RE: the unofficial home of the dumas dauntless    Gallery
Logged in as Guest
Users viewing this topic: Sound Sailor, dauntlessfan
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> RE: the unofficial home of the dumas dauntless Page: <<   < prev  146 147 [148] 149 150 151 152 153 154 155   next >   >>
Login
RE: the unofficial home of the dumas dauntless - 11/17/2012 5:01 PM
Rich404
Score: 105
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: dauntlessfan
Close but other way around, it takes in two batteries 6-8.4 volts and the output is double, up to 16.8V max. I'll clear it up by posting some wiring diagrams tonight.
I get it now...one 6V battery input has a 12V output...
-R.
Hide Signatures
(in reply to dauntlessfan)
       Post #: 3676
RE: the unofficial home of the dumas dauntless - 11/17/2012 9:31 PM
deep sky
Score: 100
Status: offline
what about running 2  7.2 packs for each  motor at a max volt of 17.4
Hide Signatures
(in reply to Rich404)
       Post #: 3677
RE: the unofficial home of the dumas dauntless - 11/17/2012 10:08 PM
Sound Sailor
Score: 100
Status: online
What that esc does is put the 2 batteries in series thereby doubling the voltage. That means you get the most votage out of the combo of 2 batteries but less run time. Not my cup o tea.
I opt for longer run times in my boats so all but one have 2 batteries in parallel.
Bill
Hide Signatures
(in reply to deep sky)
       Post #: 3678
RE: the unofficial home of the dumas dauntless - 11/18/2012 12:30 AM
dauntlessfan
Score: 110
Status: online
quote:
ORIGINAL: deep sky
Yes Deep that is correct and would work fine (your output voltage would be 14.4).
And yes Bill you are correct as well on the series statement as well.
Hide Signatures
       Post #: 3679
RE: the unofficial home of the dumas dauntless - 11/18/2012 12:58 AM
Sound Sailor
Score: 100
Status: online
DF are you using this esc? Interesting reading the specs. Notice motor limit and about thermal shutdown. Also about the 0 timing for reverse
Bill
Motor Limit: EVX-2 Marine has a 12-turn 550 modified motor limit whenInsulate the Wires: Always insulate exposed wiring with heat shrink tubingUse Neutrally Timed Motors: For reverse use, the motors must have 0°Motor Capacitors Required: Ceramic capacitors should be properly installedNo Schottky Diodes: External schottky diodes are not compatible with
the motor is properly geared. A water cooling kit (Traxxas part #1580) is
required for modified motor use in marine applications such as the Villain
EX. If the motor or speed control is overheating, try a smaller pinion gear.
Do not attempt to use a more powerful motor (fewer turns) than the above
mentioned motor limits or you could experience frequent thermal shutdown.
to prevent short circuits.
timing. Modified motors (with adjustable end bells) timed to 0° or Johnson/
Mabuchi (closed end bell) motors are recommended. Using motors with
other than 0° timing will draw excess current in reverse, and can result in the
speed control overheating and premature motor wear.
on every motor to prevent radio interference. These are already installed on
the factory Titan Marine motor.
reversing speed controls. Using a schottky diode with the EVX-2 Marine will
damage the ESC and void the 30-day warranty.
Hide Signatures
       Post #: 3680
RE: the unofficial home of the dumas dauntless - 11/18/2012 2:06 AM
deep sky
Score: 100
Status: offline
my brain is getting so fryed about these escs i wonder if i should sell these and buy ? what are you outher captains useing for the groupner 700 9.6 motors as in batt-escs
Hide Signatures
(in reply to Sound Sailor)
       Post #: 3681
RE: the unofficial home of the dumas dauntless - 11/18/2012 3:16 AM
Rich404
Score: 105
Status: offline
My motors & ESC's are Astroflight and you see I have a no-nonsense setup...
I mentioned this time and time again..go for the Astroflight ESC's..
Here is what I find comical...So many people cut corners to save money and then have to spend even more money to do it all over again...I've seen this happen on the forums for years..
Isn't it cheaper to just do it right the first time?
-Rich.
< Message edited by Rich404 -- 11/18/2012 1:10 PM >
Hide Signatures
       Post #: 3682
RE: the unofficial home of the dumas dauntless - 11/18/2012 7:19 PM
deep sky
Score: 100
Status: offline
hi caps i got a little more work done on the cockpit built the 2 benchs havent glued them down im thinking of puting hinges on them so i can get to my motor covers
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3683
RE: the unofficial home of the dumas dauntless - 11/18/2012 9:51 PM
Rich404
Score: 105
Status: offline
Very nice Deepsky!!
-Rich.
Hide Signatures
       Post #: 3684
RE: the unofficial home of the dumas dauntless - 11/18/2012 10:19 PM
Rich404
Score: 105
Status: offline
Here is some photos taken today..
It's like a scene from YACHTS IN A HURRY...
