RE: the unofficial home of the dumas dauntless    Gallery
Logged in as Guest
Users viewing this topic: Sound Sailor
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> RE: the unofficial home of the dumas dauntless
Page: <<   < prev  144 145 [146] 147 148 149 150 151 152 153   next >   >>
Login
RE: the unofficial home of the dumas dauntless - 11/7/2012 9:55 PM
Rich404
Last Login: 5/18/2013
Status: online
I hope all is well with Bill. I have not heard from him since before the storm began.
Bill...give us a shout to let us know that you are ok!!
-Rich.
Hide Signatures
(in reply to deep sky)
       Post #: 3626
RE: the unofficial home of the dumas dauntless - 11/10/2012 3:06 AM
deep sky
Last Login: 5/17/2013
Status: offline
hi caps here is the latest headway got cockpit deck layed a long way to go starting to look better the planks were a pain
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Rich404)
       Post #: 3627
RE: the unofficial home of the dumas dauntless - 11/10/2012 1:03 PM
Sound Sailor
Status: online
I'm still around after 10 days of no power and 11 days no internet/cable. (just got the net right now) My property ,luckily, recieved minor damage . The house next to me had a 36" diameter pine tree fall on it. It stood 25' from my house but went in their direction. Another house in town had a tree fall on it killng two preteens. We have had down trees and telephone poles blocking roads until 2 days ago. We had the National Guard helping clear roads, etc and the local fire station provided dry ice and hot showers. Most of the damage came from very large pine trees that coud not stand up to Sandy's winds.
It is interesting how we have become so reliant on power and the net. There is not much to do on nights that are getting longer but I kept busy working on a new build duing the hours there was enough light.
Anyway it's good to be back amongst civilization.
Cheers all
Bill
Hide Signatures
       Post #: 3628
RE: the unofficial home of the dumas dauntless - 11/10/2012 3:59 PM
rblubaugh
Status: offline
Bill,
GREAT to be hearing from you and very happy you escaped serious damages.  So very sorry about your neighbor's in town however; I can not imagine loosing two children.  Everything else is repairable damage even if inconvenient.
Deep,
The decking looks real nice.  In those tight confines I can only imagine the difficulty of laying those small strips of decking but the effort was worth it.
Bob
Hide Signatures
(in reply to Sound Sailor)
       Post #: 3629
RE: the unofficial home of the dumas dauntless - 11/11/2012 6:15 AM
deep sky
Status: offline
hi caps i was able to get 2 evx-2s for a good price now im wondering if my recever is only a 2 chanel and each one is pluged in to it where does the steering plug in can i wire them together and use 1 plug or do i need to get a 3-4 chanel raido set
Hide Signatures
(in reply to rblubaugh)
       Post #: 3630
RE: the unofficial home of the dumas dauntless - 11/11/2012 3:41 PM
dauntlessfan
Status: offline
Deep - Other captians please check my math on this but I think you'll use a y-connector to connect two ESCs to the throttle output of your Rx.
Make sure to disconnect one of the positive Rx battery elimination circuit (BEC) wires from either (one) of the ESCs so the Rx is only powered from one source.
Hide Signatures
       Post #: 3631
RE: the unofficial home of the dumas dauntless - 11/11/2012 4:53 PM
Sound Sailor
Status: online
DF is correct on both counts. When disconnecting the BEC power lead on one rcvr rather than just cutting it you can lift the little pin in the side opening of the plug and just pull the lead out of the plug. Turn it back and put a small piece of tape over it. This is less permenant if you ever want to use the the esc elsewhere.
Bill
Hide Signatures
(in reply to dauntlessfan)
       Post #: 3632
RE: the unofficial home of the dumas dauntless - 11/13/2012 6:50 AM
deep sky
Status: offline
hi caps  well i got all my motors escs and ordered a servo y 2 graupner 700 speed bb turbo 9.6 motors 2 Traxxas EVX2 16.8 ESCs about the only thing left is batterys  i want to go with the aux lighting batterys but i dont know where to buy them any ideas
Hide Signatures
       Post #: 3633
RE: the unofficial home of the dumas dauntless - 11/13/2012 4:30 PM
Rich404
Status: online
Hey Deep...Auxillary (lighting) batteries are not  good for high discharge motors. You will end up running the boat for a few minutes and the battery will appear dead. Then, when you bring the boat home it will suddenly appear charged and ready to go again. This is because the auxillary battery won't be able to keep up with the demand of the motors. In the end it will be a waste of money.
