WhiteWolf McBride
Score: 100 Joined: 12/6/2004 Last Login: 11/21/2009 From: Ottawa,
ON, CANADA Status: offline
Rich: PLEASE tell us you were able to make copies of these 'as-first-launched' pictures! It would be very interesting to see what those rails might have been... My guess? Depending on location, perhaps they were for navigating the side-decks while the boat was at speed? That was one thing I did note - no way to get from fore-deck to cockpit safely: no handrail, no edge-rail or safety line. But after the 'sea-trials', they may have been removed as 'un-necessary equipment' as most wouldn't be traversing fore/aft while the boat was in transit, yes? Would also like to see the cockpit without the permanent canopy... That 'Design Section' article shows it without the permanent top... and one might tale the lines running back from the fore-deck safety-line to the cockpit door to be those 'bars' you mentioned, a safey-line attachment point I guessed at? The 'inboard profile' plan diagram shows the uncovered cockpit, and the 'venturi' (aka wind deflector) down at the base of the cockpit windscreen, and the windshield on the bow seating area one can be seen (and is noted) as well. I remember some of the later 40's and early 50's cars had these at the 'top' of their windscreens by the roof, often done in chrome. Many tractor-trailor semi's have them now too, and on the nose of the engine cowling as well. Shame about the ladders... after all that (idle) work making a few from balsa. Ah well, can always use 'em as display items... or mebbe use 'em on my refitted AE. Hope you can get those pics up (or mailed)... if you got 'em. WhiteWolf PS: I was just looking back at images of the aft cabin enterior, and something looks odd... mebbe a negative got flipped or summat? Here is whats baffling me: All three images posted here in the past (labelled Kv17005, Nt46108, & Xq44864) show an access ladder to the deck being on the LEFT side of the image, right? BUT any shot of the forward access from that aft cabin area to the main cockpit would put that access ladder/door on the RIGHT side of the image, correct? Now Kv & Nt appear to be of the same era, but not left/right of the same cabin. Nt has a fire extinguisher beside the ladder, Kv has an odd cast-pewter-ish emblem on the cubboard, and Xq has a shorter ladder (4 steps to the floor-block vs 5 of the other two) I'd personally say Nt & Xq are the same cabin, but at different times, due to the standard location of the sink on the far wall, the range/stove on the right, AND the differing electronic gear behind the access ladder, not to mention the curve of the deck/cabin support the ladder is attached to. So why the shorter ladder to the deck-box in Xq? Redesign when the engines were changed, perhaps? So that leaves Kv as the odd picture out. There are distinctly odd things in the Kv image: what looks like a round porthole on the right side above the counter facing aft, and an oblong one on the left above the counter facing the side, and the edge of a second be seen above the seating. The only place on the boat where there are oblong windows is the forecabin! This ~should~ make it the main cabin galley, forward of the cockpit, facing aft... BUT the ladder is too big! Plans show its only two steps up, and to the main cabin, NOT the cockpit, and plans show the access centered in the hull. Also, the curve of the deck/cabin support the ladder is attached to is less pronounced... if I had to assume flipped negs, I'd assume this is the one facing toward the cockpit, and the other two face AFT, toward the rear 'sundeck'... Mebbe Rich's research can provide some answers. (not that I'm going to build the interior, its just inconsistancies and puzzles like this really bug me) PPS: Anyone notice Dumas also missed that loop-antenna on the starboard foredeck? Its mast can also be seen in the images of the film cameras being set up (its the dark upright rod on the foreground of the image) Was that for the radio-telephone, or was the extra whip on the mast (the .041 piano wire) used for that? Rich, if your verbal data is this enlightening, I'd gladly be willing to donate a few bills for images/scans. Let us know, won't you?
< Message edited by WhiteWolf McBride -- 11/7/2009 4:43 AM >
_____________________________
WhiteWolf McBride - http://www.freewebs.com/whitewolf_mcbride/ 2x Tamiya Leo 1A4, 1x M4A3, 1x M26, 1x T34/85, & LAV''''
Hide Signatures
