dnitro
CA, USA Status: offline
Hey guys, I'm the newest member of a pulse xt pnp. I've just installed a spektrum system and a 3s 2200mah lipo. I gone thru the elev, rudder, aileron checks, cg is were it is suppose to be, and made sure my expo and d/r are correct. I'm just doing dry runs, with the plane held in place and I play around with the throttle to see how much time I can get with a set of batteries. Im estimating 8-10 minutes. I've notice that the motor, esc, and battery gets really warm, borderline hot. The prop looks like it is balanced. The esc and motor are the stock 450 brushless/22amp esc setup. Does it get hot because it is not actually flying, but rather just flying in place. No cool air is going thru the motor and inside compartment. Any ideas, or is this normal??? Thanks and happy flying
