RE: fs 70 on 30%
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler for Saito's
Seller:  RC Specialties
Details:   $49.95   |  10/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: fs 70 on 30%
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: fs 70 on 30% - 9/13/2006 8:21:13 PM
loughbd
Status: offline
I use the Enya #3 in all my glow engines, two and 4 cycle. Best plug made in my opinion. Been using them since introduced to them while living in Japan back in the late 70's and early 80's.
(in reply to DarZeelon)
       Post #: 26
RE: fs 70 on 30% - 9/13/2006 9:38:47 PM
RC-Bearings
Status: offline
Just to throw another log on the fire, I used the K&B 1L while racing!
quote:
ORIGINAL: DarZeelon
So you see, Hugh?
I did not even know the K&B-4C and the Thunderbolt FS plugs existed...
This is interesting stuff!
_____________________________
Steel and Ceramic bearings for model engines
http://www.rc-bearings.com
       Post #: 27
RE: fs 70 on 30% - 9/14/2006 4:12:09 AM
FlyerBry
Status: offline
When running my Saito .82 on 30% what impressed me the most is not so much the increase in top RPM, but the increase in torque. The engine simply powers through climbs without slowing down on the 30% where with the 15% the engine makes good power but it eventually poops out on a straight-up climb. All I can say is the difference is quite noticable - enough that I will miss it when I switch back to 15%.
I have to also point out that the subject of this thread refers to the O.S. .70 FS. I have one of these as well and never even considered trying higher nitro content in this engine. It has never struck me as a powerhouse of an engine. It's greatest quality really is its reliablity. To run 30% in this engine is kind of like souping up a Honda Civic. I have never really gotten into that fad but to each his own!
(in reply to RC-Bearings)
       Post #: 28
RE: fs 70 on 30% - 9/14/2006 6:21:33 AM
RC-Bearings
Status: offline
quote:
ORIGINAL: FlyerBry
Well, you did it with the Saito and look at the results! The OS will respond the same way.
(in reply to FlyerBry)
       Post #: 29
RE: fs 70 on 30% - 9/14/2006 7:13:25 AM
DarZeelon
Status: offline
Paul,
There should be a way to put a limit on this...
Because methanol has a best power stoichiometric ratio of about 5:1 and nitro runs at 0.5:1 - 2.5:1, the more nitro you have in your fuel, the more fuel your engine will 'drink'...
Using 40% nitro, you use fuel at a rate ~2.5 times higher than if you run 0-5% nitro.
Using FAI fuel (0% nitro), you are already using fuel at a rate ~2.5 higher than gasoline (best power stoichiometric ratio of about 12.5:1).
Glow fuel with 0-5% nitro already costs 3 times as much as gasoline.
Even with no-to-low nitro, each and every one of us is paying 3 times 2.5, or 7.5 times more for fuel, than if he was running on gasoline. With 30% fuel costing over 3 times as much, each of us would be paying 22 times as much for fuel.
40% nitro fuel is currently not offered by Tower and I had trouble finding it elsewhere too, but it would bring the fuel cost up to over 30 times the equivalent gas cost...
Do we all want to make this hobby more affordable, or do we want to make R/C the the hobby equivalent of living in Beverly Hills, owning a private Learjet and a yacht and touring the whole universe, while earning a current median level salary?...
We don't all drive a 'top-fuel dragster' to work. In fact, none of us do.
Let us all regain our sanity...
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
       Post #: 30
RE: fs 70 on 30% - 9/14/2006 9:02:54 AM
RC-Bearings
Status: offline
quote:
ORIGINAL: DarZeelon
Paul,
Dar,
This is a HOBBY. It is for your disposable income, not your food money. I am not telling anyone they HAVE to use 40% nitro fuel, only that it DOES work and works well with many engines. And I don't think there should be any limits placed on modelers.
       Post #: 31
RE: fs 70 on 30% - 9/14/2006 10:06:29 AM
DarZeelon
Status: offline
quote:
ORIGINAL: RC-Bearings
Yes, Paul. I agree it is a hobby and this is exactly the point.
Since it is just a hobby, we all have some sort of a budget dedicated to it.
If we use this budget to fly each weekend; say, making 5-6 ten minute flights on 5% nitro, we would enjoy ourselves very much.
If we would use 40% fuel instead, we would be using the same budget to finance 2-3 five minute flights each weekend.
And we would be replacing/overhauling our engines after half the time period.
And all we would gain is about 5% in flight speed and a better climb rate...
I think the second option would be way too short in duration, to make the enjoyment equivalent to the first option; even with that (obviously insignificant) 'adrenalin rush' from that added speed... After all, you're going just a bit faster, not twice as fast.
And... if you want the additional speed, you could have it at a small fraction of the additional flight hour cost, by just using (buying it in the first place) a slightly larger engine and high-pitch props, still using 5% nitro.
Your model will not know the difference, will fly just as fast and give you just as great an 'adrenalin rush', as the smaller engine would on 40% nitro.... And you will lose about 1 minute per flight, instead of cutting your total weekly flying time by 75%...
It is simply a matter of using your ever smaller hobby budget more wisely.
