RE: E-Flite Mini Pulse XT Owner's Club
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Aerobatic & Sport Planes >> RE: E-Flite Mini Pulse XT Owner's Club Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: E-Flite Mini Pulse XT Owner's Club - 11/28/2006 4:03:53 PM
gsk11740
Status: offline
quote:
ORIGINAL: fliprob17
While the Pulse sits collecting dust waiting for Christmas morning.........I had to kill some time and settle some anxiety with the hobby....since I am just flying the Cessna right now......... So......... I picked up (2) Mini Ultra Sticks and (3) YAK 54 3D foamies on EBay I am putting together one of the YAK 54 for my dad for Christmas, and of course the Mini Ultra Sticks are for me
This Hobby is way toooooo addicting
I envy you guys in CA and FL! You only have to wait for Christmas to fly your MP. By the time I get my MP ready to go and get the MUS fixed and ready, I'll probably have to wait for Spring here. Once Winter starts setting in around my area, it gets way too windy to fly much of anything. I just checked the weather and it sounds like we have another cold front coming in Friday, just in time for UPS to deliver my MP.
(in reply to ADChobbystore)
       Post #: 201
RE: E-Flite Mini Pulse XT Owner's Club - 11/28/2006 7:45:34 PM
bkfawcett
Status: offline
So, not much discussion lately about the spinner problem. I chopped mine up last night to make sure that I don't even try to make it work. I'll run it without, but it sure looks nicer with a spinner. I've got a Dubro 1-3/4" to mount, but there isn't much thread left to tighten the prop, 'looking for a longer shaft.... I don't think that a Great Planes spinner would work any better. Any ideas out there? I want to commit to a setup so I can drill and mount the cowl with the right spacing. I don't want to sound like a rant, but I really expected the recommended kit, motor, prop, etc. to all snap together like it was meant to. Does the manufacturer even try to put their product together once to make sure? (rant rant moan...)
Found this aluminum 40mm spinner:
http://www.rcgroups.com/forums/showthread.php?t=577051
< Message edited by bkfawcett -- 11/28/2006 7:59:00 PM >
(in reply to gsk11740)
       Post #: 202
RE: E-Flite Mini Pulse XT Owner's Club - 11/28/2006 8:00:14 PM
ADChobbystore
Status: offline
Ya, I gave up on the spinner right off the bat. It looks really nice and clean with the spinner. I am looking at getting a Dubro 1-3/4" and a longer Great Planes prop adapter. They have one that measures just a little bit longer than the one that comes with the E-Elite motors. They are not in stock right now though. At the same time I am worried aobut the cooling for this whale of a 480 motor, so I am just going to go without and see if anythings gets too warm. You can use the stock spinner and get it all setup and still mount the cowl. That is what I did, then took the spinner off, the clearance/spacing is still good to go without the spinner. Just check it out several times before actually drilling the holes.
_____________________________
"All About The WATTS!!!"
adchobbystore.com
(in reply to bkfawcett)
       Post #: 203
RE: E-Flite Mini Pulse XT Owner's Club - 11/29/2006 11:49:29 AM
bzizzi
Status: offline
fliprob17,I see you picked up a couple of MUS on e bay like I did.I just won bid on
a US 25e and that brings the total to four sticks.I watched Doc's video on the 25e and just had to have one.I never understood addictions,I don't smoke,I don't do drugs,
I don't hang out at the bar and I don't gamble.But this Model aeroplane hobby has got me hooked. Oh well,I guess that this is alot less expensive and keeps me out of trouble.
When the wife ask's me what I wanted for my b-day the answer was real easy,a MFX
and I am sure X-mas will be the same.
       Post #: 204
RE: E-Flite Mini Pulse XT Owner's Club - 11/29/2006 1:15:06 PM
Doc Austin
Status: offline
quote:
ORIGINAL: bzizzi
To be fair to the plane, it was 25mph wind gusts that day and the plane is much, much smoother than appears in the video. If you check out the opening axial roll, you can see halfway through the plane gets blown dead sideways and keeps flying straight. Also notice i just flew right through it because the plane stayed stable and in control.
Later I've got full up on approach and the wind kept shoving the plane at the ground. It might look like a harrier, but I was really in deep trouble and only the plane's sublime stability coupled with agility got me out.
Welcome to the club. I'm going on 51 years.
Once my wife found out how much cheaper R/C was than having a mistress, she started buying all the stuff for me. Hey, now I've got my planes, and more to spend on my mistress!
Hey, just kidding.
< Message edited by Doc Austin -- 11/29/2006 1:16:31 PM >
There are days when I believe one man can make a difference.....and others where I have given up all hope.
