how that is. So I would most certainly be willing to compensate you for your service. I have a couple high output EDF's laying around and I was hoping to come up with sort of a B1 park flyer to go with them. If you would be willing to share your plans with me that would be awesome, but if you don't I certainly understand.
regards - Jason Perez
Hide Signatures
       Post #: 871
RE: 1/8th scale B-1B - 9/14/2009 8:51 PM
Jason233
Score: 100
Status: offline
hey Butch,
PM'd you back, thanks
Hide Signatures
(in reply to Jason233)
       Post #: 872
RE: 1/8th scale B-1B - 9/14/2009 8:53 PM
Jason233
Score: 100
Status: offline
from what i read online, it seems that I could open solidworks files if that's what you are using
Hide Signatures
       Post #: 873
RE: 1/8th scale B-1B - 9/15/2009 6:09 AM
izz4u2mm
Score: 100
Status: offline
Wow Bob just looked at the last video...man what a freaky accident . Sorry that happened and am Glad that no one got hurt man!! especially you guys.
Hope you can get reimbursed for all the damage done to everything that got jacked up . Wish you lotta luck and keep on trucking on the B1b .
Manny
Manny Monroy
Hide Signatures
       Post #: 874
RE: 1/8th scale B-1B - 9/15/2009 3:58 PM
Shok
Score: 100
Status: offline
yeah we almost had an incident in our trailer as well coming back from Waco.
It's odd because the further south you drive from Dallas, it seems like the people do not know how to get on a highway. They actually decelerate on the ramp.
That happened with a little white truck in the pouring rain. He decelerated while getting on, causing me to get on the brakes hard, which in turn made a car behind me veer into the left lane, which in turn sent a truck flying through the median and sliding in the mud.
Could have been a horrible accident.
Ronnie
Jetmach, JetCat Sales, KingTech Turbines
Laser-Design-Services
Hide Signatures
       Post #: 875
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.281RCU1
