jtsails
NC, USA Status: offline
Hey guys, sorry I haven't posted, been kinda hectic here. I did get the maiden done on Friday. Ground handling is about what I expected, very touchy, but once she gets a little air over the tail it settles down pretty well. Just be very light on the rudder. Once airborne it needed very little trim, don't think I even touched the ailerons, just a couple of clicks of down elevator. Made a couple of slow passes then gave her a little throttle, yikes she really climbs with throttle. Eased her back in and made some adjustments. I added some travel to the ailerons, went up to 1" up and down with about 30% expo. I added a little travel to the elevators, about 1 1/4" and dropped the expo back down to 30% and added a bunch of expo to the rudder for the ground handling. I'll set up a second condition or rate for the ground handling before I fly it again. Tried to make a second flight Fri but my onboard glow died, it was an old McDaniels unit. I made a second flight Sat. with no cowl so that I could get glow drivers on it. Had to fiddle with the carb setting to get it running right and then took off. Made my first mistake, didn't refuel after spending 5 min tuning and I ended up dead sticking it when I ran it out of gas, dang I forgot how much fuel a Saito 300 burns. Wasn't a problem though, just keep the nose down and she comes right in. I even landed it on the runway and stopped right in front of myself. Couldn't have done better with power. Handling was better on 2nd flight but I mixed too much down with the throttle and now had to hold up when I gave her the gas. Reset that and added a delay to the mix to elim a little purpoising and refueled and made a third flight and I have it pretty close. Still needs a little adjustment. New onboard glow should be here today, I'll get that installed and hopefully get back to the field Mon. since I'm going to the beach for the weekend. On a side note, the maiden was a little nervy as I had just lost a 30% Yak to a radio problem, total loss of airframe.
