n8026t
CO, USA Status: offline
The joiner wire was my initial assumption as well, however it remained intact. Some have guessed radio problems, however, since I have switched to FASST, I have not even experienced a hiccup. When things went bad, the A/C was at eye level, appx. 20 meters away, straight and level unaccelerated, and it was obvious control flutter. From what I could see, it appeared to start outboard on the left and promulgate inboard and accross. My assumption is that it was a flaw exclusive to my airframe either in construction or rigging. I initially thought it was speed related, but given the minimal power system I used in comparson with others on this board, if it were speed related, many others would have experienced the same.
