RE: Eletronic engine syncronizer **SUPPORT **
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Eletronic engine syncronizer **SUPPORT **
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: Eletronic engine syncronizer **SUPPORT ** - 1/8/2007 2:28:27 AM
bhdutch
Status: offline
Bill,
I'm not sure if this has been covered but....
I will be running two twin cylinder engines, two engines, 4 glow plugs.
Can I run each engines glow drivers in parallel to provide glow to both plugs without problems?
Dutch
(in reply to yl5295)
       Post #: 176
RE: Eletronic engine syncronizer **SUPPORT ** - 1/8/2007 10:51:44 AM
Acetronics
Status: offline
Hi, Bill
First of all ...Wish you a Happy new year !!!
Here is one more reason for an external slave Glow module !!!
Bench testing showed Twinsync works really great ( might be too many options available ... LOL )
Your processors are really nice chips ... So, I've started learning about them
Once more : Thanks and congratulations !!!
Alain
(in reply to bhdutch)
       Post #: 177
RE: Eletronic engine syncronizer **SUPPORT ** - 1/8/2007 3:40:19 PM
yl5295
Status: offline
Yes you can run the two plugs in parallel on each engine. So two plugs per glow driver circuit. The Transistors are rated at 11AMPS.
Bill
       Post #: 178
RE: Eletronic engine syncronizer **SUPPORT ** - 1/15/2007 6:00:57 PM
yl5295
Status: offline
Guys,
A couple of guys have found a receiver with a minor issue when used with the TwinSync. The Hitec RCD-3500 receiver has a minor issue. If the transmitter is very close to the receiver with the antenna fully extended you can get some glitching. Fix is to put a resistor in the throttle signal lead (orange wire) between the Twinsync and the receiver with a value of 1.5 - 7.5K ohms. Email me if you have this receiver and I will send you a modified cable at no cost.
       Post #: 179
RE: Eletronic engine syncronizer **SUPPORT ** - 1/15/2007 11:55:03 PM
orcrest
Status: offline
Hi
Is there a new manual out yet in PDF for download with the latest firmware changes for 1.4.3?
Cheers
Da Orc
       Post #: 180
RE: Eletronic engine syncronizer **SUPPORT ** - 1/16/2007 7:22:45 PM
yl5295
Status: offline
I can email you the 1.4.4 manual but you need the manual that matches your unit.
(in reply to orcrest)
       Post #: 181
RE: Eletronic engine syncronizer **SUPPORT ** - 1/16/2007 10:05:56 PM
orcrest
Status: offline
OK
I have the unit from RCS that came with version 1.2 IC. You are sending me out an IC with 1.4.3 I thought (or 1.4.4 if that is the latest version). I've been following the thread but it's confusing keeping up with all the different versions.
Cheers
Da Orc
       Post #: 182
RE: Eletronic engine syncronizer **SUPPORT ** - 1/16/2007 10:12:45 PM
yl5295
Status: offline
No problem. I will inlude the manual with the chip. You really only need to know what version you have and have the matching manual.
       Post #: 183
RE: Eletronic engine syncronizer **SUPPORT ** - 1/19/2007 2:41:26 AM
Heli-NuBee
Status: offline
Hi guys,
I am almost finished with my Nitro Planes P-38 which will be powered by two OS 91 FS engines. I have been flying RC for more than 35 years but this will be my first twin engine plane. Bill Wike's new twin sync device had a lot to do with my decision to now build a twin engine airplane. It seems to me that flying a twin engine plane with this device should be no more risky than flying any good scale single engine aircraft. I believe the new device will bring many more new twin engine flyers to the table because we can have much more confidence that we will be sucessful. Bill's support of the device is also an important part of the sucess formula. He has proven to me just how helpful and suportive he is. I had a problem getting one of my glow drivers to work on my twin sync earlier this week and Bill took the time to try to work through the problem with me on the phone. We could have done a little further testing and checking but I was to chicken to do anything directly on the circuit board. So I returned it to Bill for review and he found the problem and has shipped it back to me already. As he suspected, there was nothing wrong with the device but one of the orange wires was cut or broken about one inch from the end. I have to say that is outstanding service and support and I am so happy to have folks like Bill Wike in out hobby.
Best wishes and good safe flying to all.
Heli-NuBee(Roger)
       Post #: 184
RE: Eletronic engine syncronizer **SUPPORT ** - 1/20/2007 1:49:35 AM
Pilot44
Status: offline
Bill,
OK, got a KMP B25 on the board, using 2 RVC 91CD's. I need the full house stuff you have. Like our gal in the Dukes of Hazards (Jessica) says. " I totally don't know squat about this stuff. But I wan it."
Will figure it out.
Check out the picture of the Tru-turn hub I will be dealing with and advise as to how to install magnets here. In the center washer or outer hub itself. For some reason your email addy came back as undeliverable.???
I think with the LED display I need to order the sync from you, Glo driver version. Shoot me a PM or mail and we can get it done. Thanks
Jim
Click to see fullsize image.
Click for fullsize
< Message edited by Pilot44 -- 1/20/2007 1:53:16 AM >
(in reply to Heli-NuBee)
       Post #: 185
RE: Eletronic engine syncronizer **SUPPORT ** - 1/20/2007 2:51:30 PM
yl5295
Status: offline
Pilot44,
I got your email and will respond to it. Sorry my inbox was full the reason you got the error message but I still got your email.
For everyone if you do not have spinners or are using prop saftey nuts/hubs there are two options that I recomend:
1. Put an alumium or fiberglass (PCB materal available from Radio Shack) disk behind the prop and mount the included magnet in it.
2. Order from me a pair of diametric magnets ($2.50 per pair). Then you drill a 1/8" hole in the front of the prop hub on the engine parallel with the crankshaft and expoxy them into the prop hub.
I know of people that ground a flat spot on their prop hub and just JB welded the magnets to that. That scares me a little that it could fly off so I don't recomend that. Pressing the magnets into a drilled hole on the prop hub might be ok though.
(in reply to Pilot44)
       Post #: 186
RE: Eletronic engine syncronizer **SUPPORT ** - 1/20/2007 3:57:01 PM
n9331v
Status: offline
Where would someone order the twin sync from and does anyone know if they make one for a gas engine twin??
Web site or phone would be great.
_____________________________
Mooney N9331V
       Post #: 187
RE: Eletronic engine syncronizer **SUPPORT ** - 1/20/2007 4:52:32 PM
yl5295
Status: offline
You can order them from RC Showcase or from me direct. Their web site is http://www.rcshowcase.com or you can email me at billw@nc.rr.com Please do not send me RCU PMs since I often do not have computer access and I can respond to emails from my PDA.
The Twinsync is programmed for GAS engines as the factory default. The only difference in GAS and glow is the timing/engine response time curves. Using the factory default timing settings work fine on gas or glow. However, if you speed it up a little when used with glow engines it reduces time to sync from about a second to about 1/4-1/2 a second.
< Message edited by yl5295 -- 1/20/2007 4:55:01 PM >
(in reply to n9331v)
       Post #: 188
RE: Eletronic engine syncronizer **SUPPORT ** - 1/20/2007 6:42:09 PM
n9331v
Status: offline
Thank you, just ordered one from rc showcase. Will install it in my KMP B25 with gas G20ei's
Click for fullsize
Mooney N9331V
