RE: the unofficial home of the dumas dauntless    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> RE: the unofficial home of the dumas dauntless Page: <<   < prev  125 126 [127] 128 129 130 131 132 133 134   next >   >>
Login
RE: the unofficial home of the dumas dauntless - 8/7/2012 4:18 PM
Rich404
Score: 105
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: Rich404
Instead of me using aluminum on top of the epoxy lip I might just shape a piece of aluminum or wood as a spacer for the back wall and fill the entire cavity like a swimming pool in epoxy. Then I just have to remove the temporary wall when it is done, lightly sand it and paint it. Then I never have to worry about something happening to the bowlip because the entire structure is made opf solid aluminum.
-Rich.
Perhaps someone will find some inspiration in this and put it to work. Just make the entire bowlip from a block of epoxy and shape it....done. It is easy and will be indistructible.
-Rich.
Hide Signatures
(in reply to Rich404)
       Post #: 3151
RE: the unofficial home of the dumas dauntless - 8/7/2012 4:36 PM
Sound Sailor
Score: 100
Status: offline
Rich I can't find the photo right now but I believe DF did a screen grab from the video on the beach that showed the bow lip area with the bow light etc. In that pic the area under the covering at the front of the lip was not solid.
I made my bow lip by first making a paper template and then cutting a piece of styrene , bending it to the curve of the bow and Ca ing it to the deck. Then I Ca'd a cover piece for the very front. Remember the lip had chocks cut into it for the anchor rhode.
Bill
Hide Signatures
       Post #: 3152
rblubaugh
Score: 100
Last Login: 5/20/2013
Status: offline
Rich,
I was just looking at the photos and reading the text back on page 19.  The bow lip is merely a continuation of the bow curvature and I noticed it seemed fairly thick, maybe 1/8"?  I also noticed dropped of relatively sharply (after the chocks) and wonder of if should be a little more gradual?    The idea of making the entire addition of solid epoxy sounds great and a lot simpler than building it out of wood/plywood ,etc.
Bob
Hide Signatures
       Post #: 3153
RE: the unofficial home of the dumas dauntless - 8/7/2012 5:07 PM
Rich404
Score: 105
Status: offline
Hi Bill & Bob,
These discussions are great because they challenge me to come up with solutions.
Bob: Just after the chock the lip must drop fairly sharp in order to be correct. The difference between mine & the original is that the chocks were present on the other side of the aluminum whereas I buried them in epoxy. The info with the chocks present was not available at the time. I will not re-modify them because the external appearance is good and it added strength to the overall structure.
I would not use styrene and if I had to do it again but rather I would go epoxy. My bowlip is nearly indestructible. I do not ever have to worry about it getting ruined because of a mishap because it is that strong! If another model boat was to cross mine while underway their boat would get POUNDED and my bowlip should easily withstand it.
You do have a good point about the inside of the lip being hollow. Fair enough. Here is a proposal. IHow about making a thin rectangle box that will be at the end of the bow just where the chocks begin where the lip platform ends. It will go abeam to the other side. Then drill a few holes behind it as grab holes on the deck. Then backfill the rest of the bow and over the top of the rectangle box by 1/8”. By doing this you can still see a little bit under the platform to be satisfied with the detail and still have the strength of having a solid epoxy platform and bow lip. I think this will last the life of the boat.
To make the initial bowlip that extends past the deck use painters tape to get the height and look and then fill it with epoxy. When the tape is removed the epoxy will look perfect and the shape will be there.
What do you all think?
-Rich.
Hide Signatures
(in reply to rblubaugh)
       Post #: 3154
RE: the unofficial home of the dumas dauntless - 8/7/2012 5:10 PM
Sound Sailor
Score: 100
Status: offline
Rich take a look at page 95 first post .
Bill
Hide Signatures
       Post #: 3155
RE: the unofficial home of the dumas dauntless - 8/7/2012 5:14 PM
Rich404
Score: 105
Status: offline
quote:
ORIGINAL: Sound Sailor
Bill
You never let me get off easy!!
-Rich.
Hide Signatures
(in reply to Sound Sailor)
       Post #: 3156
RE: the unofficial home of the dumas dauntless - 8/7/2012 7:21 PM
Sound Sailor
Score: 100
Status: offline
Hey it's a dirty job but somebody has to do it! How am I doing?
Bill
Hide Signatures
       Post #: 3157
RE: the unofficial home of the dumas dauntless - 8/7/2012 7:36 PM
Rich404
Score: 105
Status: offline
Bill
you're doing a great job at keeping me on the straight and narrow... I do think that the above suggestion is great for someone that doesn't care to capture every detail in it's entirety.
After seeing that it reminds me that my bow is one thin aluminum plate away from having that detail completed.
-Rich.
Hide Signatures
       Post #: 3158
RE: the unofficial home of the dumas dauntless - 8/7/2012 10:10 PM
deep sky
Score: 100
Last Login: 5/19/2013
Status: offline
well captains i could not sleep last knit so i burned the midnight oil and she is ready for he first coat of glass i would reckamend anybody building dauntless to use feather light bondo to fill with. next after glass more filler and sanding
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3159
RE: the unofficial home of the dumas dauntless - 8/7/2012 10:43 PM
rblubaugh
Score: 100
Status: offline
DS,
Fabulous!  Just simply fabulous.  You've done a really nice job on the hull; the bow is nicely shapped.  There's still a lot of sanding ahead butwhat a nice base!