Don't waste money...GO NIMH..and don't look back...
-Rich.
Hide Signatures
       Post #: 3634
RE: the unofficial home of the dumas dauntless - 11/13/2012 5:22 PM
deep sky
Status: offline
thanks Rich WHAT KIND OF CONBO DO I NEED 1 12 VOLT PER MOTOR 2 6 VOLT PER MOTOR 1 12 VOLT FOR ALL ?
Hide Signatures
       Post #: 3635
RE: the unofficial home of the dumas dauntless - 11/13/2012 6:29 PM
Rich404
Status: online
Use (2) 12V NIMH batteries..
-Rich.
Hide Signatures
       Post #: 3636
RE: the unofficial home of the dumas dauntless - 11/13/2012 10:34 PM
dauntlessfan
Status: offline
DS - With your speed controllers, remember that each of your EVX-2's will come pre-wired to accept one or two batteries with a maximum voltage of 8.4V each.
If you only use one battery per ESC, you can't use anything above 8.4v. and the speed of your boat won't be very exciting at only 8.4 volts being fed to each motor.
As the EVX-2 is designed out of the box, you'll need a total of four 6-8.4v packs to get a healthy 12-16.8 volts to each motor.
Or... if you found some super high-capacity 6-8.4v packs, you may be able to use just use two batteries - each in parallel - feeding one of the two battery inputs to both ESCs.
Or... according to the forums I've read, you can rewire the EVX-2 to accept a single battery up to 16.8V. It involves making a jumper on the non-BEC battery input side. Check out the Traxxas user forums for a diagram if you feel comfortable expereimenting with this route.
Hope that doesn't muddy things up too much .
Hide Signatures
       Post #: 3637
RE: the unofficial home of the dumas dauntless - 11/14/2012 4:03 AM
deep sky
Status: offline
hi here are the latest pix finely got the roof glued on im happy with the trim on the dash primed the rear roof and put the side window suports in not done yet im still messed up on this esc thing the evx2 calls for 2 batterys can i use 1 12 volt batt on one side or do i need 2 batterys that = 12 volts
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3638
RE: the unofficial home of the dumas dauntless - 11/14/2012 4:30 AM
dauntlessfan
Status: offline
quote:
ORIGINAL: deep sky
When I had an EVX I used two 6 volt batteries with no problems. That would be my recommendation.
Hide Signatures
       Post #: 3639
RE: the unofficial home of the dumas dauntless - 11/14/2012 6:32 AM
deep sky
Status: offline
so if i understand this right i need 2 6 volt batterys per esc as i will be running 2 escs one for each motor and the 4 batterys will work when i use the y cable for the escs
Hide Signatures
       Post #: 3640
RE: the unofficial home of the dumas dauntless - 11/14/2012 4:07 PM
Rich404
Status: online
Hi Bill,
I plan on sailing Dauntless in Binney Park during my lunch break. Will you be around?
-Rich.
Hide Signatures
       Post #: 3641
RE: the unofficial home of the dumas dauntless - 11/14/2012 4:09 PM
Rich404
Status: online
quote:
ORIGINAL: dauntlessfan
quote:
ORIGINAL: deep sky
Hey DF..Is this in series or in parallel?
-Rich.
Hide Signatures
       Post #: 3642
RE: the unofficial home of the dumas dauntless - 11/14/2012 5:26 PM
dauntlessfan
Status: offline
OMG Rich I read your post too quick and I thought it said, "I plan on SELLING Dauntless..." I about fell out of my chair.
Anyway, as to your question - when I used two 6 volt batteries, each was just directly connected to the EVX ESC because it has two battery plugs coming out of it.
Hide Signatures
       Post #: 3643
RE: the unofficial home of the dumas dauntless - 11/14/2012 5:39 PM
deep sky
Status: offline
just wondering if there is 2 leads for 2 motors why cant you use 1 12 volt per esc so you feed each motor 12 v or do you have to use bolth leads on each esc
Hide Signatures
       Post #: 3644
RE: the unofficial home of the dumas dauntless - 11/14/2012 6:21 PM
Sound Sailor
Status: online
Hey Rich, sorry about that! I'm still catching up on things here after Sandy and forgot we talked about sailing today and was out doing erands. Did you sail? how is the pond?
