RE: the unofficial home of the dumas dauntless    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> RE: the unofficial home of the dumas dauntless Page: <<   < prev  151 152 [153] 154 155 156 157 158 159 160   next >   >>
Login
RE: the unofficial home of the dumas dauntless - 12/31/2012 1:05 AM
deep sky
Score: 100
Last Login: 5/19/2013
Status: offline
trying agin to upload i made some headway on the raft not done yet also made forward hatch and painted hull inside i dident like my bow so i started over for the bow light stand
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to deep sky)
       Post #: 3801
RE: the unofficial home of the dumas dauntless - 12/31/2012 2:19 PM
Rich404
Score: 105
Last Login: 5/21/2013
Status: offline
Hi deepsky,
If there are no mounting screws on the ESC try 3M double stick tape.
Your boat is looking great! Notice that on the full sized Dauntless you have the bowlip but it is covered. I have yet to get up to it on my model but it will get done. Use the Dauntless video on youtube for reference when he gets up to the bow. The lip is sort of like a platform.
-Rich.
Hide Signatures
       Post #: 3802
RE: the unofficial home of the dumas dauntless - 1/1/2013 1:11 AM
deep sky
Score: 100
Status: offline
hi caps i was able to start puting the motors back in servo ext. iv got to get some doble side tape to try for my escs anyway here is some pix
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Rich404)
       Post #: 3803
RE: the unofficial home of the dumas dauntless - 1/1/2013 4:26 AM
Rich404
Score: 105
Status: offline
Happy new year captains!!
-Rich.
Hide Signatures
       Post #: 3804
RE: the unofficial home of the dumas dauntless - 1/1/2013 8:38 AM
leebart121
Score: 105
Last Login: 3/30/2013
Status: offline
Yes happy new year.
Hide Signatures
       Post #: 3805
RE: the unofficial home of the dumas dauntless - 1/1/2013 4:02 PM
rblubaugh
Score: 100
Last Login: 5/20/2013
Status: offline
Ditto, Happy New Year.
Deep, the boat is looking great.
Bob
Hide Signatures
(in reply to leebart121)
       Post #: 3806
RE: the unofficial home of the dumas dauntless - 1/1/2013 6:13 PM
rblubaugh
Score: 100
Status: offline
Captains,
I have successfully epoxied the Port motor mount.  After adjusting with my battery pack attached I applied some 6 minute epoxy, kept the motor running for a couple minutes to make sure things hadn't shifted, unpluged the battery then left it alone for a few hours.  When I came back it purred like a kitten.
Tried switching the universal to the Starboard motor but wasn't as successful, the motor ran rough so I broke the epoxy joint and about a 40 thousandths shim seemed to smooth it out but I ran out of time so will go back later to re-test it.  Otherwise I'm waiting for a replacement coupling insert.  Might be better to use it's own universal before permanently epoxying in place
although I really don't see any reason why.
Here's a few pics.  The first one shows the Port motor in place, the second shows both motors with the Starboard crippled without its universal and the last two just to show the alignment "looks" pretty close, but not close enough.
Bob
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to rblubaugh)
       Post #: 3807
RE: the unofficial home of the dumas dauntless - 1/1/2013 6:41 PM
dauntlessfan
Score: 110
Last Login: 5/18/2013
Status: offline
Deep - another idea for mounting those ESCs is to make little wood frames to set them in. That's how I mounted mine last time just made a shallow wood case to set the ESC in, waterproofed it, then of course the wood frame is easy to glue into place anywhere you'd like. But my last ESC had the cooling fins on top, looks like yours may be on the sides, so a few holes for air circulation.
Hide Signatures
       Post #: 3808
RE: the unofficial home of the dumas dauntless - 1/1/2013 7:17 PM
deep sky
Score: 100
Status: offline
thanks for the idea im thinking about that same thing or maybe drilling 4 small holes and useing 2 small zip ties in a + pattern to hold them but i will most likely build a frame for them
Hide Signatures
(in reply to dauntlessfan)
       Post #: 3809
RE: the unofficial home of the dumas dauntless - 1/1/2013 11:09 PM
Sound Sailor
Score: 100
Status: offline
All  my ESC are just mounted with industrial hook and loop tape. (Velcro) Some of mine are the same make as yours which do not have cooling fins and are sealed units. Once in a rare while the tape doesn't stick (on the boat side)  and a little medium Ca takes care of it . As I said that is how they are mounted in all my fleet of 8 boats incuding the one brushless with fins . My rcvrs are mounted the same way.
