RE: Eletronic engine syncronizer **SUPPORT **
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Eletronic engine syncronizer **SUPPORT **
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Eletronic engine syncronizer **SUPPORT ** - 10/4/2006 7:48:50 AM
a1pcfixer
Status: online
quote:
ORIGINAL: wayneparrish
I don't have glow engies so I don't follow your reasoning ? Wayne
Well, generally neither gas engines nor electric would have your issue so I figured you must be running 2c or 4c.
For 2c or 4c, keeping the glow drivers on thru takeoff would greatly diminish any chance of flameout during those critical moments.
_____________________________
Jim L.
Learn from the mistakes of others.You won't live long enough to make all of them yourself. ClubSaito Member#445
(in reply to wayneparrish)
       Post #: 76
RE: Eletronic engine syncronizer **SUPPORT ** - 10/4/2006 1:42:45 PM
yl5295
Status: offline
There is no way to disable the dead stick idling the other engine as shipped. There is an option for turning the engine synchronizer off completely via an aux channel. Disabling the unit makes it the same as a "Y" cable which is effectively the same thing that I think you are asking for. I am open to adding an option for this in future software but there is a problem with the concept.
The unit will syncronize the engines. If one engine slows down it will pull the other one back. So even if I disabled the deadstick detection is would still pull back the good engine (slower than a deadstick though) to idle. So I don't see a way to sync the engines for take-off but disable the dead stick if one died.
One of the advantages of the unit is reducing the yaw effect of a failing engine. So if you have an airplane that could still climb out on one engine I think that sync disable via a toggle on an aux channel is probably the best but if you want a sync only when both running (i.e. otherwise throttles stay at stik position) we can discuss.
I think that the worst scenario would be if taking off from right to left and the left engine died as the plane went by the pits. This would try to yaw the airplane into the pits. The TwinSync would greatly reduce the risk of this example as it is currently. I think even a big stable gasser might be a handful just after takeoff on one engine at full power.
However, I can add a mode (there are still 3 modes that are not assigned) that will sync the engines only if both are running and otherwise moves the servos to the throttle stick position - completely disabling all of the failsafes. Let me know if you want this mode added. Would you want an AUX channel to add any other functionality to this mode?
Bill
< Message edited by yl5295 -- 10/4/2006 1:46:44 PM >
       Post #: 77
RE: Eletronic engine syncronizer **SUPPORT ** - 10/4/2006 2:37:07 PM
wayneparrish
Status: offline
Bill, I'll get with you on this. Wayne
(in reply to yl5295)
       Post #: 78
RE: Eletronic engine syncronizer **SUPPORT ** - 10/5/2006 3:51:43 PM
yl5295
Status: offline
BUG!!!!
NEW GLOW DRIVER BUG FOUND!
YES - Someone just found a new BUG (although minor or of no concern to most)!!!
1) The glow drivers come on in all modes except mode 5 (when plugs are controlled by an AUX CHannel) when RPM is sensed. They are supposed to come on for 10 seconds. They only stay on for 3.3 seconds. This will be updated back to 10 seconds in current software. No a big deal if using an electric starter but a problem for the guys that flip start.
OBSERVATION: Weak glow plug driver strength...
A few units have been observed to have a weak drive on the glow plug. This can be observed by comparing how bright the glow plugs are directly connected to the battery versus through the glow plug drivers on the TwinSync.
The reason is that there is a resistor (R3) that protects the TwinSync from damage should someone try to charge the glow plug batteries while they are connected to the TwinSync (NO ONE SHOULD EVER DO THIS AS IT MAY DESTROY THE TWINSYNC).
Depending on the value of this resistor it can limit the drive strength of the glow plug driver circuit. Manufacturing tolerances have caused some to be a little weak in the plug heat department.
If you want - you can remove/short out this (R3) resistor if you want to have "full heat" going to the plugs. BUT--- The device will have no protection then against overvoltage on the glow plug wires after that. So only 1 NiCD or 1 NiMh cell per driver circuit if you do this mod. I will be lowering the value of this resistor on all new units that ship or comeback for any reason.
Attached below is a diagram of which resistor to short out (solder a wire between the two leads) if you want to do this. (no it will not void your warranty - unless you completely destroy the unit then I will replace it at a minimal fee). Also attached is a picture of a wire soldered between the two legs on the back of the board showing the mod. The arrows point to each end where the wire is attached.
This is not something you have to do but just may WANT to do if you have weak plug heat.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by yl5295 -- 10/5/2006 3:56:49 PM >
       Post #: 79
RE: Eletronic engine syncronizer **SUPPORT ** - 10/8/2006 3:40:59 AM
a1pcfixer
Status: online
quote:
ORIGINAL: yl5295
BUG!!!!
Well, shoot, I reported this issue back on Post #39 on 9/15/06 [page 2 of this thread]
quote:
ORIGINAL: a1pcfixer
On board glow isn't giving enough juice to start engines. I'm running 2 Sanyo 1700 mAH in parallel,
and yes they were fully charged. I'll figure out this issue, but the above issue needs your assistance.
Will mine be updated for this, or had you shipped it back before finding/fixing this bug?
Jim L.
       Post #: 80
RE: Eletronic engine syncronizer **SUPPORT ** - 10/8/2006 12:49:07 PM
yl5295
Status: offline
Yours (as all that come back) will be updated before shipped back. The resistors will be replaced with more accurate 1% resistors with a better value to give full power and still protect the device.
