the unofficial home of the dumas dauntless
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> the unofficial home of the dumas dauntless
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
the unofficial home of the dumas dauntless - 8/30/2006 1:18 PM
NITRO_VEEDRIVER
Score: 100
Last Login: 7/8/2009
Status: offline
well i decided not to get the deep vee. instaed i got the dumas dauntless. its the 49.5 inch cabin cruiser. its in the midst of being finished as we speak. here are the pics of it when i got it yesterday...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by NITRO_VEEDRIVER -- 9/18/2006 11:43 PM >
_____________________________
You can run, But you can''''''''t hide!
(Dwayne (Dog) Chapman)
Hide Signatures
       Post #: 1
RE: the unofficial home of the dumas dauntless - 8/30/2006 2:16 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
just finished sanding the hull. still alot to do to it before summer next year. more pics to come of the finishing project on it....
p.s what do you use to seal the hull? paint? i cant find epoxy paint anywhere ....any advice would be appreciated.....
also if anyone here uses skype you may add me...mini_dragonflyer
< Message edited by NITRO_VEEDRIVER -- 8/30/2006 2:20 PM >
Hide Signatures
(in reply to NITRO_VEEDRIVER)
       Post #: 2
RE: the unofficial home of the dumas dauntless - 8/30/2006 2:38 PM
Ron Olson
Score: 1026
Last Login: 11/8/2009
Status: online
Just regular epoxy. Brush it on and wipe off the excess with a paper towel.
Member, Southwest Michigan Model Boat Club and the IMPBA.
Rate me if I helped you, thanks.
Hide Signatures
       Post #: 3
RE: the unofficial home of the dumas dauntless - 8/30/2006 3:04 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
what kind of epoxy to use? after epoxy what kind of paint? name of epoxy to be used?
Hide Signatures
(in reply to Ron Olson)
       Post #: 4
RE: the unofficial home of the dumas dauntless - 8/30/2006 3:08 PM
Ron Olson
Score: 1026
Status: online
Use a good hobby grade epoxy. You'll probably want one with at least 45 minutes to give you more working time.
Seeing how it's an electric boat, you can use just about anything but keep it the same type of paint otherwise you could run into compatability problems.
Hide Signatures
       Post #: 5
RE: the unofficial home of the dumas dauntless - 8/30/2006 3:12 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
heres the thing. i am not finishing it for electric. i will be putting 2- 3.5 cc marine nitros into it. as it is a dual prop unit. so i really need to know what the name of epoxy is, and do i need to glass the inside of the whole hull? or just where the shafts exit the boat and under the engine....?
Hide Signatures
       Post #: 6
RE: the unofficial home of the dumas dauntless - 8/30/2006 3:21 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
well from what i am reading in the instructions for building this i have to fibreglass the hull and deck outside of it....1 layer of 2 oz fibreglass cloth with resin...
Hide Signatures
       Post #: 7
RE: the unofficial home of the dumas dauntless - 9/1/2006 10:49 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
well, here is what i have done so far. after 2 days of measuring things, i have finally cut the hatches, doors,vents and side port windows. the hatches, windows, and all doors are goin to be made from thin plexi. the side ports are goin to be green plastic pop bottle . also the hatches and doors are goin to be functional. my next step in this project will be making the floor inside the cabin. and making all furniture to go into it.. i have also around 8-9 running lights going in it. i will be using bondo polyester fibreglass resin to seal the hull. 1 coat outside and one coat inside to fuel proof it. i then will be using automotive spray paint to paint the hull in the colours that i want.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by NITRO_VEEDRIVER -- 9/2/2006 12:31 PM >
Hide Signatures
       Post #: 8
RE: the unofficial home of the dumas dauntless - 9/4/2006 6:00 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
come on guys. i know there must be other dauntless owners out there... i wanna see some dauntless's.....