Bill
Hide Signatures
       Post #: 3810
RE: the unofficial home of the dumas dauntless - 1/1/2013 11:24 PM
deep sky
Score: 100
Status: offline
thanks for the input i dont know why the first time i tryed velcro when i glued it on with 5 min epoxy it fell off maybe ill try cleaning the esc a little better thanks to all you captains i have ideas now o by the way where would i look for inds velcro
Hide Signatures
(in reply to Sound Sailor)
       Post #: 3811
RE: the unofficial home of the dumas dauntless - 1/2/2013 3:05 AM
Rich404
Score: 105
Status: offline
 Hi captains,
I have bee putting a lot of hours in Dauntless...
The cabin lights work but the contact springs are shightly pushing up on the cabins. I now need suggestions on how to latch the cabins to the hull. I posted detailed pictures on page 2 of the Dauntless sister forum.
Then off to the sound module...I spent all night and a good part of today trying to hook that thing up....I know I hooked it up right and it doesn't work. I think it was dead on arrival (DOA). I have to contact the manufacturer AGAIN. This is VERY annoying...
Now i'm of to the pumps. I got the servo to work so I know it will switch on...
Now for the pumps. I just ran a test on each one and like everything from china one pump seems smoother than the other....One thing that I don't like is that the motors kick up a fair amount of sparks...This makes me a bit nervous because they are in such close proximity to the LIPOS. I will likely up up alumunum foil lined boxes around them....
I plan on going on some missions before the end of Winter. Three very important locations on the 'bucket list' for this boat is:
-The Long Island Sound
-Tarrytown Boat Club
-Oyster Bay
Bill...Are you up to go on some missions?
Well guys...break is over back to wiring...
-Rich.
Hide Signatures
       Post #: 3812
RE: the unofficial home of the dumas dauntless - 1/2/2013 3:26 AM
dauntlessfan
Score: 110
Status: offline
Rich keep on truckin and don't get burnt out (no pun intended) . Also maybe feeding a bit lower voltage to those chinese pumps would help with the sparks?
Hide Signatures
       Post #: 3813
RE: the unofficial home of the dumas dauntless - 1/2/2013 4:34 AM
dauntlessfan
Score: 110
Status: offline
Rich I'm guessing your Oyster Bay visit going to be to the Jackobson shipyard? I think last time I looked, it had been converted into a recreation center or something. But the turntable and tracks Jackoson once used to launch boats (and assuming also the Dauntless) are still visible in online satellite views.. the attached are from a few years ago. Current images show a lot of small sailboat hulls cluttered around the turntable and one of the launch tracks pretty much built over.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3814
RE: the unofficial home of the dumas dauntless - 1/2/2013 5:58 AM
Rich404
Score: 105
Status: offline
Hi DF,
That is absoulutely fine with me...Yes I would go to that spot to sail the boat..I think it would be a sacred spot for us 'dauntlessfans' to sail at least once. The cool part is step sister  lives very close to there.
Update,
The wiring on my boat is bananas...I have become a pro at soldering and shrink wrapping to say the least.
As of now I am done with the following:
  • The lights all work and the switch panel is under the lazarette floor near the steering controls. I cut out a section in the floor so that I can easily use the switches.
  • Each of the 4 motors are wired up. I took a long cable for positive and one for negative and cut around where the contacts would be for each motor. Then I soldered the cable to each motor contact. The positive cable runs straight to the pwr dst panel and the negative runs to the servo controlled 3 way switch and then to the panel.
  • The boat also has 3 working fans in the engineroom. Two are intake which brings in outside air and the third sucks in engineroom heat and blows it outside the louvered vents outside the boat. The exhaust is made from the old exhaust box mentioned earlier. That is also wired up and it will be placed over the servo controlled switch.
