RE: BUILDING A WOODY 47IN V
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> RE: BUILDING A WOODY 47IN V
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: BUILDING A WOODY 47IN V - 2/13/2007 9:27 PM
rob_crash24
Score: 100
Last Login: 1/1/2010
Status: offline
yeh but what do i need to bye to make one hoe do i conect the engine to a prop ?
Hide Signatures
(in reply to da mad maori)
       Post #: 226
RE: BUILDING A WOODY 47IN V - 2/14/2007 12:51 AM
fastguy
Score: 100
Last Login: 6/25/2007
Status: offline
when i started i was wondering that also well the weed eater has a little shaft that has a square end that fits into the weed eater on the other side there it is soldered to a little brass thingy whitch is attached to the prop shaft im sure that some other guy will show u a picture
Hide Signatures
(in reply to rob_crash24)
       Post #: 227
RE: BUILDING A WOODY 47IN V - 2/14/2007 12:55 AM
bentley marshall
Score: 105
Last Login: 3/18/2010
Status: offline
hi you should be asking this in a new post as not every one reads this one or do a search for what your looking for go back and lookthru my pics you might find what your looking for
Hide Signatures
(in reply to fastguy)
       Post #: 228
RE: BUILDING A WOODY 47IN V - 2/15/2007 1:04 PM
STEVE MARSHALL
Score: 100
Status: offline
Hi All, I am back from work and hanging out to go out to the shed, I am only home for 5 days so I will see how much i get done. Will post pics as they are taken.
Steve.
Hide Signatures
(in reply to bentley marshall)
       Post #: 229
RE: BUILDING A WOODY 47IN V - 2/15/2007 8:32 PM
bentley marshall
Score: 105
Status: offline
welcom back bro check out the goodies i got for mine!!!
Hide Signatures
(in reply to STEVE MARSHALL)
       Post #: 230
RE: BUILDING A WOODY 47IN V - 2/15/2007 9:33 PM
fastguy
Score: 100
Status: offline
well now i have the plans iamready to go to the store i made mounts for my homelite i will order hardware from whh on tuesday i want to buy the wood now cut it out tomaro and stich and glue does anny one know how mutch time it takes to finish the hull
Hide Signatures
       Post #: 231
RE: BUILDING A WOODY 47IN V - 2/15/2007 10:33 PM
bentley marshall
Score: 105
Status: offline
lots of time
Hide Signatures
       Post #: 232
RE: BUILDING A WOODY 47IN V - 2/16/2007 12:28 AM
fastguy
Score: 100
Status: offline
well how mutch time i dont have to go to school or work i will cut everything out with a jig saw
Hide Signatures
       Post #: 233
RE: BUILDING A WOODY 47IN V - 2/16/2007 12:30 AM
bentley marshall
Score: 105
Status: offline
you can only do it in stages you have to wait for glue/resin to dry befor you go on to the next bit
Hide Signatures
       Post #: 234
RE: BUILDING A WOODY 47IN V - 2/16/2007 12:35 AM
fastguy
Score: 100
Status: offline
ever hear of five munite epoxy aqnd airplane glue(ca)
Hide Signatures
       Post #: 235
RE: BUILDING A WOODY 47IN V - 2/16/2007 12:37 AM
fastguy
Score: 100
Status: offline
how long did it take you and your brother to finish?
Hide Signatures
       Post #: 236
RE: BUILDING A WOODY 47IN V - 2/16/2007 12:46 AM
bentley marshall
Score: 105
Status: offline
we are still not finished we have to work for a living
Hide Signatures
       Post #: 237
RE: BUILDING A WOODY 47IN V - 2/16/2007 12:49 AM
STEVE MARSHALL
Score: 100
Status: offline
Hi Fastguy, you wont have it made in 5 mins, it takes time, dry fit all the pieces first and make sure they are all square and fitting corectly, then glue and clamp or screw. After it is all glued up you have to fiberglass all the inside joins to make it stronger. Then seal it and paint,fit the motor and running gear. I would say working on it every day it will take about 3 weeks. (don't rush it or you will end up with a piece of crap.)
