RE: 1/8th scale B-1B
Tower Hobbies
Logged in as Guest
Users viewing this topic: tassos p, SDCrashmaster, Thommo
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: 1/8th scale B-1B
Page: <<   < prev  51 52 [53] 54 55 56 57 58 59 60   next >   >>
Login
RE: 1/8th scale B-1B - 11/16/2009 12:33 AM
rcyogi
Score: 100
Last Login: 3/19/2010
Status: offline
Ha ha ha, red hand works great!
Hide Signatures
(in reply to Seraphim77)
       Post #: 1301
RE: 1/8th scale B-1B - 11/16/2009 12:43 AM
theb1bman
Score: 100
Last Login: 3/18/2010
Status: offline
we mite us up another page of red hand followers
_____________________________
carbon fiber
Hide Signatures
(in reply to rcyogi)
       Post #: 1302
RE: 1/8th scale B-1B - 11/16/2009 12:44 AM
bcovish
Score: 116
Status: offline
"This user is on your "block" list and the message has been blocked"
This is great. When you hit the block button on a post, all of that persons posts are blocked and get the above message everytime he posts. And it applies to any post he makes on RCU no matter what thread. So everyone hit the block button on the idiot.
Bob-O
Austin TX
Hide Signatures
       Post #: 1303
RE: 1/8th scale B-1B - 11/16/2009 12:53 AM
SPLIT S
Score: 105
Status: offline
All bow and hail to the red hand - shop smart, shop s mart (for all of you Army of Darkness fans)
Now back to one killer B1....
Dan
Hi Dad, Doing anything? Want to go to the field?
Hide Signatures
(in reply to bcovish)
       Post #: 1304
RE: 1/8th scale B-1B - 11/16/2009 12:55 AM
invertmast
Score: 100
Status: offline
quote:
ORIGINAL: udet1918
Can anyone tell me what the block button does? It's located in the bottom of the post windows. Perhaps if everyone blocked a certain someone we would not need to read about perfection all the time!
Ron
Hey! just now noticed that button... its going to come in handy! WOOOOT!
Thomas W.
Euro-sport Evo. NextD Rave 450, Scratch built 1/7 F-14D Tomcat
Hide Signatures
(in reply to udet1918)
       Post #: 1305
RE: 1/8th scale B-1B - 11/16/2009 1:02 AM
LearnedInUk
Score: 100
Status: offline
That is a cool button!
Hide Signatures
(in reply to invertmast)
       Post #: 1306
RE: 1/8th scale B-1B - 11/16/2009 1:06 AM
rcyogi
Score: 100
Status: offline
OK enough of the red hand......where is the new video? I need my fix........Show me the video......what happen to the F16? Lets see the finish product......
Hide Signatures
(in reply to LearnedInUk)
       Post #: 1307
RE: 1/8th scale B-1B - 11/16/2009 1:33 AM
Dan M
Score: 121
Status: offline
nice
< Message edited by Dan M -- 12/3/2009 12:10 AM >
Be it an ARF , an RTF , or a Kit that took 2000 hours to complete , if you don''t FLY it , what Good is it ?
Hide Signatures
       Post #: 1308
RE: 1/8th scale B-1B - 11/16/2009 1:49 AM
bcovish
Score: 116
Status: offline
Ok Bob, that problem seems to be taken care of.
Now it's time for you to "GIVE US THE FINGER"
Bob-O
Austin TX
Hide Signatures
(in reply to Dan M)
       Post #: 1309
RE: 1/8th scale B-1B - 11/16/2009 2:49 AM
Hustler58
Score: 100
Status: offline
Wow ! That was easy ! I should have done that before now! I'm sorry to everyone ! Now I need to work on the White House ! HA ! Butch
http://www.b1modelproject.com/
Hide Signatures
       Post #: 1310
RE: 1/8th scale B-1B - 11/16/2009 2:58 AM
Mike Emilio
Score: 100
Status: offline
quote:
ORIGINAL: pilotdude57
So you want to block the person who was correct about the F-14 having washout, or the person who was wrong?
Geez, ,, I didn't want to say anything, , , , here's a clip from the factory drawing.
You guys can come to your own conclusions.
Pilotdude, , No offence intended guy, but you can see how you can get torn to shreds if you can't substantiate what you say. Hard facts are always better than some unverifiable conversation. The onis of substantiating what you say is up to you, not anyone else, or it just goes on being argumentative.