-Rich.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Rich404 -- 11/18/2012 11:27 PM >
Hide Signatures
       Post #: 3685
RE: the unofficial home of the dumas dauntless - 11/19/2012 4:11 PM
dauntlessfan
Score: 110
Status: online
Hi Bill - I was using a single EVX for many years when I had tame Mabuchi 555 motors. But once I upgraded to the 700 motors, one EVX couldn't handle it and died.
DS - On Big Dauntless those seats folded out of the way as needed, so that would be cool to add to your model as well!
Rich - Awesome pics, she's a beauty on the water. And who knew Dauntless would make such a cool looking monster truck in that first pic !
Hide Signatures
       Post #: 3686
RE: the unofficial home of the dumas dauntless - 11/20/2012 12:27 AM
deep sky
Score: 100
Status: offline
hi caps i found a dauntless o e bayunder dumas dauntless starting bid 99.99
Hide Signatures
       Post #: 3687
RE: the unofficial home of the dumas dauntless - 11/20/2012 12:34 AM
deep sky
Score: 100
Status: offline
on an outher note im am going to try my evx-2s traxxas makes the water cooling kit 3.95 and they are used on the traxxas  villan boat and outher of ther boats they tell me they will handel 1 700 motor since im running 2 evxs 1 for each motor im going to try it i have 2 of them the worsr that can happen is ill have to start over
Hide Signatures
       Post #: 3688
RE: the unofficial home of the dumas dauntless - 11/20/2012 12:56 AM
deep sky
Score: 100
Status: offline
i also have a question i was reading that some of you captains have had bad luck with dumas dog bones who makes the 5mm to 3/16 u joints
Hide Signatures
       Post #: 3689
RE: the unofficial home of the dumas dauntless - 11/20/2012 6:37 AM
dauntlessfan
Score: 110
Status: online
DeepSky - yes those Dumas dog bones will get chewed up like... well... a dog with a tasty bone. Go to the Harbor Models website and order from their selection of couplers instead.
Hide Signatures
       Post #: 3690
RE: the unofficial home of the dumas dauntless - 11/20/2012 3:42 PM
Rich404
Score: 105
Status: offline
+1
-Rich.
Hide Signatures
       Post #: 3691
RE: the unofficial home of the dumas dauntless - 11/20/2012 3:44 PM
Rich404
Score: 105
Status: offline
Hi Deepsky,
The Dauntless above once had a buy it now price that was outragous. It seems like the owner decided to be more realistic on his starting price.
-Rich.
Hide Signatures
       Post #: 3692
RE: the unofficial home of the dumas dauntless - 11/20/2012 3:46 PM
Rich404
Score: 105
Status: offline
Dauntless is a great monster truck...she cruises through the toughest terrain with ease and she doesn't break my back cause I don't have to carry her...
I am able to fit all this in a small Toyota with ease...
-Rich.
Hide Signatures
       Post #: 3693
RE: the unofficial home of the dumas dauntless - 11/20/2012 4:34 PM
Sound Sailor
Score: 100
Status: online
Shame about those 2 children having to ride on the roof though!
Bill
Hide Signatures
       Post #: 3694
RE: the unofficial home of the dumas dauntless - 11/20/2012 5:16 PM
Rich404
Score: 105
Status: offline
quote:
ORIGINAL: Sound Sailor
Bill
Sadly they have to follow in another car!!!
but the boat fits...
-Rich.
Hide Signatures
       Post #: 3695
RE: the unofficial home of the dumas dauntless - 11/20/2012 5:20 PM
Rich404
Score: 105
Status: offline
Hi Bill,
I took the week off from work so I won't be in the area for a run. When I ran the boat this last time I found out that it was the prop shafts that need regreasing..Hopefully I will have that squared away in the next few days.
Now that I have the week off I am remodelling our bedroom...there's always something on the honey do list. Our room looks like granny's craftroom with all the old floral wallpaper & such. Its the final frontier in our home  that needs a makeover.....It's time to bring it to modern standards..
-Rich.
Hide Signatures
       Post #: 3696
RE: the unofficial home of the dumas dauntless - 11/20/2012 11:33 PM
Sound Sailor
Score: 100
Status: online
Bill
Hide Signatures
       Post #: 3697
RE: the unofficial home of the dumas dauntless - 11/21/2012 12:57 PM
Rich404
Score: 105
Status: offline
Bill
Hi Bill,
Catching the issue was not very simple. A while back when I was removing a part of the rear keel It split away from the hull causing the glass to crack which resulted in a leak under the owners cabin. I since sealed it but I was worried that it came from there.
-Rich.
Hide Signatures
       Post #: 3698
RE: the unofficial home of the dumas dauntless - 11/21/2012 3:38 PM
Sound Sailor
Score: 100
Status: online
What did the grumpy old man say at the park when he asked about oilites?
Bill
Hide Signatures
       Post #: 3699
RE: the unofficial home of the dumas dauntless - 11/21/2012 3:55 PM
Rich404
Score: 105
Status: offline
yep you were right. Today I dropped the shafts and regreased them. This should do the trick for a little bit.  Now I need to finish up those water wells I started making for the shafts.
I also removed the sound module and got it ready to go back to Canada.
-Rich.
Hide Signatures
       Post #: 3700
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