Steve
Hide Signatures
       Post #: 238
RE: BUILDING A WOODY 47IN V - 2/16/2007 12:52 AM
fastguy
Score: 100
Status: offline
that was what i was thinkindg race u to the water
Hide Signatures
       Post #: 239
RE: BUILDING A WOODY 47IN V - 2/16/2007 1:24 AM
da mad maori
Score: 100
Last Login: 3/19/2010
Status: offline
ya can cheat to speed things up....
i put the frame, bottom, sides on with blobs hot glue here and there just to keep it together and lined up then hit the inside with resin
you'll get alot of a**l retentive "pro" boat builders who'll say "oh no you cant do that, you have to do it properly with stones and sticks and the the gut lining from a wilderbeast"
but it works ive built two like this and even rammed another chaps boat with it and i came out with no cracks or seems coming apart only a dent in the resin
try it!
(hot glue that is...not ramming someone elses boat)
Hide Signatures
       Post #: 240
RE: BUILDING A WOODY 47IN V - 2/16/2007 1:32 AM
fastguy
Score: 100
Status: offline
sure i will try that how long does it take?
Hide Signatures
       Post #: 241
RE: BUILDING A WOODY 47IN V - 2/16/2007 1:39 AM
da mad maori
Score: 100
Status: offline
to cut out patterns.....couple of hours
to stitch the frame, bottom and sides together...15mins then hit the inside with resin
for the resin to dry....over night
half ya boat done in one day!!
Hide Signatures
       Post #: 242
RE: BUILDING A WOODY 47IN V - 2/16/2007 1:40 AM
da mad maori
Score: 100
Status: offline
even what Steve said... use screws
Hide Signatures
       Post #: 243
RE: BUILDING A WOODY 47IN V - 2/16/2007 1:43 AM
bentley marshall
Score: 105
Status: offline
do it the maori way glad im not one
Hide Signatures
       Post #: 244
RE: BUILDING A WOODY 47IN V - 2/16/2007 2:01 AM
da mad maori
Score: 100
Status: offline
im only halfcast so its not that bad
nothing wrong with abit a rangi work
Hide Signatures
       Post #: 245
RE: BUILDING A WOODY 47IN V - 2/16/2007 2:31 AM
bentley marshall
Score: 105
Status: offline
lol
Hide Signatures
       Post #: 246
RE: BUILDING A WOODY 47IN V - 2/16/2007 7:57 AM
fastguy
Score: 100
Status: offline
just printed the plans about 100 pages i cut out some of the patterns wow it is 11:34 and i only cut 1 of the bulk heads and i still have to tape all the pages together does any body know a short cut please tell me
Hide Signatures
       Post #: 247
RE: BUILDING A WOODY 47IN V - 2/16/2007 8:34 AM
STEVE MARSHALL
Score: 100
Status: offline
Hi everyone, Today I got all the glass work done and the prop,rudder,flexshaft assy arrived in the mail. Now i need some bright spark to tell me how to set it up, should i space it further back off the transom so i have some flex shaft out the back of the boat? Do i set the prop square with the boat or angle it up or down a bit? I know i have to run the shaft right in the bottom of the v in the transom.
Steve
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 248
RE: BUILDING A WOODY 47IN V - 2/16/2007 9:24 AM
w3bby
Score: 100
Last Login: 3/11/2010
Status: offline
quote:
ORIGINAL: fastguy
...does any body know a short cut please tell me
Buy an RTR
quote:
ORIGINAL: fastguy
this is my next prodject
Don't stick that together with hot glue
The faster epoxies do not have the penetration of the slower epoxies, it is your choice.
Steve, set it up as it is to start with. Give yourself the ability to raise and lower the strut and adjust the angle once the boat is on the water and running. Your base line should be the strut parallel with the bottom of the boat.
_____________________________
Ian
Hide Signatures
       Post #: 249
RE: BUILDING A WOODY 47IN V - 2/16/2007 9:55 AM
VH-GMB
Score: 100
Last Login: 1/20/2008
Status: offline
quote:
ORIGINAL: fastguy
time here is 12:49 night what time is it in austraila_wait steve is in austraila bently is in new zeland ?????
It's 8.50 pm here in Australia.
Sorry to Interupt Guy's but I'm watching this thread eagerly, and have decided to build one of my own. I like the one that da mad maori is building, as soon as I can track down some plans, I'll get started. The scale Helies are too expensive.
Cheers.
Hide Signatures
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.141RCU1
