Damnathius
CA, USA Status: offline
Rman, I'm not using a glow driver. I actually considered installing a driver on this engine, but after running it in on the bench for a few hours and getting it tuned, I determined that it just wasn't necessary, and just installed a DuBro remote adapter due to the cowled installation. The prop I am running on the 120 is a 24x8. I think that helps lower the idle by 100-200 rpm. The top end is 4400 with this prop. I believe RCV recommends not loading it below 4100 rpm at WOT. As for reliability, it just runs plain sweet, no questions asked. I do keep it a tad rich on idle and top end. Just remember that 1000 rpm at the prop is 2000 rpm crankshaft speed on the SP engines, which is a reasonable idle speed for most 4 strokes. On the 60 SP I was running a 15x12 APC, and it would tach to about 5900-6000, so I definitely ran that one rich to keep the rpm down. You have probably read this elsewhere, but flip starting these engines is a breeze as long as you can get them primed nice and wet. Hope this helps. Dave
