RE: 32% Carden Yak 54 Construction
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: 32% Carden Yak 54 Construction
Page: <<   < prev  1 [2]
Login
RE: 32% Carden Yak 54 Construction - 11/5/2006 2:28:50 PM
swk550
Status: offline
Rudder control horn installation
I fnally have some more time to build. I will be using the TBM CF control horns for all surfaces. I chose them as I can use the Dubro ball links and they support the ball links from both sides. Here are my steps:
1. Sand the bevel in the control surface and drill the Robart hinge holes
2. Inlay a 1" or 1.5" balsa block in the control surface. Use epoxy or Gorilla glue. Sand smooth the surfaces.
3. Assemble the control horn. Measure distance for horn slots. Cut the slots with a band saw.
4. Trial fit the control horn and make sure the ball link is square and centered at the hinge bevel centerline.
5. Make 1/32" hard ply slot closure pieces.
6. After covering, the entire assembly will be installed with epoxy.
Good luck,
Steve
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to 5150flyer)
       Post #: 26
RE: 32% Carden Yak 54 Construction - 11/17/2006 1:27:17 AM
swk550
Status: offline
Yak Covering
I have next week off for vacation. It's time to start covering. This phase is my hardest because it is so hard for me to do it right. I just need to take my time and not get in a hurry. I've decided to cover my Carden Yak similar to my QQ Yak. I start by laying out the pattern and cutting poster paper templates. I'll post a few more pictures as the covering progresses.
Click for fullsize
Click for fullsize
       Post #: 27
RE: 32% Carden Yak 54 Construction - 11/22/2006 1:14:46 PM
swk550
Status: offline
Making progress
I have now covered the fuse and stabs. I did go ahead and repaint the cowl and canopy trim colors to match the covering. I used Ultracote on the fuse. The wings and stabs will use Monokote white as I had a 25' roll of the stuff. I did not use monokote on the fuse because Ultracote forms better at the vertical fin at the fuse joint. Today I hope to start covering the wings.
Steve
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to swk550)
       Post #: 28
RE: 32% Carden Yak 54 Construction - 11/24/2006 2:07:52 PM
swk550
Status: offline
Wing covering
The trim colors are made from poster board templates. The white is Monokote. The trim colors are Ultracote.
Steve
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 29
RE: 32% Carden Yak 54 Construction - 11/24/2006 2:13:44 PM
swk550
Status: offline
Control horn installation
I am using the TBM CF truss type control horns. Pacer hinge glue makes the installation easy. The glue bottle comes with a fine applicator tip. This way I can fill the hinge slots with glue and get good horn coverage. After inserting the horns, center the control linkage over the hinge centerline. I use a Q-tip to wipe up any excess glue after inserting the horn. Now I'm ready to install the radio and engine.
Steve
Click for fullsize
Click for fullsize
       Post #: 30
RE: 32% Carden Yak 54 Construction - 11/26/2006 7:44:38 PM
gregman50
Status: offline
Are those trim colors placed over a completely covered wing or do they just overlap each other? I am just curious because I am going to build my next plane, I've had just about enough of these arfs !!!!!!!!!!!!
       Post #: 31
RE: 32% Carden Yak 54 Construction - 11/26/2006 10:55:13 PM
swk550
Status: offline
The trim colors overlap each other. I did not finish it in all white and then add trim colors.
Good luck in your build.
Steve
(in reply to gregman50)
       Post #: 32
RE: 32% Carden Yak 54 Construction - 1/16/2007 12:51:33 PM
swk550
Status: offline
range of CG locations ????
The plans show the CG location around 1/4" from the front edge of the wing tube. On my initial radio intallation, my CG aft to around 1/4" from the rear edge of the wing tube. For IMAC flying, where is the optimal CG location?
Steve
       Post #: 33
RE: 32% Carden Yak 54 Construction - 1/21/2007 1:20:00 AM
swk550
Status: offline
Yak balance and battery installation
I had installed two Fromeco 4800 batteries on the engine box for balance. I was still 3/4" aft the recommended CG. I have switched to one 3250ma 6v and one 1650ma 6v NiMh receiver batteries. They are on the front of the engine box. Right now I am between 1/8" and 1/4" aft (rearward) of the CG on the plans.
I am pleased with the final weight at 29#. The plane has a DA 100 engine, MTW TD-75K canisters and eight JR DS8611A servos on the control surfaces and one JR 4031 servo for throttle. Hope the weather clears so I can get in a test flight. Here are some pictures.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 34
RE: 32% Carden Yak 54 Construction - 1/27/2007 1:01:29 AM
swk550
Status: offline
Maiden flights today
The weather let up today. The field was a bit wet, but winds were light and down the runway. This 32% Yak flies well. I ended up setting the CG per the plans. I only needed one click of up elevator. Rudder and aileron were dead on. This plane flies even better than my QQ 102" Yak. I had four uneventful flights. No mix with right rudder and less than 2% on the other side. I practiced the IMAC sportsman maneuvers and some of the old Masters pattern maneuvers. It draws straight down lines. Right thrust is perfect. We did some harriers and had no wing rock. Torque rolles were effortless. At 29# it feels light. I currently do not have any cowl baffling. The max cylinder temperature today was 125 deg F. Great snaps and stall entries. One thing I really like is the airframe construction. I have almost no vibration. At idle, the ailerons are steady. Absolutely no canopy vibration. Here are a few pictures. I am ready for this season.
Steve K
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 35
RE: 32% Carden Yak 54 Construction - 1/27/2007 3:04:24 AM
as722
Status: offline
Steve,
It looks awesome ! Good luck with your new yak.
Albert
_____________________________
Carden Aircraft
       Post #: 36
RE: 32% Carden Yak 54 Construction - 1/27/2007 3:35:18 PM
PJFaller
Status: offline
Im getting ready to finish my yak. Did you run the fiberglass for the hatch all the way up to the paint line for canopy or did you just overlap the canopy with fiberglass just a little and then finished the glass work so you could not see where the glass ended and the canopy began. Ive been told I have to overlap the canopy wi