  • ***I do need to finish up the woodwork to tie together the intake and exhaust to the louvers.
Here is how the switch works:
It is a 3 way switch and is controlled by a slider switch on my tx. On the tx the center is off but when it is slid up the servo switches on the waterpumps. Then it goes back to center where the pumps are off. Then, when it is slid down the intake and exhaust fans will kick on and flush the heat out of the engineroom.
So now another change will be made to the water plumbing. The water hoses are too big and don't fit very tightly around the water pump so that is the first concern.
Second, they don't fit very snug around the underwater intake tubes. This is a bit scary because a mishap will send my boat to Davey Jones locker as the saying goes. So I am going to refit all the plumbing using smaller tubes. Finally the third concern with the plumbing is that I have two intake lines per water inlet and they get fed into one waterpump. It is overkill because I had to branch all the splitters which looks horrible. So rather than rip out the double water inlets I am going to epoxy over one pair under the boat and fill the tubes with epoxy and call it a day. Now I will use 4 underwater pickups rather than eight. What I am going to do is have one splitter comimg off of each motor so that when the tubes do fill they will still converge at the transom and still have the same effect on the water exhaust feature.
Once there are less water tubes to deal with aft I am planning on setting the LIPOS up using on/off switches. This is so that I don't have to take the boat apart at the pond but rather install the charged LIPOS at home, bring the boat to the pond and remove the storage doors on the transom and turn on the LIPOS at the flick of three switches. This will be ideal for me and now that I am comfortable with soldering I will can make it happen.
The cool thing about this is that not only can I turn the boat off or on but I also have access to the light switches in the same area so I won't have to take the boat apart to get to anything...
-Rich.
Hide Signatures
       Post #: 3815
RE: the unofficial home of the dumas dauntless - 1/2/2013 6:06 AM
Rich404
Score: 105
Status: offline
quote:
ORIGINAL: dauntlessfan
Unfortunately my pwr distribution panel goes from 3,5,6 and 12V. I wish it had a 9V feature. I tried it on 6V and they didn't even turn over so 12V it is. Also, I am going to watercool those pumps..The way that I soldered the cable to the leads makes them ideal for me to cut some brass tubes and solder them to the leads. I just didn't have the time tonight. Once I begin the water tube redo I will sdo it then.  I figure that one pair of pumps will be dedicated to cooling all the pumps and cooling the two ESC' and one pair of pumps will be dedicated to cooling the motors. This has turned into a very complex system but I am having so much fun doing it.
-Rich.
Hide Signatures
       Post #: 3816
RE: the unofficial home of the dumas dauntless - 1/2/2013 3:11 PM
Rich404
Score: 105
Status: offline
 Hi captains,
Here are pictures to support the above...
First picture is the water pump and exhaust switch..
Then comes the wiring for the lights..
-Rich.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3817
RE: the unofficial home of the dumas dauntless - 1/2/2013 3:21 PM
Rich404
Score: 105
Status: offline
Now comes the glory...
The lighting of the yacht...
The searchlight was on the line with the navigation lights which turned out not to be a good idea bacause the navi lights were 6V and the searchlight was 3V. As Jesus once said, a star that shines twice as bright lasts half as long.... So I have to either replace the bulb to 6V or have to find a 6V searchlight...
Here are those pictures..
PS..I noticed today that RCU loads up pictures lightning fast...I wonder if they got wind that the crown jewel of the scale boat forum began migrating to another forum..
-Rich.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3818
RE: the unofficial home of the dumas dauntless - 1/2/2013 3:43 PM
Sound Sailor
Score: 100
Status: offline
Rich, not being critical but helpful. In the pics above of the wiring , last row of the 3pics, pic in the middle of the 4 switch wiring. Be very careful and maybe use some tape or other insulation close to the solder connection. The wires on the single spst switch look to be very close to touching and causing a closed circuit.
You going to the meeting on Friday?
Bill
Hide Signatures
       Post #: 3819
RE: the unofficial home of the dumas dauntless - 1/2/2013 3:48 PM
Rich404
Score: 105
Status: offline
Moving right along....
Here are pictures of the pumps and fans being wired up.  If you look closely at these pictures you can see that the aft side walls are completely covered in wires and watertubing. There are a few final notes here..
