DarZeelon
Joined: 4/9/2003 From: Rosh-Ha'Ayin, ISRAEL Status: offline
quote:
ORIGINAL: John Patterson ...Most of the guys I fly with are using a 30% ...According to the guys using the 30% nitro/syn oil, they don't have any problems with carbon buildup. John, The reason those guys have no carbon build-up problems has nothing to do with the 30% nitro. Your engine neither needs it, nor is it optimized to run on it. You would not believe how much richer your engine must be run with 30% nitro, compared with 15%, just to prevent detonation. OS tells you to use up to 15%, because it cannot be optimized to run at an ideal mixture setting; not because it cannot possibly run at all on 30%. The guys at your club are doing a foolish thing by using only 30% and actually doubling their fuel bill, with no benefits whatsoever. Using 15% all synthetic will keep their engines just as clean and since 30% must be run very rich; 15% run much leaner (earlier ignition) will give about as much power too. The only engines that actually benefit (power-wise) from 30% nitro, are the YS four-strokes. Saitos more or less peak at 20%. I do recommend some castor oil for added protection, but if you are careful, all except the ABN OS.70FL, can safely use fuel with all synthetic lubricant.
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com MVVS - Jett - Nelson - Bolly - Mejzlik
