Wooden Blades for 36
Tower Hobbies
Logged in as Guest
  Printable Version
MS Composit Hornet X-CP ARF w/Brushless Motor
Seller:  Erick Royer
Details:   $100.00   |  9/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> Wooden Blades for 36
Page: [1]
Login
Wooden Blades for 36 - 9/1/2006 3:45:11 PM
higgy1541
Status: offline
I have just purchased some wooden blades for my 36. I got them from HeliDirect, you can see the blades here . I have just recieved them and they have got a white plastic covering on them. Does the whole white film need to be peeled off or do you just need to make a whole for the bolt to go through?
James
_____________________________
Check out my newly updated profile, with all my models!
       Post #: 1
RE: Wooden Blades for 36 - 9/1/2006 3:55:36 PM
sweetrevenge7800GTX
Status: offline
The whole film needs to be removed.
(in reply to higgy1541)
       Post #: 2
RE: Wooden Blades for 36 - 9/1/2006 3:57:26 PM
higgy1541
Status: offline
Ok thanks, Just didnt want to go ripping it all off to find out i ruined a set of blades.
(in reply to sweetrevenge7800GTX)
       Post #: 3
RE: Wooden Blades for 36 - 9/1/2006 7:38:20 PM
E_Heli
Status: offline
Don't rip it off, they used to use clear covering and I have couple set from them. Now they use the white covering, I would check the balance first, and check the tracking afterward.
       Post #: 4
RE: Wooden Blades for 36 - 9/1/2006 8:47:13 PM
higgy1541
Status: offline
ummmm, little bit late. I took the covering off one set. Does anyone else have experience with these blades?
(in reply to E_Heli)
       Post #: 5
RE: Wooden Blades for 36 - 9/1/2006 10:40:30 PM
Orion1024
Status: offline
Leave the plastic on - the blades are supposed to be covered. These blades work very nicely. However, they were a little too long inside the blade holder, so I had to remove some off the end with a Dremel. You should be able to cover them back up with the correct size shrink tubing.
       Post #: 6
RE: Wooden Blades for 36 - 9/1/2006 10:44:39 PM
higgy1541
Status: offline
I was thinking about just giving the blades with the stripped off covering a coat of clear lacquer.
(in reply to Orion1024)
       Post #: 7
RE: Wooden Blades for 36 - 9/2/2006 1:54:55 AM
sweetrevenge7800GTX
Status: offline
i ripped mine off and they worked just fine
       Post #: 8
RE: Wooden Blades for 36 - 9/2/2006 6:24:19 AM
higgy1541
Status: offline
quote:
ORIGINAL: sweetrevenge7800GTX
So the blades have no covering, they are just the bare wood?
       Post #: 9
RE: Wooden Blades for 36 - 9/2/2006 12:05:28 PM
sweetrevenge7800GTX
Status: offline
Yeah basicaly. but the work Very Well.
       Post #: 10
RE: Wooden Blades for 36 - 9/2/2006 8:55:39 PM
neweheliflyer
Status: offline
For No. 36 helicopter, this kind of blades are good - very durable.
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
