gadget01
AP, USA Status: offline
330mm blades are the longest you should run unless you extend the tail to keep from hitting the tail blades. I use T-Rex 325mm blades and SAB 315mm carbons and they both work great. When I first installed the CP head kit, I just used a set of LMH blades for a while. You won't be going inverted right away anyhow, so it doesn't matter. LMH blades are very efficient and lift a lot more than symmetrical blades so you don't need as much power or nearly as much pitch to hover. Find the latest version of the EHBG and read through setting up your throttle and pitch curves along with idle-up settings. The BT CP kit is a super sweet upgrade and it makes the Corona a "real heli" and much easier to control. It's not nearly as indestructable but not far off- I "landed" inverted and only broke a bolt and a mixing arm. Since it's much easier to control, crashing "should" be more infrequent anyways- unless you're trying moves out that you're not set up for.
_____________________________
oooh, was that supposed to happen?
