RE: the unofficial home of the dumas dauntless    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> RE: the unofficial home of the dumas dauntless Page: <<   < prev  138 139 [140] 141 142 143 144 145 146 147   next >   >>
Login
RE: the unofficial home of the dumas dauntless - 9/24/2012 1:51 AM
dauntlessfan
Score: 110
Last Login: 5/18/2013
Status: offline
Holy (expletive) Rich, she looks remarkable on the water now. WOW! I love how the boat really digs in on the turns. Great videos and congratulations. You've definitely captured the performance and power of the S&S Dauntless!
Hide Signatures
(in reply to Rich404)
       Post #: 3476
RE: the unofficial home of the dumas dauntless - 9/24/2012 3:05 AM
Sound Sailor
Score: 100
Last Login: 5/21/2013
Status: offline
Hi Rich, definately a lot better as I expected with that motor now "hitting on all cylinders".  Looks right on for speed. I wasn't impressed with the sound system on the video but I'm sure it's better in person.
I went down to Fushing today and also had good results with the repowering of the Baron. The boat ran well and the motor passed the touch test. The guys will probably only run another week or two and I'll be on my cruise so thats it for me this year. (for down there that is) Maybe we can sneak in a sail at Binney when I get back. Still need to wire in switches and fuses in Dauntless but it can be run plugging the batteries direct to the ESCs.
Bill
Hide Signatures
       Post #: 3477
RE: the unofficial home of the dumas dauntless - 9/24/2012 3:08 AM
guapoman2000
Score: 259
Last Login: 5/5/2013
Status: offline
quote:
ORIGINAL: Sound Sailor
I like having the redundancy in case of a problem. It was proven helpful when one of mine burned out at the a club sail and I was able to run Dauntless back on one. I am in the process of replacing them with Astro 208D s.
Bill
Bill,
Consider visiting this thread before you do go with the Astro 208D's
http://www.rcgroups.com/forums/showthread.php?t=465523
Carlos
Hide Signatures
(in reply to Sound Sailor)
       Post #: 3478
RE: the unofficial home of the dumas dauntless - 9/24/2012 3:25 AM
Sound Sailor
Score: 100
Status: offline
Thanks, but i already bought them and I have them in the boat. I was running 2 Electronize fr30xh which were supposed to be good and had problems twice with the last being completely dead so i gave up on them. I also put a 208D in my racing lobster boat and so far it has performed really well. All the newer esc have thermal shut down which I have experianced in the past. once they cool a little they work again. The best cure is to find why they are overheating which is usually the motor drawing to much current or ambient temperture from a overheating motor.
Bill
Hide Signatures
(in reply to guapoman2000)
       Post #: 3479
RE: the unofficial home of the dumas dauntless - 9/24/2012 3:31 AM
guapoman2000
Score: 259
Status: offline
Bill,
Does any company out here in the USA sell a Brushed ESC that can withstand 50-AMP continuous and without reaching thermal shutdown?
The PRO BOAT 50-AMP ESC that I have in my large 6-Foot Plywood PT311 did gave me a shut down momentarily on the 2nd Run this past Saturday for the Still High Resolution Picture session and the motor just quit. I am amazed since I have the Forced Water Cooling System with Water Cold Plate system and when the Motor finally restarted (less than one minute) I commanded the model to shore only to find the ESC just luke warm???
I am willing to spend some additional $$$ for a very robust ESC such that I do not find myself with an unresponsive Motor and heading to the rocks!
Appreciate any leads.
Thanks!
Carlos
Hide Signatures
       Post #: 3480
RE: the unofficial home of the dumas dauntless - 9/24/2012 3:44 AM
Rich404
Score: 105
Status: offline
quote:
ORIGINAL: guapoman2000
Bill,
Carlos
Hi Carlos,
I know exactly what was happening to his ESC's. I knew the guy from back in the day...He was running one ESC for both motors and he like many guys back then was running huge props direct drive on his boat. When his boat was at speed you could barely see the wake because he ran big props and it was a big load on one ESC. The ESC would shut down because there were so many amps on one ESC because he had two big Astros in addition to the large props.. That's a recipe for a thermal shutdown.