< Message edited by Mike Emilio -- 11/16/2009 12:25 PM >
Hide Signatures
(in reply to pilotdude57)
       Post #: 1311
RE: 1/8th scale B-1B - 11/16/2009 4:56 AM
rhallgarth
Score: 100
Status: offline
quote:
ORIGINAL: Hustler58
quote:
ORIGINAL: rhallgarth
quote:
ORIGINAL: Hustler58
quote:
ORIGINAL: theb1bman
Thanks my CG is with in the 10-17% wing out but as I sweep them back to make it fly with no up elevator trim the CG needs to be about 2 1/2'' behind that.
If I got what you told pilotguy I should use the wing angle of attack and or just anhedral to change the center of lift?
I'm not sure how the anhedral works but they put it in the full scale for a reason. The anhedral on the B-1 is 1.9 deg
Anhedral allows a plane to be more unstable in flight. It might sound weird but most combat aircraft have 0 anhedral or have some anhedral in wings. All modern combat aircraft are designed to be unstable in flight or less stable in spiral mode. Dihedral increases stability in spiral mode while anhedral increases instability. If the plane cannot perform drastic aerodynamic moves to avoid threats it is at a disadvantage. With anhedral a combat aircraft can twist/roll faster in a side slip or roll movement. The F-4 is a polyhedral aircraft because initial flight testing indicated some real nastiness with the flat wing design in flight. One wants the plane to be slightly unstable but not unflyable.
The anhedral in the swing wing has little to do with the stability with the wing forward. It has affect on the wing when it swings back. You have to look at the pivot piont and watch the wing rotate back and you will see how the wing twist/rotate. Which gives it a under camber affect like a delta wing.
That is incorrect. anhedral always affects the spiral mode of any combat aircraft or its roll rate. There is a book "Modern Combat Aircraft Design" by Klaus that clearly analyzes this and other issues used when designing modern combat aircraft. The anihedral allows the aircraft to bank faster even with the wings in standard configuration. With the Central Air data Computer in auto mode the leading edge slats and the flaps are used to increase lift and turn rates in combat as well as allowing much slower landings.
Hide Signatures
(in reply to Hustler58)
       Post #: 1312
RE: 1/8th scale B-1B - 11/16/2009 5:06 AM
rhallgarth
Score: 100
Status: offline
What is being done on this B1-B bomber IMHO is simply amazing. Bob and Butch have done an amazing design on this amazing aircraft and as a former Aerospace Engineer I do not see anything they have done that is even marginally questionable. The only question I have is how can I donate to this amazing project using PayPal.
Hide Signatures
(in reply to rhallgarth)
       Post #: 1313
RE: 1/8th scale B-1B - 11/16/2009 6:35 AM
Props4ever
Score: 105
Status: offline
Hey Bob, Butch guys where is the new video, nuff of this challatterr rest of you!!!.
It's amazing to see how this model stands on it's own gear!, keep bringing us what we most can't do for one reason or another!!.
Lets get back to Bob's shop.....
I do believe in KISS (Keep it simple silly). Where there is a will, there is a way.. Part of 1/12th Palmer C130 build group.
Hide Signatures
       Post #: 1314
RE: 1/8th scale B-1B - 11/16/2009 6:39 AM
Seraphim77
Score: 100
Status: offline
quote:
ORIGINAL: N622JR
quote:
ORIGINAL: theb1bman
Does anyone else agree that one of the worst things about model aviation is that it's so damned hard to video?? Anyone have any tips? Could focus be manually set to infinity, maybe?
I am new but so far the worst thing about model aviation is having an $.89 balsa glider budget, foamie ARF talent/experience, and B-1B dreams.
Although, talent and Experience can grow with research and practice, dreams can come true, and to heck with the car insurance, I'm buying a new kit!!!
Now the only thing I need to find is a spare 85'' of space in my house to build the thing.
John
Welcome John! Hey, we all start from somewhere and learn over time...nobody knows it all and very few can fork out an unlimited supply of cash! We do with what we have and build upon that. I have no doubt that if one of your goals and dreams in life is to fly jets, you will! Of course though, you might want to rethink the car insurance thing...you'll have to get to the field somehow...hopefully legally! You'll need it to trailer in your future B-1!
Hide Signatures
(in reply to N622JR)
       Post #: 1315
RE: 1/8th scale B-1B - 11/16/2009 7:53 AM
Seraphim77
Score: 100
Status: offline
quote:
ORIGINAL: Mike Emilio
What is that drawing from, are you saying it is the F-14? It shows washout but it appears to be only about two degrees.