Hide Signatures
       Post #: 9
RE: the unofficial home of the dumas dauntless - 9/4/2006 7:27 PM
Jerry Dunlap
Score: 100
Last Login: 11/7/2009
Status: offline
quote:
ORIGINAL: NITRO_VEEDRIVER
You might want to consider posting your quest for information on the Dauntless on the Scale Boat forum.
I can provide a suggestion on epoxy - I like West Systems Marine epoxy. It doesn't come in small amounts(like a quart is the smallest), but if you have other wood projects it can be used for it is worth the expense.
JD
Hide Signatures
       Post #: 10
RE: the unofficial home of the dumas dauntless - 9/12/2006 6:54 AM
NITRO_VEEDRIVER
Score: 100
Status: offline
well after long a deliberation period, i have decided as i am not goin electric, but 2 dual engines , that i am not goin to build the interior of the dauntless.so i am putting in a shallow floor. without furnishings. the floor however will be carpeted and the door goin to the cabin will still be a working door. as will the stairs be in it..
Hide Signatures
(in reply to Jerry Dunlap)
       Post #: 11
RE: the unofficial home of the dumas dauntless - 9/18/2006 3:51 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
finally got my nav lights today. still waiting on running gear.....
Hide Signatures
       Post #: 12
RE: the unofficial home of the dumas dauntless - 9/21/2006 4:51 PM
green-boat
Score: 100
Last Login: 10/17/2009
Status: offline
Go to an autobody supply store and get some color additive. Mix it in with your resin, that way you will have the color and resin all in one.
If olive oil comes from olives, where does baby oil come from.
Hide Signatures
       Post #: 13
RE: the unofficial home of the dumas dauntless - 9/21/2006 4:57 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
sounds like a plan, but i am still waiting on hardware for it. called towers today , post office here in canada, and u.s customs, noone has got my package. waiting on call from tower hobbies now. it was mailed on the 1st of sept. we are now the 21st. anyways, after i have done the resin i will be spray bombing the colors onto it. goin silver, royal blue, and white. oh but primer first......lmao
Hide Signatures
(in reply to green-boat)
       Post #: 14
RE: the unofficial home of the dumas dauntless - 9/21/2006 5:53 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
well i got a call back from tower and they are sending me a replacement so now when i get it if i get the other one and send it back to them. then at end of month i order my engines. dual aquacraft .18 marine engines too many people go electric so i thought i would be different....
Hide Signatures
       Post #: 15
RE: the unofficial home of the dumas dauntless - 9/26/2006 1:55 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
got some of my replacement parts yesterday. what didnt come in the package is my s/s shafts and stuffing boxes. i again phoned tower and told them , they phoned dumas and now i am waiting on dumas to send me out those items. today. actually like 5 min ago i get a knock on the door, its the first order of running hardware and they wanted money... needless to say i told the lady to send it back to tower. i paid enough for the items and customs wants money? only 17.00 but still at 102.78 on my card that should have been accounted for. so now i play the waiting game.....again
Hide Signatures
       Post #: 16
RE: the unofficial home of the dumas dauntless - 10/4/2006 4:05 AM
NITRO_VEEDRIVER
Score: 100
Status: offline
well, today i finally get my 1 engine so far. gotta order another one still. instead of aquacraft i went with the O.S max-18cv-rm. still waiting on shafts and stuffing boxes.also gotta figure out if i can get a dual engine mount bought or made to house both on one plate.
Hide Signatures
       Post #: 17
RE: the unofficial home of the dumas dauntless - 10/12/2006 5:45 AM
NITRO_VEEDRIVER
Score: 100
Status: offline
finally i have both my engines i need to get 1 more flywheel,and 2 universal joints. all running hardware is installed and working great. ordered 2 servos today. still need a battery for the reciever. still tons of work to do on it. all in due time. so far the tally is pretty close to 1000.00 spent on this boat. :shock: .