If he had one ESC per motor and smaller props (1 1/2"- 1 3/4" max) he wouldn't have that problem with the 208D's. I have those ESC's in two boats and absolutely love them!  Even when my other motors were running hot the Astro ESC's were as cool as can be.
-Rich.
< Message edited by Rich404 -- 9/24/2012 4:07 AM >
Hide Signatures
       Post #: 3481
RE: the unofficial home of the dumas dauntless - 9/24/2012 3:49 AM
Sound Sailor
Score: 100
Status: offline
I can't answer that Carlos since a motor drawing 50 amps continuous is not very common in RC boats. i know you are running one big motor in your PT. you might check Novack for an esc, also I don't know if you are water cooling on your esc. as well as the motor.
Bill
Hide Signatures
       Post #: 3482
RE: the unofficial home of the dumas dauntless - 9/24/2012 3:59 AM
guapoman2000
Score: 259
Status: offline
Thanks for the replies guys!
Nevermind, I will allow you all to continue to discuss the Dumas Dauntless....
Regards,
Carlos
Hide Signatures
       Post #: 3483
RE: the unofficial home of the dumas dauntless - 9/24/2012 4:12 AM
Rich404
Score: 105
Status: offline
quote:
ORIGINAL: dauntlessfan
Thanks Dauntlessfan,
This is the type of performance I always dreamed of for this boat. Thanks to all of you for the inspiration that helped me bring this dream forward.
-Rich.
Hide Signatures
(in reply to dauntlessfan)
       Post #: 3484
RE: the unofficial home of the dumas dauntless - 9/24/2012 4:22 AM
Rich404
Score: 105
Status: offline
Bill
The sound system still needs work. It needs to be properly grounded and the storage doors on the transom need to be installed so the sound can be let out. It currently sounds muffled trapped behind all that mahogany & epoxy. So far, this was the first time I turned it up during a run because it can be annoying listening to the feedback. One of the good things about it is that once you shut down the volume you don't hear it. I don't think I would get another one especially since the Astroflight motors sound so darned good as is.
I think a session at Binney is inevitable. I do think that the Empire State clan should push forward with each Sunday until the pond freezes but that's just my opinion. I'll try to get down for a wrap up session but I have been really busy with other things to make the trip. I'm glad the Baron is doing good. I cannot wait to see it in person. We'll have to meet up very soon.
-Rich.
Hide Signatures
       Post #: 3485
RE: the unofficial home of the dumas dauntless - 9/25/2012 3:19 AM
deep sky
Score: 100
Last Login: 5/19/2013
Status: offline
today started puting rudders on and fitting servo i just thought i would see what it looks like with the props on
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3486
RE: the unofficial home of the dumas dauntless - 9/25/2012 3:45 AM
deep sky
Score: 100
Status: offline
i started looking at my shafts and the props set way back these shafts were for the drive dogs with the new style props it sets them way back im wondering if the thereds should be cut off a little has anyone had any problems with the props that far back
Hide Signatures
(in reply to deep sky)
       Post #: 3487
RE: the unofficial home of the dumas dauntless - 9/26/2012 4:09 AM
dauntlessfan
Score: 110
Status: offline
DS I'd set them back as close as possible to the strut to minimize vibration, maybe put a washer and collar between.
Rich - thanks again for the pulley. Hung it on the davit tonight, shines like a jewel. I totally dig it!
Click for fullsize
Hide Signatures
       Post #: 3488
RE: the unofficial home of the dumas dauntless - 9/26/2012 6:28 PM
rblubaugh
Score: 100
Last Login: 5/20/2013
Status: offline
Captains;
I just received an email that the drive shafts I ordered were shipped today.  I'm a little disappointed since the last email received said they would try to get them out Friday but if not them "Monday for sure".  I suppose they can suffer from personnel problems like most other companies.   Meanwhile I've been working on the motor mounts.
