YS 140, on 73". what prop???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> YS 140, on 73". what prop???
Page: [1]
Login
YS 140, on 73". what prop??? - 9/1/2006 9:58:22 AM
Gimble Bender
Status: offline
Rezagh,
Could you ask QQ what prop he ran on his 73" with the YS 140? I don't know how to prop it best for 3D. I would like to know the brand and size he recommends.
I have a Mejzlik 18X8 on it now but it won't work. My rpms are right where they should be but vertical pull out from a hover is very, very, very slow. . I can fine tune the mixture some more but it won't make that big of a difference. I'm hoping I'm just way off on the prop. It was what I had so I tried it.
Any one else have any ideas?
GB
_____________________________
Built for go, not for show.
       Post #: 1
RE: YS 140, on 73". what prop??? - 9/1/2006 12:24:15 PM
randy racer
Status: offline
gb i thought the Mejzlik was a 18-6?? if i haven't sold my 3W 28cc with my collection of props by this week end you can try some of them on at the Kennett fly in. i have a 18-8, 18-10 Xoar and a 18-8 biela. if one of them will work fly it this week end and order some next week.
randy racer
Revver Bro #196
Ford RV Refrigeration Training Center & The RVRN
(in reply to Gimble Bender)
       Post #: 2
RE: YS 140, on 73". what prop??? - 9/1/2006 10:06:33 PM
arobatx
Status: offline
I have the slightly older 72" version, and I remember reading that QQ used an APC 17x8 on his. I have the 1.40 sport on mine, and run Cool Power 30% Heli, with the APC 18x6 and get just under 9000 RPM as desired. I have no issues pulling out from a hover.
Chad
(in reply to randy racer)
       Post #: 3
RE: YS 140, on 73". what prop??? - 9/1/2006 10:51:07 PM
Gimble Bender
Status: offline
quote:
ORIGINAL: randy racer
randy racer
It is an 18X6, my bad. I was at work and in a hurry. Got my props confused.
arobatx,
Mine is turning around 8600 on the ground with the Mejzlik 18X6 but it won't pull out vertical very well at all. Hmmmm.......??
       Post #: 4
RE: YS 140, on 73". what prop??? - 9/2/2006 4:35:48 AM
zope_pope
Status: offline
What model YS140? I have a DZ and up here at 6000' msl I am turning an APC 18x6W at 9300 rpm+! I run cool power 30% Heli.
I have never run a Mejlik, but I wouldn't expect it to drop that many rpm's.
If you choose not to make a decision, you have still made a decision.
       Post #: 5
RE: YS 140, on 73". what prop??? - 9/2/2006 7:53:43 PM
Gimble Bender
Status: offline
Mine is the 140 sport.
GB
(in reply to zope_pope)
       Post #: 6
RE: YS 140, on 73". what prop??? - 9/3/2006 4:02:55 AM
merlin3
Status: offline
18x6 is the recommended prop and what quique runs. surprisingly my 140l likes the cheapo zinger 18x6 better than the apc 18x6w. It seems to have a lot better pull out.
QQ yak 54 73" , raptor 50, vigor cs, trex 450xl
       Post #: 7
RE: YS 140, on 73". what prop??? - 9/4/2006 2:46:16 AM
Gimble Bender
Status: offline
Thanks merlin,
I have an 18X8 Zinger, but didn't try flying with it, I'll pick up an 18X6 and see how it does.
(in reply to merlin3)
       Post #: 8
RE: YS 140, on 73". what prop??? - 9/20/2006 7:21:28 AM
zope_pope
Status: offline
Any results on the Zinger?
       Post #: 9
RE: YS 140, on 73". what prop??? - 9/20/2006 2:39:38 PM
arobatx
Status: offline
Hey Guys,
This past weekend I tried a Zinger Pro Series 18x6, and I found the same result that Merlin3 did with his 1.40L. Mine is the 1.40 Sport but I gained a couple hundred RPM with this prop compared to the APC 18x6w, and it spools up quicker. I am using the CP 30% heli fuel, and it's turning 9100rpm.
Chad
       Post #: 10
RE: YS 140, on 73". what prop??? - 9/21/2006 1:11:53 AM
zope_pope
Status: offline
More thrust with the increase of Rpms? Or just more Rpms? i need a bigger prop as the recommended range for my dz is 8000-8500.
(in reply to arobatx)
       Post #: 11
RE: YS 140, on 73". what prop??? - 9/21/2006 2:37:23 PM
arobatx
Status: offline
Zope Pope,
Get yourself a Skorepa 18x6 wood for your DZ. I think you will find this prop very hard to beat.
Chad
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