Sorry about your post #39 but it wasn't clear that you had found an issue and needed help. Since you stated that you would figure it out.
(in reply to a1pcfixer)
       Post #: 81
RE: Eletronic engine syncronizer **SUPPORT ** - 10/9/2006 2:08:34 PM
yl5295
Status: offline
All,
as for the above modification. Please contact me at billw@nc.rr.com before making the mod if you have weak glow heat. MOST PEOPLE DO NOT NEED a change. Only a few units have weak plug heat. The glow plug drivers were tested on all of the shipped units and they were working well enough to pass a visual (i.e. is the plug bright?) test. Try yours before assuming that you may need this modification because chances are that you do not.
       Post #: 82
RE: Eletronic engine syncronizer **SUPPORT ** - 10/11/2006 4:51:00 PM
yl5295
Status: offline
All,
pending final testing this weekend software version 1.4 and an updated manual are now available. Earlier versions of the software is still fine for using/flying (no big problems found - only minor stuff). Anyway here are the updates/changes in version 1.4:
1) Added new throttle control algorithm to eliminate oscillations at all RPM ranges, faster tracking of engine RPM in the event of engine problems, and faster dead stick response time.
2) New Mode 6 added to disable dead stick function
3) Glow plug battery voltage detects low battery now at 1.0V rather than 1.2V
4) RPM now must be >1500 rpm synchronize (was >0 rpm previously)
5) Runs glowplugs now for 10 seconds after RPM sensed (was 3 seconds)
6) Programmed idle point is now where throttles are moved with loss of transmitter signal (was previously KILL)
7) PCM lockout capability now expanded to support frame rates as low as 25 fps (now works with Multiplex Radios)
8) Glow plugs can not come on now when transmitter is turned off
9) Programmable for use with one or two magnets (contact tech support for info)
10) Programmable Sync accuracy (contact tech support for info)
11) Remote display is now enabled by default and remote glow led is disabled
All units shipping from RCS will all have this new 1.4 version of software. All chips/units returned (that you have not gotten back yet) will get this new version. Make sure to only use the manual that matches the version of software that your device has. I don't expect any updates in the near future for the Twinsync after this release of software (i.e. this should be the last one for a while).
Bill
< Message edited by yl5295 -- 10/11/2006 4:52:37 PM >
       Post #: 83
RE: Eletronic engine syncronizer **SUPPORT ** - 10/17/2006 8:07:13 PM
yl5295
Status: offline
An update to everyone:
RCShowcases next batch of inventory shipped today including Remote displays, and TwinSyncs with and with out glow drivers (no reason for gas guys to have to buy glow drivers). They had software version 1.4.1 on them.
Also today I shipped all units and chips that had comeback to me for software upgrades with 1.4.1 software on them.
Software version 1.4.1 is the same as version 1.4 described above but adds one thing. It requires an engine to be at >1500 rpm for 0.5 seconds before it declares that the engine is running. The reason for this is the following:
Say an engine dies while flying and it idles the other. You get control of the plane and bring the stick back to idle and throttle up the running engine. If the dead engine's prop spins or vibrates in front of the sensor before this change it could declare both engines running and try to sync them. Then when no rpm is sensed on the dead engine it would idle the running engine again. This latest change prevents the unit from idling a running engine under stick control after a deadstick unless it spins at >1500 rpm for >1/2 a second.
Bill
       Post #: 84
RE: Eletronic engine syncronizer **SUPPORT ** - 10/19/2006 5:35:52 PM
Acetronics
Status: offline
Hi, Bill
I just have a little question : my Twinsync was to be shipped those days ... how to know the Soft release ??? a sticker somewhere ???
Will you update THE manual too ???
Alain
       Post #: 85
RE: Eletronic engine syncronizer **SUPPORT ** - 10/19/2006 7:25:43 PM
yl5295
Status: offline
If you placed an order with RCS and have not received your unit yet it will come with 1.4.1. If you already have your unit it is 1.2.X unless you have gotten an update.
(in reply to Acetronics)
       Post #: 86
RE: Eletronic engine syncronizer **SUPPORT ** - 10/19/2006 11:21:26 PM
a1pcfixer
Status: online
quote:
ORIGINAL: yl5295
Bill
Just got mine back, and that remote display is cute & compact. Good job!
With the updates you did to mine, should I figure I'm starting with a new unit (ie, my settings/tweaks are now back to stock)?
Also; will RC Showcase or you, be posting the updated Owners Guide soon for version 1.4.1?
Jim L.
       Post #: 87
RE: Eletronic engine syncronizer **SUPPORT ** - 10/20/2006 12:30:41 AM
yl5295
Status: offline
I will email it to you....
Please send me an email so I can reply to it with the manual attached at billw@nc.rr.com.
I am talking to them now about one other potential change (no functional difference - just something to help with customer support) that may result in them posting a 1.4.2 rather than a 1.4.1 manual. You will need the manual that matches your unit though.
< Message edited by yl5295 -- 10/20/2006 12:31:41 AM >
       Post #: 88
RE: Eletronic engine syncronizer **SUPPORT ** - 10/20/2006 7:15:41 AM
a1pcfixer
Status: online
Bill,
e-mail address on it's way.
Jim L.