Bob
Hide Signatures
       Post #: 3489
RE: the unofficial home of the dumas dauntless - 9/26/2012 6:39 PM
Rich404
Score: 105
Status: offline
They'll be there before you know it...That reminds me I should post some updated engineroom pics..
Also the water pumps came in....I am waiting for the water jackets to be in stock so that I can buy them & hook them up. I'll do the pumps at the same time. Tis' a waiting game..
-Rich.
Hide Signatures
(in reply to rblubaugh)
       Post #: 3490
RE: the unofficial home of the dumas dauntless - 9/26/2012 6:41 PM
Rich404
Score: 105
Status: offline
Today I began looking into Dauntles's crew. I have the captain & engineer picked out...
-Rich.
Hide Signatures
       Post #: 3491
RE: the unofficial home of the dumas dauntless - 9/27/2012 4:04 PM
Rich404
Score: 105
Status: offline
Hi caps...
Between yesterday & today I found a good crew of people that will ride aboard the Dauntless. There will be 3 men in suites along with a few elegant ladies aboard. I'm still bidding on the captain & engineer but won't reveal who they are are until I have them. All of the people will be in 1:18 scale because it is currently too difficult to find a decent crew in 1:16. I think this will be a good mix of people that will play the part of the modern 1940's-50's wealthy. I'm sure I will add more people later on but this is a start. These little figures add up fast! The Dauntless will be set up as a diorama so each room inside & out will feature people going about their business on the boat. Each room will have a story to tell.
Pics will come once they arrive.
-Rich.
Hide Signatures
       Post #: 3492
RE: the unofficial home of the dumas dauntless - 9/27/2012 4:55 PM
Sound Sailor
Score: 100
Status: offline
Surely not the head!!!!
Bill
Hide Signatures
       Post #: 3493
RE: the unofficial home of the dumas dauntless - 9/27/2012 5:04 PM
Rich404
Score: 105
Status: offline
Surely!!! but who dares to peek inside!!
-Rich.
Hide Signatures
       Post #: 3494
RE: the unofficial home of the dumas dauntless - 9/27/2012 5:36 PM
deep sky
Score: 100
Status: offline
hi caps im bidding on a new graupner 9.6 700 turbo motor if i win i will be running these motors. well i got a little done started the radar mast.im still wondering if i should cut some of the threds off my shafts to bring the props forward a little
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3495
RE: the unofficial home of the dumas dauntless - 9/27/2012 7:52 PM
rblubaugh
Score: 100
Status: offline
Deep,
I read, on another forum, "the closer the prop to the rudder the better."  He then went further and stated "to try to get the prop no closer than 25% of the prop diameter".  You can check it out here and maybe PM the writer with any further questions and let us know the answer.  http://www.rcgroups.com/forums/showthread.php?t=701900&highlight=prop+rudder+distanc
Bob
Hide Signatures
       Post #: 3496
RE: the unofficial home of the dumas dauntless - 9/27/2012 8:09 PM
rblubaugh
Score: 100
Status: offline
Deep,
Another point I just read, the closer the prop to the rudder the more responsive the boat is to rudder commands since the rudder /boat only responds to moving water.  Hmm, something else to think about.
Captains,
My drive shafts have arrived, time to go to work.
Bob
Hide Signatures
       Post #: 3497
RE: the unofficial home of the dumas dauntless - 9/27/2012 8:55 PM
deep sky
Score: 100
Status: offline
thanks i think ill try it the way they are
Hide Signatures
       Post #: 3498
RE: the unofficial home of the dumas dauntless - 9/28/2012 12:27 AM
deep sky
Score: 100
Status: offline
well i won a new in the box graupner 700 speed turbo motor so thats what ill go with. i spent most of the day cutting one plank at a time for the aft deck there not sanded or finshed yet or glued but i think it look good.still lots of work on the aft deck area before the get instaled
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3499
RE: the unofficial home of the dumas dauntless - 9/28/2012 12:29 AM
Sound Sailor
Score: 100
Status: offline
I encountered the same thing when I changed props. I left it as is with no problems and it runs fine. Once you cut the shaft there is no going back.
Bill
Hide Signatures
       Post #: 3500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
