ailerons wider than trailing edge?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Aerodynamics >> ailerons wider than trailing edge?
Page: [1]
Login
ailerons wider than trailing edge? - 1/9/2003 7:14:40 AM
Wallrat
Status: offline
I'm currently modifying a Sig Seniorita to include ailerons. Given that this is a fairly slow flying aircraft, I'd like to make the ailerons as large as possible. The trailing edge is 1 1/8" wide. The ailerons I was thinking of adding are 1 1/4" wide and would extend 1/4" wider than the trailing edge. Would this create enough drag to be concerned about? Or would the pieces of trailing edge stock that I removed make decent ailerons for this aircraft?
Matt
_____________________________
Matt
       Post #: 1
ailerons wider than trailing edge? - 1/10/2003 4:55:28 AM
BMatthews
Status: offline
If these are full span strip ailerons then don't worry about it. The stock you remove will be just fine. If they are barn door types then perhaps make them a rib bay or two longer.
In any even extending them back by 1/4 inch wouldn't create any noticable difference other than to ensure a slightly snappier aileron response.
While you're at it you may want to incorporate some differential in the linkage so the up throw is more than the down throw for less adverse yaw on such a slow flying model.
Witty saying to be plagarized shortly.....
(in reply to Wallrat)
       Post #: 2
ailerons wider than trailing edge? - 1/10/2003 10:19:21 PM
Rodney
Status: offline
You would also benefit by removing most if not all the dihedral else the ailerons will be relatively ineffective.
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.191RCU2