Bob
Hide Signatures
(in reply to deep sky)
       Post #: 3160
RE: the unofficial home of the dumas dauntless - 8/7/2012 10:49 PM
Rich404
Score: 105
Status: offline
quote:
ORIGINAL: deep sky
Congrats Deepsky you are moving this project along at a tremendous pace!
-Rich.
Hide Signatures
       Post #: 3161
RE: the unofficial home of the dumas dauntless - 8/8/2012 3:06 AM
dauntlessfan
Score: 110
Last Login: 5/18/2013
Status: offline
Great ideas on the bow details fellas.
I went to start my truck this morning and quickly realized the AC had quit. We're right in the middle of a 100+ degree heatwave, so you guys can probably guess what I'll be working on tonight instead of the boat .
Hide Signatures
       Post #: 3162
RE: the unofficial home of the dumas dauntless - 8/8/2012 3:42 AM
Rich404
Score: 105
Status: offline
quote:
ORIGINAL: dauntlessfan
I went to start my truck this morning and quickly realized the AC had quit. We're right in the middle of a 100+ degree heatwave, so you guys can probably guess what I'll be working on tonight instead of the boat [&o].
UGG..About a year or so ago my wife had to work in Dallas so I went down there to check it out. . Every day was over 100 degrees and it was brutal. I feel for you for having to deal with that heat. The AC is a must over there.
-Rich.
Hide Signatures
(in reply to dauntlessfan)
       Post #: 3163
RE: the unofficial home of the dumas dauntless - 8/8/2012 2:33 PM
rblubaugh
Score: 100
Status: offline
Makes you wonder how we ever got along without AC?
Bob
Hide Signatures
       Post #: 3164
RE: the unofficial home of the dumas dauntless - 8/8/2012 7:51 PM
deep sky
Score: 100
Status: offline
how does this look for the bowlip
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3165
RE: the unofficial home of the dumas dauntless - 8/8/2012 8:43 PM
rblubaugh
Score: 100
Status: offline
DS,
Looks good to me BUT "wheres the chocks"?  Go back to page 95 to get some inspiration fromRich and if you want 'scale'  also check out the picture on page 19 of the bowlip of the "original" Dauntless.
Bob
Hide Signatures
       Post #: 3166
RE: the unofficial home of the dumas dauntless - 8/8/2012 8:55 PM
deep sky
Score: 100
Status: offline
i havent got that far yet just finished roughing it out. after glass and puting deck on ill cut for chocks
Hide Signatures
       Post #: 3167
RE: the unofficial home of the dumas dauntless - 8/8/2012 9:39 PM
rblubaugh
Score: 100
Status: offline
O.K. I jumped the gun.
Hide Signatures
       Post #: 3168
RE: the unofficial home of the dumas dauntless - 8/9/2012 2:05 AM
12skipper
Score: 100
Status: offline
Hi Deepsky,
If you go back to page 8 about the 12th post down, you will see how I treated the raised bow and the chocks. I hope this helps.
Chuck
Hide Signatures
       Post #: 3169
RE: the unofficial home of the dumas dauntless - 8/9/2012 2:18 AM
deep sky
Score: 100
Status: offline
that is just about what mine will look like when its done im not ready to cut out the caucks yet
Hide Signatures
(in reply to 12skipper)
       Post #: 3170
RE: the unofficial home of the dumas dauntless - 8/9/2012 11:24 AM
Sound Sailor
Score: 100
Status: offline
In  this shot you can see the profile of the bow lip on the real Dauntless and the one I added to mine long after it was built.
Bill
Click for fullsize
Hide Signatures
       Post #: 3171
RE: the unofficial home of the dumas dauntless - 8/9/2012 10:59 PM
deep sky
Score: 100
Status: offline
hi caps can anyone tell me if a esc rated at 75 amps that has been runing a 7.2 motor will work for 1 of my 700s
Hide Signatures
       Post #: 3172
RE: the unofficial home of the dumas dauntless - 8/10/2012 2:37 PM
Rich404
Score: 105
Status: offline
quote:
ORIGINAL: deep sky
If you are running the boat on 7.2V's then yes it would work. If the boat will be running on 12V then you have to first look up the specs of the ESC to see if it will support it.
-Rich.
Hide Signatures
       Post #: 3173
RE: the unofficial home of the dumas dauntless - 8/10/2012 3:46 PM
dauntlessfan
Score: 110
Status: offline
Made more accute throttles, was going to paint the knobs. Pulled out my box of Testors model paints and most of them have dried up .
Other than that I think this piece is finally done.... for now .
Click for fullsize
Hide Signatures
       Post #: 3174
RE: the unofficial home of the dumas dauntless - 8/10/2012 4:00 PM
deep sky
Score: 100
Status: offline
im not shure what the specks are a guy has a radio motor and esc on e bay with a buy it now of 20 dollars he states the motor is 7.2 and the esc is rated at 75 amps max im going 12v
Hide Signatures
       Post #: 3175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
