grotto2
FL, USA Status: offline
quote:
ORIGINAL: microsprint9 grotto2 I see your right near the heart of racing land, you should find your nearest sprint car track, those cars go thru 30-40 gal of methanol a night, i'm sure you could split your shipping with one of these guys as during the season they probably go thru 10 55gal drums. Ha-Ha! Methanol I can get. Nitro's always the problem. In case anyone's curious, we emptied the two drums in two evenings directly into reclaimed jugs. About 10% of the jugs developed pinhole leaks, but I have plenty of spares. This was a two man job, although the wives pitched in a bit. We have a wooden frame with a bolt-on ramp made of two boards. We screw in a standard water faucet first, and then the two of us lay the drum on it's side and roll it up the ramp. There's a mark on the ramp where you have to have to start the faucet at to assure it will be in the right place when it rolls over into it's cradle. We empty the drum through a funnel that has a stainless filter in it. The very last gallon requires tha |
