djay
Joined: 3/21/2003 From: Dubai, UNITED ARAB EMIRATES Status: offline
Hi, just set my twin sync up in my Top Flite DC3. I want to set it up so I can turn the unit on and off via the aux channel, to enable me to set the engines up, but when I plug the units aux channel lead into channel 6 of my rx, which is a on/off switch for the flaps, and set the twinsync to the correct seting, it does not do anything. The unit stays on all the time. The tx has been enabled on channel 6, and I use it for flaps on other models. The radio is a futaba 2.4 6 channel unit. The instructions are not absolutely clear how to plug the unit in and set it up regarding the aux lead. Any help would be appreciated. Darryl
_____________________________
I used to land in English cow poo, now I land in Camel poo. Plane still smells the same though.
