Carden 35% Extra 260
- RTF
Seller:jmiracle Details:
$2,950.00
| 10/2/2008
| Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
TX, USA Status: offline
I used 1/4" depron foam for the canister floor plate. I ended up splicing in balsa for the area at the rear end of the MTW TD75K canisters. This way if the canister rubs, it will only touch the balsa. Also here are some pictures of the throttle servo mount. I still need to cut the air exit hole in the 1/4" balsa sheeting behind the landing gear mount plywood.
OH, USA Status: offline
I too am doing this stab modification. In fact I have changed all of my giant scale builds to this style of attachment. In the pic below you will see from left to right stabs from a 40% Carden 330, 35% Hurley Extra, and a Great Planes Extra 330L. I dont want to watch another plane go in because of stabs departing the aircraft, trust me it is not fun to watch.