On another note I  have interesting graphics coming from Callie for Sandy B.
Bill
Hide Signatures
       Post #: 3645
RE: the unofficial home of the dumas dauntless - 11/14/2012 6:50 PM
Rich404
Status: online
LOL!! even though sometimes I feel like this boat has a wacky hold on me & I would be better off without it..
-Rich.
Hide Signatures
       Post #: 3646
RE: the unofficial home of the dumas dauntless - 11/14/2012 7:23 PM
Rich404
Status: online
Hi Bill,
Yes, I went to Binney today...Is that park freakin' haunted?? Too many things were going wrong over there....
I parked and started at the canal near the tennis court...
1) I tested the boat before placing her in water, all was fine... Then I put her in water and the port coupler slipped off and she let off the most wicked scream... then I had to bring her in & put it back on...what a pain in the arse....
2) tried to take pics of her in the canal which was really difficult because I had to use an old slow camera and with the head wind Dauntless had to cruise pretty fast to stay on course.. (toward the cobblestone bridge)
3) I almost got hit by a car crossing the street while Dauntless was sailing under the cobblestone bridge...(There's a lot of risk sailing a boat under a bridge that you can't see under) The car crossed over the bridge while Dauntless was cruising under it..and I was crossing the street and was more preoccupied on what Dauntless was doing...I couldn't see her and stopping was not an option...
4)did get some pics as she came out from under the cobblestone bridge...cool.
5) Now after the cobblestone bridge Dauntless had to cross under a foot bridge to get into the actual pond. For those that don't know this bridge is low so before I sailed her under I slowly brought her up to the bridge to see if she would make it...It looked like there was about 2" clearance from the top of the radar mast...Then I went to the bridge, held my breath and cruised her under and into the pond...About half way under the bridge I heard a CRUNCH CRUNCH sound...that can't be good...so Dauntless sailed out and the mast was laying on the owners cabin....ARGGGG....LUCKILY no damage...
6) I brought her near shore to readjust her mast....tapped a few rocks on the way....I didn't survey the damage yet....but I did manage to get my knee muddied up kneeling at the edge of the pond...
7) So Dauntless cruised off with me snapping away some pics...and then the port coupler came off again resulting in the same scream that I heard earlier...brought her back and put it back on...I didn't remove the boat from the water but instead removed the cabins with the hull in the water and adjusted from there...
8) So I cruised a little more and got some great compliments....all of which were dog owners...then I stepped in a steaming pile of dog sh1t....GREEEAAAATTTT!!!!!
9) Afterwards the LIPO alarms were starting to go off so I cruised her back to the low foot bridge and set down the mast so she could safely cruise under and made my way back to the canal where she cruised under both bridges and made her way back to port...A few more people seen her in the canal and were commenting on her beauty so I floored the throttles for a possible final picture and the camera was dead...so much for that but she looked really cool making her way down the canal...
10) When I brought her in I noticed that her engineroom was lightly flooded...I have no idea what the heck happened there...there is never a drop of water inside after runs so this has to be looked at..
I would post pics BUT I took out the SIM card and realized that it is ancient and not compatible with my computer...so much for that...I have the plug at home so I will post those either tonight or tomorrow...
So that was my run today at Binney Park...
-Rich.
Hide Signatures
       Post #: 3647
RE: the unofficial home of the dumas dauntless - 11/14/2012 8:02 PM
Rich404
Status: online
I'm sure it's not the park's fault though..it's just one of those days..
-Rich.
Hide Signatures
       Post #: 3648
RE: the unofficial home of the dumas dauntless - 11/14/2012 8:26 PM
Sound Sailor
Status: online
See!! I told you it was you Mayhem was following!!  I wasn't there this time.
Post them pix
Bill
Hide Signatures
       Post #: 3649
RE: the unofficial home of the dumas dauntless - 11/15/2012 12:26 AM
Rich404
Status: online
Mahem surely caught up with me today.....next time I need you there!!
-Rich.
Hide Signatures
       Post #: 3650
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