The motors are wired and as I mentioned will get watercooling on the contacts.
I moved the fuse holders to the port and starboard motors further aft. The fuse holders were located on the stateroom side for the port motor and the pantry on the stbd motor. Because they are bulky they would cause problems every time I lifed off the owners suite so I broke a bed suppport 3 seperate times and it was always hard to shimy it back in place. So with the fuses relocated further aft this is no longer an issue...
The owners cabin walls were always a bit too high since I created the lipo trays under the owners suite so I began shaving down the top of the walls so that they will lower properly. This was done after supports were put on the top of the walls to better support the upper structure.
You can also see the spagetti tubing aft where the tubes come up from the underwater pickups and converge to go into the waterpump. By eliminating one tube per motor on the intake side will eliminate the wishbone look coming from the floor and clean up the mess down there. also there was no need for two intakes for one motor. This should clean up nicely and free up more room for the LIPO switches.
The exhaust fan in the engineroom still needs to be slightly modified. I am going to cut down the four exhaust pipes to be smaller and will possibly remove those cool looking smoke injectors. This will also free up some space in the enginerom and not look so cluttered when the tubes are installed.
This yacht is a continued work in progress but that's what a hobby is, right?
-Rich.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3820
RE: the unofficial home of the dumas dauntless - 1/2/2013 3:54 PM
Rich404
Score: 105
Status: offline
quote:
ORIGINAL: Sound Sailor
Bill
That's a good idea, thanks Bill!! I'll follow up and wrap a little electrical tape aroud them.
I am unsure if I will make the meeting but i'll keep you posted.
-Rich.
Hide Signatures
       Post #: 3821
RE: the unofficial home of the dumas dauntless - 1/2/2013 4:15 PM
Rich404
Score: 105
Status: offline
Hi captains,
I hope you all had a Happy New Year!!
-Rich.
Click for fullsize
Hide Signatures
       Post #: 3822
RE: the unofficial home of the dumas dauntless - 1/2/2013 10:09 PM
Apismelifera
Score: 100
Last Login: 2/21/2013
Status: offline
deep sky:
Velcro or any quality brand of hook and loop fastening can be found at any fabric store. That's where I bought mine last time. The fabric store I went to sells it by the foot in black or white, and in several different widths.
If you want you can also buy it from http://www.mcmaster.com/#hook-and-loop/=kv56rd they have Military Specification hook and loop if that,s what you really want. Have a look!
Rich404:
I have on occasion, made my own "Y" connectors from K&S brass tubing before. I made mine in a square or U shape to better fit the space. I made one with a 0.375" inlet and five 0.125" outlets for my Torino. I used it as a vacuum manifold. Made the tubing runs neater and shorter. I even soldered on a brass tab with a hole in in so I could bolt it down. Nothing fits Better than a custom made part.
You also mentioned that the pump motors spark a lot. Consider adding RF suppression capacitors to them. If they spark they're radiating RF noise that your receiver has to deal with. The cleaner the environment the more range you will have. Since they are only getting voltage of one polarity you might try a large 100uf capacitor on the motors from Positive to negative. You only need one for each pair of motors. Just be sure to get the polarity of the capacitor correct. Something like these: http://www.radioshack.com/product/index.jsp?productId=2102510&znt_campaign=Category_CMS&znt_source=CAT&znt_medium=RSCOM&znt_content=CT2032230
_____________________________
John KaBang
Hide Signatures
       Post #: 3823
RE: the unofficial home of the dumas dauntless - 1/2/2013 11:29 PM
dauntlessfan
Score: 110
Status: offline
Great update and cute kid Rich! And wow, some of those pictures of the interior lighting really give insight as to how it must have looked to be aboard Big D after dark... very nice work as always!
Hide Signatures
(in reply to Apismelifera)
       Post #: 3824
RE: the unofficial home of the dumas dauntless - 1/3/2013 11:43 AM
Sound Sailor
Score: 100
Status: offline
Real nice pic with the latest family addition. Looks like you were ready to lose a railing.
What did Nicholas think of that going on with HIS boat?
Hide Signatures
       Post #: 3825
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