Matt Murdoc
(in reply to bzizzi)
       Post #: 205
RE: E-Flite Mini Pulse XT Owner's Club - 11/29/2006 3:11:07 PM
ADChobbystore
Status: offline
quote:
ORIGINAL: bzizzi
Ya, I got two complete MUS kits, one with a cracked rib in the wing, and the other with a tear in the ultracote, and one crack in the fuse for $108. Other than that they look fine. I was looking at a couple of the 25 E's, just missed out on one.....you probably got it
adchobbystore.com
       Post #: 206
RE: E-Flite Mini Pulse XT Owner's Club - 11/30/2006 12:36:14 AM
lionel2341
Status: offline
Guys, just a heads up on bleeding off the speed on the MP. I use negative flap-a-rons to bleed speed. In other words, by setting up the ailerons to go up in spoiler fashion you will bleed speed nicely. I use the same setup on my Gas version of the Pulse XT. You only need a small amount of negative deflection and it works like a charm. Think Air-brake. It softly kills the lift of the wing. Once you turn on final you can pretty much put it anywhere on the landing strip
Ernie
       Post #: 207
RE: E-Flite Mini Pulse XT Owner's Club - 11/30/2006 1:31:22 AM
Doc Austin
Status: offline
Another way to kill speed to to use a percentage of the engine brake. I don't know about other ESCs, but with the Castle Creations ESC you can program brake in at 10% intervals. If you go into the advanced menu, you can program in 1% intervals. what this does is hold the prop back where it takes air force to turn it, and that force slows the airplane down. If you watch the video I posted earlier on this thread of the 25E, you can hear the ESC buzzing when the brake is on. When you hear that, watch how fast the airplane slows down.
Of course, you have to be careful if you use the ESC this way because the airplane slows so much faster than without it that you can stall the airplane very easily if you aren't fast on the power when you need it. Eventually you get used to it, but in the beginning it's like throwing out a patrachute, and the sudden loss of speed can catch you by surprise if you aren't expecting it.
I posted this about the ESC on another forum;
quote:
ORIGINAL: Doc Austin
I'm using the Castle Creations Phoenix 60 ESC. In the beginning I didn't know how to program it, and with no engine brake the motor would idle so fast that you could hardly land. I dialed in 10% brake and that fixed it, but it also created an interesting phenomenon.
Now the engine keeps turning, but slower, and the prop acts like a giant "air brake." I can come in really hot, snap the throttle back and it's like throwing out a parachute. Another cool thing it allows me to do is use a stall turn (or almost any other low turning maneuver) as a final approach, and the plane won't pick up much speed on the down leg. Generally I have always carried a little power on the leg in, which is now essential to keep the brake from engaging, but with power and "brake" it's effortless to spot land the thing with ridiculous accuracy.
However, you have to be careful that you don't stall the plane really deep with the "brake" on. When the nose falls forward, the braking action won't allow the plane to gain any airspeed. The plane simply drops, (which isn't good if you are low to the ground). You have to either give it alot of power or put the nose way down (which isn't good if you are low to the ground) so it picks up airspeed. If you just leave the nose level, the prop holds the plane back, and it will fall out of the sky. On my first 25E I pulled the power back and turned really hard low to the ground (my standard final approach). The turn scrubbing off speed and the "braking" action slowed the plane down much faster than I expected, and the plane fell right out of the sky and knocked the firewall out. This caught me completely by surprise, and it took awhile to figure out what had happened, but now I use the braking action to my advantage.
Another cool trick is that the speed controller will buzz when the "brake" is being employed. The faster the plane is traveling, the harder the air turns the prop against the "brake," and the louder the ESC will buzz. I like to dive the plane straight down from almost out of sight, with the throttle pulled back. The combination of the air rushing over the plane and the ESC howling is a very tortured, frightening sound. The first time it happened I almost threw the transmitter down and started running!
< Message edited by Doc Austin -- 11/30/2006 1:34:30 AM >
Matt Murdoc
(in reply to lionel2341)
       Post #: 208
RE: E-Flite Mini Pulse XT Owner's Club - 11/30/2006 2:42:22 AM
gsk11740
Status: offline
Kind of like the JU-87 Stuka? I never heard one of course (are there any left flying?) but my Dad who was stationed in England during WWII said it was a horrible sound that you never forgot.
Gary.
(in reply to Doc Austin)
       Post #: 209
RE: E-Flite Mini Pulse XT Owner's Club - 11/30/2006 9:34:08 PM
zoott
Status: offline
What wheels do you guys find work the best? Did you get the skirts to work with them?
       Post #: 210
RE: E-Flite Mini Pulse XT Owner's Club - 12/1/2006 6:26:32 AM
ADChobbystore
Status: offline
I went with 2-1/4" foamies. No wheel pants.
adchobbystore.com
(in reply to zoott)
       Post #: 211
RE: E-Flite Mini Pulse XT Owner's Club - 12/1/2006 5:14:48 PM
ADChobbystore
Status: offline
Hey bzizzi,
I got a Cellpro 4S for my dad to go with his plane for Christmas. It looks like the Cellpro is setup to charge thru the balancing plug. Have you had any problems with this? Does it work out ok? And did you have to get an adapter to get the Thunder Power batteries to charge? I currently have an Astroflight 109 and it charges thru the regular plug, not the balancing plug.
adchobbystore.com