Hide Signatures
       Post #: 18
RE: the unofficial home of the dumas dauntless - 10/22/2006 2:10 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
and now all work on the dauntless has seized. due to moving in a few days.i have done up some airintake boxes on the inside of the boat where i had put the air scoop pieces. but thats all i have done. i also bought some wood filler and envirotex lite.high gloss finish pour on . this stuff should do the trick for sealing the wood. will post more when i move and get settled in.
Hide Signatures
       Post #: 19
RE: the unofficial home of the dumas dauntless - 10/26/2006 1:02 AM
Pusar
Score: 100
Last Login: 10/7/2008
Status: offline
Nitro..
Be sure to use at least 2oz. fiberglass cloth on the hull! The hull needs to be reinforced with the glass. If you have any questions about the build drop me a line...
I am running twin water cooled AstroFlight 25's with two Astro 308D Speed controls and each motor is running on a Sanyo 5000mAH 10 cell pack. It gets on plane FAST!
Marty
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Pusar -- 10/26/2006 1:17 AM >
Hide Signatures
       Post #: 20
RE: the unofficial home of the dumas dauntless - 10/26/2006 9:20 PM
RCOZZY
Score: 100
Last Login: 7/19/2008
Status: offline
It sure makes a nice looking boat when it's done. I like it better than the Crannberry Isle lobster yacht or whatever Midwest calls it. Is there any information on the web regarding the prototype? It's ahrd to believe these were commuter boats. Seems like you would see some thing similar today if it were truly a viable transport method.
< Message edited by RCOZZY -- 10/26/2006 9:21 PM >
Rob
Hide Signatures
(in reply to Pusar)
       Post #: 21
RE: the unofficial home of the dumas dauntless - 10/27/2006 12:54 AM
Pusar
Score: 100
Status: offline
It was a commuter boat for the Rockefellers. Not much of a commuter boat for the rest of us saps!
Marty
Click for fullsize
Hide Signatures
(in reply to RCOZZY)
       Post #: 22
RE: the unofficial home of the dumas dauntless - 10/27/2006 8:14 PM
NITRO_VEEDRIVER
Score: 100
Status: offline
one question for you pusar. i was told by another buddy to use envirotex to seal everything up. how hard is working with 2 oz glass? i used glass on my 14 ft fibreglass boat for the floor and it turned out to be a mess. i already have the engines to install when finished so i really dont want too much weight. the envirotex is used on furniture to make the surface look like a glass top. seems to be alright. but all opinions are welcome. is there anyone around my area that does glassing? if so pls msg me.
thanks in advance
Hide Signatures
(in reply to Pusar)
       Post #: 23
RE: the unofficial home of the dumas dauntless - 10/28/2006 12:03 AM
Pusar
Score: 100
Status: offline
Nitro...
Stay away from the Envirotex. Per the website...It is for indoor use and is not reccomended for outdoor use. A boat hull would be the worst enviroment for it. And don't forget in will come in contact with gasoline at some point. The fiberglass cloth takes out the imperfections of the wood planking and adds quite a bit of strength. It will not add that much weight. My battery packs alone weigh 7lbs. and the boat will still plane out. A real boat floor is a big diffference from this hull. Placing the boat upside down the fiberglass will lay on the hull. Pour the resin on and let it soak into the cloth. Use a plastic scraper in a downward motion and let the excess drip to the floor. When it dries get a case of beer and a lot of sandpaper and begin to sand. When the beer is gone and the sandpaper is shot... get more beer and keep sanding! A bit simplistic but it is not that bad.
Marty
Click for fullsize
< Message edited by Pusar -- 10/28/2006 12:07 AM >
Hide Signatures
       Post #: 24
RE: the unofficial home of the dumas dauntless - 10/28/2006 3:01 AM
green-boat
Score: 100
Status: offline
If you don't like using polyester resin with your glass cloth try using epoxy resin. Adding microballons to the resin mix will make easier to sand.
Hide Signatures
(in reply to Pusar)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.328RCU1
