Quick help with Yokomo GT4    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> Quick help with Yokomo GT4
Page: [1]
Login
Quick help with Yokomo GT4 - 8/27/2006 4:44 AM
asylum-
Score: 100
Last Login: 9/2/2006
Status: offline
Hi guys, my name is Jesse. I bought a Yokomo GT4 about 2 years ago (guess?). I drove it for about 6-8 months. After that it sat in storage (no place to drive it). Now that i can drive it i tried to start it up. It had brand new gas and a fully charged glow start. After fooling around with it a bit it wouldn't start. So i checked the gas lines. It wasn't pumping gas to the motor. So i held my finger on the exhaust tip and cranked the motor. It started but quickly stalled. And that was the only way i could get the motor to start. So basically what I'm saying is the motor is not pumping gas to it. Is there anyway i could fix that? Bad lines, Bad compression?
Any help would be very much appreciated. If you need any more information i left out then feel free to ask.
Thanks.
Hide Signatures
       Post #: 1
RE: Quick help with Yokomo GT4 - 8/27/2006 8:00 AM
rlouis12
Score: 100
Last Login: 6/17/2013
Status: offline
I usually pull off the line from the pipe and blew into it. Second the you can buy a prime bulb from towerhobbies. Also you might check your gas tank to see if it has a leak.
Hide Signatures
(in reply to asylum-)
       Post #: 2
RE: Quick help with Yokomo GT4 - 8/27/2006 9:39 AM
D-Nicest
Score: 100
Last Login: 5/27/2010
Status: offline
Your piston is probably done reason why, when a piston begins to die or is bad you have to keep on leaning the motor in to make it move like it did when it had a good piston, right now your engine is too lean. Richen it up for now but if it keeps dieng out on you its time to get a new engine. Also check your fuel tank, and make sure there no clogging anywhere. Change your glow plug, you've had that engine for like a year, you'd wonder why it won't start lol
_____________________________
Team RC America/Xray/Jaco/Hudy/Max Power/
Bruckner Hobbies/Team Fanatics/
Hide Signatures
(in reply to rlouis12)
       Post #: 3
RE: Quick help with Yokomo GT4 - 8/27/2006 5:16 PM
asylum-
Score: 100
Status: offline
Thank you D-Nicest, The engine will start and fire up but quickly die after that. Because Fuel is not getting to the motor. Will the things you just suggested help it?
I have 2 extra Glow plugs that haven't been used, but have been sitting around, will those be fine?
Thanks again.
Hide Signatures
(in reply to D-Nicest)
       Post #: 4
RE: Quick help with Yokomo GT4 - 8/29/2006 6:37 PM
D-Nicest
Score: 100
Status: offline
Yeah go ahead and richen up the high end needle, and put a brand new "packaged" glow plug in, but if you see that after maybe 1 or 2 mins of running the engine keeps on cutting off, or the car can't idol, it's time for a new engine.
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
