Yo-yo problem solved
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Yo-yo problem solved
Page: [1]
Login
Yo-yo problem solved - 9/2/2006 10:09:38 PM
rawvoodoo
Status: online
I to k my heli to a Hobby shop in a town near me. The owner has been flying competitively for 17 years. My local shop is more concerned with planes and cars. This guy knows his stuff. I had him fly it a bit in the store and he told me what my problem is....ME. I just need more practice. He trimmed it up a bit and hovered it rock solid. None of the yo-yo stuff I have been dealing with. So the only explanation is that I need more experience flying. I also just deactivated the detents in the throttle stick, he said that would help immensely.
       Post #: 1
RE: Yo-yo problem solved - 9/2/2006 10:13:27 PM
j beede
Status: offline
Rudder management with no detents in the the throttle stick can be tricky. Did you try putting a piece of heat shrink tubing on the end of the detent spring to lighten the detents?
...j
(in reply to rawvoodoo)
       Post #: 2
RE: Yo-yo problem solved - 9/2/2006 11:29:34 PM
Gonwee
Status: offline
Don't loosen the spring, you adds some fuel tubing to the metal strip in the transmitter, that will get rid of the ratchet and still let you hold the throttle in position when using the rudder.
(in reply to j beede)
       Post #: 3
RE: Yo-yo problem solved - 9/3/2006 1:09:27 AM
Psikelly
Status: offline
I actually find that the ratcheting helps me from moving the throttle while operating the rudder
_____________________________
NO I did not just crash!! Im making it flop around on the ground like that on purpose. Its a new stunt.
(in reply to Gonwee)
       Post #: 4
RE: Yo-yo problem solved - 9/3/2006 2:03:05 AM
Truglodite
Status: offline
yeah, with the fuel tubing in there, sometimes stick movement is so smooth it's hard to notice yourself changing collective while jockeying the tail. it is a good idea to get used to flying without the detent though, since controls are ultimately more precise without detent.
a good pilot can even get a rock to fly smooth, so you may still want to experiment with your throttle curve. i've flown my heli with all sorts of throttle curve settings and have found that higher pitch/lower RPM tend to be less sensitive around hover. that will help make the yoyo less snappy if you will.
whew, r/c used to be so much simpler.
(in reply to Psikelly)
       Post #: 5
RE: Yo-yo problem solved - 9/3/2006 2:18:08 AM
ct420
Status: offline
Eventually, you will stop thinking of the left stick as two different movements (throttle + rudder). When I fly now, the movement of the left stick seems more like a single movement in both axis to me. I have gotten very used to adjusting for tail drift when climbing, falling, etc. that when I want more throttle, I 'automatically' add in the correct amount of rudder without even thinking about it.
Once you hit this stage, you will probably find that you are 'fighting' the clicks on the throttle to get the heli to move exactly how you wish it to. At least, this is how it is for me. Of course, I have never liked the clicks on the throttle stick. Not even with planes, etc. I have always put fuel tubing on it to make it smooth.
Yah, I just roll like that...
(in reply to Truglodite)
       Post #: 6
RE: Yo-yo problem solved - 9/3/2006 3:07:00 AM
jltray
Status: offline
I agree, I have only been flying my BCX for a couple of weeks, but the clicking prevents me from finding that perfect hover.
I have also noticed that flying is not just a single change in any one stick axis, but a combination of all the controls to get the CX to go where I want it to go. I plan on removing my clicking tomorrow and seeing how I do after that.
I understand having the throttle lock into helps, but you never take your fingers off the sticks.
I let my sister and niece try to hover tonight and I'll be putting on the training gear tomorrow for them.
Jimmy
Jimmy T.
(in reply to ct420)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.078RCU1