Gentlemen...we're getting off topic here. Let's please take this "washout" discussion elsewhere to a F-14 thread as this one is dedicated to the B-1.
I'll say this though, from Wikipedia they say the airfoil for the F-14 is:
NACA 64A209.65 mod root
NACA 64A208.91 mod tip
In every picture and drawing I've seen, the Anhedral is there but I don't see any washout...and what appears to be hand traced/drawn rib sections seems very inconclusive.
Hide Signatures
       Post #: 1316
RE: 1/8th scale B-1B - 11/16/2009 8:07 AM
lavi rider
Score: 100
Last Login: 3/16/2010
Status: offline
I saw some docs both mine and the fellow who builds one as well and it shows a 3.2 Degree washout.
The airfoil you wrote is correct.
Very similar to HQ-Acro-1.0/12
the anhedral is around -1.8 degree.
Anyway back to the original post.....
Regards,
Hide Signatures
       Post #: 1317
RE: 1/8th scale B-1B - 11/16/2009 8:13 AM
pilotdude57
Score: 100
Status: offline
I originally just wanted to make sure Butch and Bob have checked into whether or not the B-1b has washout. If they haven't looked at it, it would be a good idea. Just helping them cover all bases.
Hide Signatures
(in reply to lavi rider)
       Post #: 1318
RE: 1/8th scale B-1B - 11/16/2009 8:38 AM
lavi rider
Score: 100
Status: offline
Isn't it a bit late over there right now .....3:30 am?
A washout on this wing is not necessary it's just a nice to have feature.. the plane will fly fine with out it too ....
Hide Signatures
       Post #: 1319
RE: 1/8th scale B-1B - 11/16/2009 8:56 AM
victorzamora
Score: 128
Status: offline
Washout would help reduce tipstall tendencies (to a certain point) and it could increase the Oswald Efficiency Factor significantly. I mean, you can achieve a a more elliptical lift distribution aerodynamically. I know that's the same thing...but I just wanted to clarify the point.
Had I have known that the law of gravity was going to be so expensive, I would''ve voted to veto the darn thing!!
Hide Signatures
       Post #: 1320
RE: 1/8th scale B-1B - 11/16/2009 10:37 AM
lavi rider
Score: 100
Status: offline
Yes you are right....but I ment for this particular model.....I just hope they have picked a "nice" airfoil for their bird for improved behaviour.
I would pick two different airfoils for the root and tip.
Hide Signatures
(in reply to victorzamora)
       Post #: 1321
RE: 1/8th scale B-1B - 11/16/2009 11:00 AM
grbaker
Score: 105
Status: offline
quote:
IGNORED *** - 11/16/2009 2:13 AM
pilotdude57
This user is on your "block" list and the message has been blocked.
Click here to unblock this user and view this post.
If a tree falls in the forest, but there is no one there to hear it. does it make a sound?
Gary Baker
Hide Signatures
       Post #: 1322
RE: 1/8th scale B-1B - 11/16/2009 12:24 PM
Mike Emilio
Score: 100
Status: offline
That's no hand tracing. Yes it is.
But now I'm thinking why I even bothered. It's in your favour, and thought it would put a quick end to the debate, but I guess you still want to argue some frivolous point. I'm going to delete it now.
This is the B1 thread.
Hide Signatures
       Post #: 1323
RE: 1/8th scale B-1B - 11/16/2009 12:44 PM
lavi rider
Score: 100
Status: offline
Mike...Qusetion answered
Peter
Hide Signatures
(in reply to Mike Emilio)
       Post #: 1324
RE: 1/8th scale B-1B - 11/16/2009 2:08 PM
victorzamora
Score: 128
Status: offline
quote:
ORIGINAL: lavi rider
Yes you are right....but I ment for this particular model.....I just hope they have picked a ''nice'' airfoil for their bird for improved behaviour.
Absolutely, I mean (if chosen correctly), you get a more efficient increase in your Oswald (less total parasitic drag). I can only imagine this plane being a BEAST to fly if you don't choose the right airfoil and get aerodynamic twist just right. I mean, anything meant for high speed flight is going to suck to fly. The plane has really high AR wings...but I think they're pretty small for the plane. High wing loading??
Hide Signatures
       Post #: 1325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