Using high nitro fuels in any sport model, used for recreation, is the wrong way to go. It simply isn't cost effective.
If you are racing and need to squeeze every last RPM from a given engine, it is a totally different story...
Added reliability?
40% nitro fuel is much more likely to cause your engine to fail catastrophically... Where would that fit into the equation?
       Post #: 32
RE: fs 70 on 30% - 9/14/2006 12:21:23 PM
FlyerBry
Status: offline
quote:
ORIGINAL: FlyerBry
I agree. Unfortunately I just took this engine off the sport plane that I had it on and put it back on my Cub. To run 30% in it now would be kind of a waste. The .70 is already plenty of power for a .40 size Cub. Again, kind of like souping up a Honda Civic. My personal feeling is if you are going to throw money at something to develop more performance, why not start with something that is already a proven high performance vehicle.
Another interesting test I could try would be to run FAI fuel in my Saito to see how it performs compared to 15% and 30%. Not so sure I want to try the FAI fuel though due to the high castor content.
       Post #: 33
RE: fs 70 on 30% - 9/14/2006 2:09:14 PM
RC-Bearings
Status: offline
quote:
ORIGINAL: DarZeelon
Added reliability?
Then we should all be flying hand launched gliders because we would get a lot more of them for the money.
That is not the point. The point here is that the OS 70 will perform better with higher nitro. It is up to you to determine whether it is the right thing for you to do.
       Post #: 34
RE: fs 70 on 30% - 9/14/2006 2:47:03 PM
DarZeelon
Status: offline
I don't agree, Paul.
It would more correctly be stated like this:
"We would find the route that would give us the most enjoyment from the hobby, within the time we can spend on the hobby and within the budget constraints we imposed upon it."
For me at least, 'flying hand launched gliders' cannot even appear within the same paragraph as the word 'enjoyment'.
quote:
...The point here is that the OS.70FS will perform better with higher nitro. It is up to you to determine whether it is the right thing for you to do.
I can agree with that, but would you tell all sport fliers (which is most of us, I believe) that they should always use 40% nitro, wear their engines out twice as fast and use up all their R/C budget within a quarter of the time, just because their engine will run 10% better on that fuel, than on 5% nitro?
I sure wouldn't.
The original question posted was probably not cost related, but dealt with the possibility of using 30% nitro fuel in this engine.
I would say no, because whether it happens from mis-adjustment, or from plain, accelerated wear, this engine will not live nearly as long as it would with the fuel specified by the manufacturer. It would clearly void the warranty as well.
       Post #: 35
RE: fs 70 on 30% - 9/14/2006 4:42:37 PM
RC-Bearings
Status: offline
quote:
ORIGINAL: DarZeelon
I sure wouldn't.
Dar,
Just how long should that engine last? My OS .91 Surpass is 15 years old and had had maybe 10 flights with 15% or less nitro. The rest of the time it has had 30% or more. Hundreds of flights. I replaced the bearings once and that's it. There are dozens of other people I know personally that have done the same thing with 4 strokes and their experiences are the same as mine. I don't buy the accelerated wear bit just because you use higher nitro and I will bet that there have not been any scientific tests to show that.
I also NEVER told all sport fliers that they HAD to use 40% nitro. Only that it was possible and the engine will run well on it.
So, YES, an OS 70 Surpass CAN be safely run on higher nitro with the same precautions you would use with lower nitro.
       Post #: 36
RE: fs 70 on 30% - 9/14/2006 5:06:43 PM
downunder
Status: online
quote:
ORIGINAL: FlyerBry
Then you're in luck because a couple of fuel manufacturers haven't got a clue what true FAI fuel is so they make something with zero nitro and 17% all synthetic or a similar fuel with a blend of castor/synthetic at 17% and call it FAI. Have a look for Cruel Power (I think that's the name ).
As for an engine wearing out faster when using high nitro, see what Dar said in post #30. "Using 40% nitro, you use fuel at a rate ~2.5 times higher than if you run 0-5% nitro." Another way to interpret this is to say that with 40% nitro the flow rate of oil through the engine is ~2.5 times greater. So unless a lot of oil can damage an engine.............
       Post #: 37
RE: fs 70 on 30% - 9/14/2006 5:59:59 PM
Sport_Pilot
Status: offline
I have never had a problem with high nitro except for perhaps one time. High nitro fuel generally runs cooler than low nitro due to the rich mixture, but if you have a lean run it will be a lot hotter. Well I was running a four stroke on 25% Cruel Power, well for some reason I had a lean run before I finished the fuel, I think it was from a hole in the fuel line, but it was years ago and not sure. The engine was extreamly hot and had very poor compression, but ran fine after it cooled off. I flew the plane a couple of times that day and finished off the fuel. The next week or so I came out with 10 or 15% Omega fuel and flew it a few more times, no problems. But I think the next trip out the bearings had a loud whine. Felt fine but they were obviously fine. Fortunately the engine was under warrenty and they replaced it for free.
Other than that as for abnormal wear, rust, and corrosion. I have never experianced this with high nitro fuel. I don't think I have run any for any length of time with more than 35% nitro though.
“I Saw Elvis at 1000 Feet” John Force
(in reply to downunder)
