RC-Bearings
AZ, USA Status: offline
Good! Some real world data that also supports one of my contentions. In my first post on this subject, I stated quote:
The only engines I know that do not like nitro above 30% are the Saitos. I wish someone here had an OS 70 that they could do the same test on but use a more appropriate fuel with a castor/synthetic blend oil. Straight castor is a well known problem with higher nitro content fuels. If anyone in the Phoenix area has one, I'll buy the fuel for the test. I will also bring out my old OS .91 Surpass for commparison. quote:
ORIGINAL: loughbd Well boys, I just got done with 3 hours of fooling around with Saito four cycle glow engines. I ran a little experiment on the differences of high and low nitromethane content fuel. Here's today's results. I had to quit after the first two engines as my neighbor was complaining about the noise (from a small 4 cycle?). I'll do the Saito 50 tomorrow. I ran two engines in todays effort. The first was an OLD bolt on head Saito FA45. The second was the more modern one piece cylinder and head Saito FA45. Prop was a TF power Point 11x6. Fuel was Hobby Shack White Lightning (10% nitromethane, 20% castor oil, 70% methanol. The other fuel was Cox Red Can racing fuel (35% nitromethane, 20% castor oil, 45% methanol. The fuel was measured with a monoject 2 ounce syringe. Glow plug was an Enya #3, the plugs I use in most of my engines. Now from what I read in this thread I should have seen a large increase in power with the 35% stuff. Also as one member stated the fuel consumption on the 35% should have 2 1/2 times as much. I ran each engine a short time to get the best needle setting then ran each engine 4 times and took the avarage time each ran on two ounces of fuel and the average RPM I got using a Royal products tachometer. I tried the old bolt on Saito first. On the 10% fuel it ran about 8900 RPM and about 7 minutes on two ounces. I couldn't get it to run worth a poop on the 35%. It got hot and kept quitting. I opened the needle until it would run without overheating and quitting and it ran so slow it wouldn't have been useful as an engine. Gave up on it. Here are my results with the newer one piece saito 45. On the 10% fuel the average RPM was 10,000 and it ran an average of 5 minutes and 20 seconds on two ounces of fuel. That's for four runs and I left the hatch open to make sure all the fuel was used. On the Cox 35% nitro fuel the average RPM was 10,200, a gain of 200RPM. The average run time was 5 minutes and 5 seconds. A difference of about 15 seconds for 2 ounces of fuel. Probably a negligable amount as far as flyng time is concerned. The price of a gallon of 10% nitro Powermaster fuel is about $13.00 here where I live. A gallon of Cox fuel runs about $110.00 per gallon. A gallon of Cool power 30% heli fuel from Tower is $23.00 plus a bunch for shipping. The net difference between 10% nitro and 35% nitro in my little experiment was about 200 RPM and the run time was almost identical. Do I think it's worth the difference?? NOPE. You can believe what I say and did or can say I'm full of you-know-what but you are all free to do the same thing I did. Tomorrow I am going to run the Saito FA50 on my Skyloop 404 and see what the results are. One surprising thing to note was the difference in power the newer one piece saito had over the older bolt on head Saito. Both are well broken in and the newer one probably has more time on it. Both have excellent compression and new or good bearings.
_____________________________
Steel and Ceramic bearings for model engines http://www.rc-bearings.com
