RE: Bling 3D 50cc ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Bling 3D 50cc ARF Page: <<   < prev  13 14 15 16 17 18 19 20 21 [22]
Login
RE: Bling 3D 50cc ARF - 9/13/2008 3:56 AM
Walt and Sage
Score: 100
Last Login: 11/28/2010
Status: offline
Hi Barry,
GREAT LOOKING PLANE !!!!!!!!!!!!!!!!!!
The ONLY concern that I have is the length at 85 inches as we feel the Bling
might fly better with 6 inches out of it...The Bling is 78.5
BUT: the Reactor has a quite WIDER wing at 84.5
The Bling is 71
The Reactor may be a WONDERFUL plane...
I WILL BE FOLOWING IT ON THE NET AS I AM SURE THERE WILL BE MUCH INTEREST!!!
You need to start a forum on it when you start on it !!!!!
THANKS for the heads up on the plane...
Walt...
_____________________________
A Man''s Character is his Destiny.........
........AMA 38255 "PRO BRO 2344"
Hide Signatures
(in reply to Barry Cazier)
       Post #: 526
RE: Bling 3D 50cc ARF - 10/8/2008 8:50 AM
VeeAte
Score: 120
Last Login: 4/20/2012
Status: offline
Just scored a new in box Bling 3D for $200 AUD.
Cant wait.
I watched the guy I am buying this one from absolutely hammer his around the sky the other weekend. He had been having engine problems and was sick of take off shortly followed by landing. So when he got the DA50 going he opened it up and flew the plane for a whole tank at 3/4 to full throttle the whole time. KE passes 4 feet above the ground was spectacular.
No problems with the wing. Fantastic to watch.
I know thats not 3D flying, but this plane handled WOT passes into loops and rolls with no problems at all.
I will check the wing root etc on mine to make sure everything is glued. He said the one he flies hasnt been touched except for a couple of spots in the radio tray that needed a dot of glue.
Anyone flown one of these with the DL50 ? Thats what I will run in it.
Hide Signatures
(in reply to Walt and Sage)
       Post #: 527
RE: Bling 3D 50cc ARF - 10/8/2008 2:18 PM
negy1
Score: 100
Last Login: 1/2/2011
Status: offline
yes mate myfreind has got a dl 50 id his good 3d power the one ive got started of with a mvvs 35cc and now have a dzy 48cc twin 21x8 wood prop good power to 3d but not as mutch power as the dl50 ive had over 100 flighs its the best 3d plane that ive flown its a shame icant buy enoughter one
Hide Signatures
(in reply to VeeAte)
       Post #: 528
RE: Bling 3D 50cc ARF - 10/8/2008 2:52 PM
VeeAte
Score: 120
Status: offline
Awesome. Sounds good.
Cant wait to get her in the air.
Thanks for the info.
Hide Signatures
(in reply to negy1)
       Post #: 529
RE: Bling 3D 50cc ARF - 3/13/2009 1:41 AM
mandtra
Score: 100
Last Login: 3/10/2010
Status: offline
My Bling flies with it's tail down like it's tail heavy all the time. and when taking power off for landing it really ballons up and I have to hold the nose down. My CG is at 7 7/8 and the CG range is 7 7/8 -8 5/8" but flies good inverted. I checked the wings and horiz stabs and everything is just as it should be. the firewall is totally neutral. no thrust at all (no right or down) and foom reading this entire thread most are using a CG of 8 1/4 . should I try some up or down thrust to see if it helps?
Hide Signatures
       Post #: 530
RE: Bling 3D 50cc ARF - 3/13/2009 1:43 AM
mandtra
Score: 100
Status: offline
oh, i'm running an Area51 with a 23 A VESS prop
Hide Signatures
(in reply to mandtra)
       Post #: 531
RE: Bling 3D 50cc ARF - 3/13/2009 4:11 PM
closetguy
Score: 166
Last Login: 5/20/2013
Status: offline
you know mine flies the same way.flies hands off when inverted but always needs a little push down to get it to land.but this is not the first time i heard of this for the plane,probably due to the long tail?
Hide Signatures
       Post #: 532
RE: Bling 3D 50cc ARF - 3/13/2009 6:45 PM
Walt and Sage
Score: 100
Status: offline
We have two of them and they both did the same thing..
