woodbender
CA, USA Status: offline
quote:
Just maiden my new Mini pulse (#2) this morning. First flight, dragged my right wing on take off. The plane was diving right, with almost full left aileron I got it flattened out. Hit 4 clicks trim, not much help. Managed to get it turned around and back down safe on the ground. On the ground I hit more trim. Trimmed it to about 3/4 left aile.. Seconed flight, got it into the air, but still needed way too much left aile.. Got it turned around again and back safe on the ground. Quit while I was ahead and did not have my plane in a bag. Called a friend (same guy I bought #1 from) he is going to figure it out for me. If the wing is flat, and I'd bet it is, try giving the rudder some left trim. Also make sure you're not moving the stick to the right as you apply power on take off. The rudder is very sensitive especially on take off. Giving even slight right rudder (or NOT giving a bit of left rudder) on take off will give you the dive to the right you describe especially if you're running the 480 with the 11/7e prop. If you have a lot of rudder throw, try limiting it and/or dialing in some expo to tame it back a bit until you get used to it.
_____________________________
Lon www.woodbender.com
