georgeb3dr
quote:
ORIGINAL: barracudahockey When you say "moves right" do you mean it drifts right or it tries to spin like a top? Hmmm...I'm going at fairly low speeds, as I don't want to lift off that way, so as it start to lift off, I stop. But I punched it a couple of times and the faster the main rotors went, the faster, and more forceful the tail would rotate to the right. So, it's not slight drift, that you can adjust with trim (I assume)...it seems to be tied to main rotor speed. Did I mess up the belt? When I turn the main blade clockwise, the tail rotates counterclockwise, up into the downwash, and I thought that was correct?