Dl50s We moved the motor forward 1/4 inch and the one A123 up front..
MUCH better...
Still does inverted flat spins like a heli... but easier to land....
Walt
Hide Signatures
(in reply to closetguy)
       Post #: 533
RE: Bling 3D 50cc ARF - 7/28/2009 7:07 PM
sergeflavigne
Score: 100
Last Login: 7/19/2010
Status: offline
quote:
ORIGINAL: Walt and Sage
MUCH better...
Walt
Anybody interested in a new set of wings. I have a new set of Bling wings in the box.
S
Hide Signatures
       Post #: 534
RE: Bling 3D 50cc ARF - 8/29/2009 9:12 PM
sergeflavigne
Score: 100
Status: offline
I still have a set of Bling wings with ailerons, new in the box $65.00 and I'll pay the shipping in the lower 48.
Hide Signatures
(in reply to sergeflavigne)
       Post #: 535
RE: Bling 3D 50cc ARF - 8/30/2009 6:26 PM
Walt and Sage
Score: 100
Status: offline
quote:
ORIGINAL: sergeflavigne
Thanks, will certainly keep you in mind .....
Hide Signatures
       Post #: 536
RE: Bling 3D 50cc ARF - 11/21/2011 1:56 AM
drbenz
Score: 100
Last Login: 1/31/2013
Status: offline
anyone still flying these??? Mine flies great!!!
Hide Signatures
       Post #: 537
RE: Bling 3D 50cc ARF - 11/26/2011 2:14 AM
Kamikazi
Score: 100
Last Login: 1/28/2012
Status: offline
Yes! As a matter of fact I just maidened mine a couple months ago after having put in on the back shelf for a few years. I'm sorry I didn't finish it sooner.
This plane flies awesome as an electric conversion. I had to build a battery box on the firewall in order to get the CG forward enough.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to drbenz)
       Post #: 538
RE: Bling 3D 50cc ARF - 11/26/2011 2:24 AM
drbenz
Score: 100
Status: offline
looks great. no muffler holes. I too put mine on the shelf for about 2 years. Now I am sorry i did. having more fun with it than any other plane.
Hide Signatures
(in reply to Kamikazi)
       Post #: 539
RE: Bling 3D 50cc ARF - 11/26/2011 1:03 PM
Kamikazi
Score: 100
Status: offline
I did replace the gear on mine shortly after I took those pictures. I could not find the Chip Hyde double vision gear anywhere - seems to be no longer available.
I installed a one-piece Graph Tech Main Gear for the Extreme Flight 74" Yak (#244). Fits the Bling perfectly - the width on the fuselage is identical. It sits about 2" higher and has a lot more "spring" to it than the stock metal gear. It also has a fair bit of sweep which I think looks great with the sweep facing rearward.
I really wish they'd bring this plane back. At least almost all the parts are still available...
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 540
RE: Bling 3D 50cc ARF - 11/26/2011 2:52 PM
Spadkun
Score: 100
Last Login: 7/1/2012
Status: offline
I added a 1/2 inch block of wood under the standard gear with longer bolts, gives a bit more prop clearance. Running DL50 on 23x8. Still providing the fun! The Bling is still listed on the importers web site here.
http://www.angelsjapan.jp/seagull/Seagull_page2/BLING3D_50cc_ora_b.htm
Hide Signatures
       Post #: 541
RE: Bling 3D 50cc ARF - 11/26/2011 11:10 PM
Kamikazi
Score: 100
Status: offline
It's still on Seagull's main website too. It's one of only 4 models listed under "gas power - aerobatic".
It seems they might be still selling them in some countries such as Japan?
Perhaps it's just the USA distributor (Horizon Hobby), that has killed it.
Hide Signatures
(in reply to Spadkun)
       Post #: 542
RE: Bling 3D 50cc ARF - 11/26/2011 11:37 PM
drbenz
Score: 100
Status: offline
That graf-tech gear looks great! saved a little weight too. Anyone weighed their planes? I weighed mine a few years ago and i think it was just over 14 lbs. I will have to recheck that to be sure.
Hide Signatures
       Post #: 543
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.688RCU1
