What's Wrong with my Moki 180
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-50cc Gas Engine by SERCE, LLC.
Seller:  XYZUSA
Details:   $259.95   |  9/12/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> What's Wrong with my Moki 180
Page: [1]
Login
What's Wrong with my Moki 180 - 9/8/2006 8:15:26 PM
hilleyja
Status: offline
I've had this Moki 180 for about 4 years but have less than 3 gallons of fuel run through it. I can't get it to run well at all right now. I've replace the needlevalve assembly and can usually get it to start easily enough when I have a 24-volt starter to use. It won't transition well, nor can I get a good idle -- that is on a long term run. It will run well for a couple of minutes but just about the time I think I can taxi for takeoff the engine fails. I have adjusted the low-speed knob numerous times but have kept it within 3 notches of center -- was told it should not adjust well past that range. NOTE: I have noticed that while starting the fuel draw to the carburetor does not hold until the engine starts, i.e., after priming it recedes.
NOTE:
1.) Fuel: Morgan Omega FAI (0% Nitro, 18% 20/80 Castor/Synthetic)
2.) Xtra large fuel line with xtra large klunk and brass fuel tubing. Fuel tank is less than 3" behind the crackcase (Its mounted on a Giant Profile airplane).
3.) Is it normal? Running temperature is in excess of 300 degrees fahrenheit at the exhaust port -- has been since brand new.
4.) Compression appears to be normal.
5.) Crankcase back was tapped for pressure but subsequently plugged when I removed the Kline regulator -- no longer needed it with the fuel tank placement on the profile.
6.) Running with Sports Muffler.
< Message edited by hilleyja -- 9/8/2006 8:16:34 PM >
_____________________________
Jim Hilley
AMA #671825
RCCA# 758
Twist 150 Brotherhood #14
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
