dif lockers
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> dif lockers
Page: [1]
Login
dif lockers - 9/11/2006 2:32:20 AM
RC Reaper
Status: offline
what do you use as a dif locker i used 2 ton apoxy but it keeps breaking loose
       Post #: 1
RE: dif lockers - 9/11/2006 2:54:01 AM
dezfan
Status: offline
Try some Shoe Goo, that's what I use!
_____________________________
TEAM PANTHER DRIVER / JP CUSTOM RCs / J Concepts
07 CMRCRC 2.2 Champ / 07 KC 2.2 Mid West Champ / 2 Time USRCCA Qualif
(in reply to RC Reaper)
       Post #: 2
RE: dif lockers - 9/11/2006 3:16:23 AM
-xXXx-
Status: offline
Won't hot glue work?
Well theres your problem. -Adam Savage And Jamie Hyneman
My rc's: aerobird extreme, 3x AAAA, T-maxx, rusty, micro-t
(in reply to dezfan)
       Post #: 3
RE: dif lockers - 9/11/2006 3:41:22 AM
Mr. Mugen
Status: online
pack it with silly puddy
Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
(in reply to -xXXx-)
       Post #: 4
RE: dif lockers - 9/11/2006 3:41:36 AM
dezfan
Status: offline
It you use the right grade, try the hardware store.
The kind they sell at the craft store deteroriated and it will fail.
       Post #: 5
RE: dif lockers - 9/11/2006 1:04:20 PM
-xXXx-
Status: offline
WHats the right grade?
       Post #: 6
RE: dif lockers - 9/11/2006 4:45:38 PM
dezfan
Status: offline
Not sure as I use SHOE GOO!
       Post #: 7
RE: dif lockers - 9/11/2006 9:41:39 PM
-xXXx-
Status: offline
Ohh, what about C.A. glue?
< Message edited by rc18t145 -- 9/11/2006 9:42:09 PM >
       Post #: 8
RE: dif lockers - 9/11/2006 9:52:24 PM
silent_echo
Status: offline
ca glue works but youll never get the diff apart again. if your sure you want it locked forever itll work
Hpi rs4 3 ss. modified with too many thing to list in this sig
       Post #: 9
RE: dif lockers - 9/11/2006 9:58:42 PM
-xXXx-
Status: offline
What would be the best to use if I still wanted it to come apart, but it was enough to keep it locked?
(in reply to silent_echo)
       Post #: 10
RE: dif lockers - 9/11/2006 10:24:54 PM
dezfan
Status: offline
Once more Shoe Goo.
It works well, it is inexpensive, readily available, easy to clean up, and totally reversible.
       Post #: 11
RE: dif lockers - 9/11/2006 10:28:46 PM
CustomTamiyas4Life
Status: offline
I would say use a fourth diff gear or silly puddy. Who can beat a half second to remove and place in an extra gear for an instantly locked diff?!
TNX-Converting to gasser / E-firestorm / Clod crawler/ Tamiya Rising Storm / lexan basher
       Post #: 12
RE: dif lockers - 9/11/2006 11:22:43 PM
RC Reaper
Status: offline
ive found out that the type of plastic the gears are made of alot of stuff dont really stick to it . it looks that way at first but then it comes apart later. like the 2 ton apoxy that i used. who would have thought that would come apart. but yeah ill try the shoo goo because i know that you can get that back out
(in reply to CustomTamiyas4Life)
       Post #: 13
RE: dif lockers - 9/12/2006 12:35:40 AM
-xXXx-
Status: offline
I will try the shoe goo then.
       Post #: 14
RE: dif lockers - 9/12/2006 3:20:16 AM
mindwreck
Status: offline
agree was dez. shoe goo is good stuff.
amazing goop is good if u dont' want it completely locked, it slips if u push it hard enough.
RC10-T2 ~ TXT-1 ~ F102~ F103 Ferrari 412T1 ~ Ferrari FXX TT-01 ~ Dual E-Maxxs ~ big block REVO ~ Walkera 60
       Post #: 15
RE: dif lockers - 9/18/2006 5:24:48 PM
habitatxskate
Status: offline
quote:
ORIGINAL: dezfan
Once more Shoe Goo.
shoe goo is the best..you can buy it at any skateboard shop or ccs.com, monsterskate.com, skateboard.com, action
