car fuel in planes??
Tower Hobbies
Logged in as Guest
  Printable Version
CRRC-Pro GF26I 2 stroke gas engine
Seller:  jewillis2
Details:   $219.88   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> car fuel in planes??
Page: [1]
Login
car fuel in planes?? - 9/11/2006 6:06:03 PM
deckerv
Status: offline
Any real disadvantage for running car fuel in planes??? Are they lower in oil content than plane engines?
Moderator edited title...
< Message edited by w8ye -- 9/18/2006 2:53:17 AM >
_____________________________
Vo Decker
AMA 117021
       Post #: 1
RE: car fuel in planks?? - 9/11/2006 6:18:11 PM
bigbadbowtie
Status: offline
Yes, some car fuels like Trinities Nitro Power Platinum only have 8% oil. Most are in the 10-12-14% raneg while some of the ready to run fuels will have 16%.
I believe most plane fuels have oil contents greater than 16%.
On the reverse of that, I have run Morgans Omega(17%oil) in my cars for years. :-)
Ray in Bama
(in reply to deckerv)
       Post #: 2
RE: car fuel in planks?? - 9/11/2006 9:48:11 PM
hpi apollo
Status: offline
planes run lower nitro (like 5-10%) and can sometimes have nearly double the oil, dont use car fuels because 1. they have too much nitro, 2. there isnt enough oil, use the fuel for its intended use, on the otherhand, you can run a high nitro plane fuel in your car
95% of statistics are made up on the spot
(in reply to bigbadbowtie)
       Post #: 3
RE: car fuel in planks?? - 9/17/2006 9:28:49 PM
deckerv
Status: offline
I have 3 1/2 gallons of Wildcat Eliminator 20% nitro with 18% oil left over from my cars b4 I sold them all... Would that suffice? I run 30% in my heli's all the time, but have only used the higher nitro in small planks and my Whiplash.
This is the stuff..
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXAKD7&P=0
I would think since it's 18% oil like most of the plane fuel I use, it would be fine.. but wanted to make sure
Vo Decker
AMA 117021
(in reply to hpi apollo)
       Post #: 4
RE: car fuel in planks?? - 9/18/2006 2:55:05 AM
w8ye
Status: offline
That fuel will be fine in a plane if it has 18% oil
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
       Post #: 5
RE: car fuel in planks?? - 9/18/2006 1:24:27 PM
bigbadbowtie
Status: offline
Do you have Eliminator or the Eliminator plus.
Eliminator - 14% oil
Eliminitor plus - 18% oil
Ray in Bama
(in reply to w8ye)
       Post #: 6
RE: car fuel in planes?? - 9/18/2006 6:05:25 PM
deckerv
Status: offline
The Plus
Vo Decker
AMA 117021
       Post #: 7
RE: car fuel in planes?? - 9/27/2006 8:47:46 PM
brianengy
Status: offline
I'm in the same boat. Could I use blue thunder RC car fuel in my plane? Its at 10% nitro. I have a gallon left over from my RC car.
       Post #: 8
RE: car fuel in planes?? - 9/27/2006 8:56:45 PM
bigbadbowtie
Status: offline
Brianengy,
1st..... Hello from an ex-Minnesotan(Rochester for 7 years).
I would say no. That blue thunder fuel only has 10% oil in it from what I have found.
You could add oil to it and be ok but then your nitro % is going to drop down.
This page here will show how much oil you need to add to get to a specific % and what the % of nitro will drop to.
http://www.nitrorc.com/default2.asp?Introduction=http://www.nitrorc.com/fuelws/
Ray in Bama
(in reply to brianengy)
       Post #: 9
RE: car fuel in planes?? - 9/28/2006 1:32:56 AM
brianengy
Status: offline
quote:
ORIGINAL: bigbadbowtie
Brianengy,
Thanks for the info. I was having problems finding the oil ratio for that fuel.
       Post #: 10
RE: car fuel in planes?? - 9/28/2006 1:56:11 AM
downunder
Status: offline
Actually it won't because the ratio of nitro to methanol stays the same and that's what we tune the needle valve for. As an example, if you had a fuel with 10% oil and 45% nitro then you'd also have 45% methanol so there'd be equal parts nitro/methanol. Add oil to 20% and then the mix would have 40% nitro but also 40% methanol or still equal parts. You'd just have to open the needle a little more to get the same volume of nitro/methanol flowing through.
The tricky part (and what confuses everyone) is that the first fuel would be labelled as 45% nitro and the second as 40%.
       Post #: 11
RE: car fuel in planes?? - 9/28/2006 3:26:02 AM
bigbadbowtie
Status: offline
quote:
ORIGINAL: downunder
according to the link I posted.... It will drop. Not much but it will drop. Here is what is says.....
NitroRC.com Custom Fuel Blend Recipe:
According to the figures you just gave us, your current fuel has, 10% nitro content and 10% oil content, leaving 80% methanol.
You have indicated that you wish to increase your oil content by 7% to a new total of 17%
In order to accomplish this you will simply need to add 10.5 ounces of castor/synthetic oil to your 128 ounces of fuel.
When you're done, you should end up with 138.5 ounces (1.08 gallons) of newly blended, custom fuel.
Custom Blend Results
Starting Nitro: 10% - - - - - - - -
Ending Nitro: 9.2%
Starting Oil: 10% Add oz Oil: 10.5 Ending Oil: 17%
Starting Mthnl:
80% - - - - - - - -
Ending Mthnl: 73.8%
Ray in Bama
(in reply to downunder)
       Post #: 12
RE: car fuel in planes?? - 9/28/2006 4:00:41 AM
carrellh
Status: offline
To get exactly 17% you'd actually need to add 10.8 ounces; assuming the existing fuel is a perfectly blended and measured gallon.
Click to see fullsize image.
Click for fullsize
Regards,
Carrell
       Post #: 13
RE: car fuel in planes?? - 9/28/2006 2:47:49 PM
brianengy
Status: offline
Where do you buy castor oil at? Can a person just buy a quart of it at the hobby shop? I live in the Minneapolis area.
(in reply to carrellh)
       Post #: 14
RE: car fuel in planes?? - 9/28/2006 3:08:45 PM
bigbadbowtie
Status: offline
